Question about Technical Hifi PA2000 Amplifier
HOW TO HOOK UP Technical Hifi LZ-2000 amplifier
I can't figure out how to hook this amp up and on with a manual or diegrams please let me know . thank you !!!
    Problem Solver:
  • 5 Answers
You need to say how you want to wire it up.is it to speakers that will be bi-wired or just a normal set of speakers,if its a cd player you want to play,how many sets of speaker terminals there are at the back of the amp.tell me exactly what the problem is in as much detail as you canand i can help you easily.
Posted on Jan 08, 2013
  • 1 more comment
  • Michael Popolillo
    Michael Popolillo Jan 08, 2013
    I'm trying to hook it up with bannana clips and the speakers have 1/4 plugs but i need to make these wires and i dont know how , and also dont know how to hook the amp up , there's no sound at all please help thank Mike
  • martin thomson Jan 08, 2013
    hi there how many speaker cables do you have and how many plugs do you have,and when you say hook up do you want to play a cd player or something else..
    if you have 4 seperate wires,get a wire with the stripe and connect the red plug to both ends of this wire(if you have 4 different wires do this to 2 cables),so you now have 2 stripped cables with red plugs at each end.do the same again with the other cables with the black plugs.you now have either 2 cables or four cables.look at your amp from the back,your speaker terminals say left and right.connect a red plug to the left terminal on the bottom of the amp then connect the other end of this cable to the bottom of your left speaker.then connect a black plug into the left terminal next to the red plug you have just connected.(if you have 4 seperate wires do the same againon the left terminals).repeat this for the right side making sure the bottom terminals on your amp are wired to the bottom terminals of your right speaker.if you have 4 separate wires push both buttons on amp for speakers a+b(this sends power to both terminals and powers both speakerstreble and bass).connect your phono leads to the amp input section using red to the red input and do the same to the cd player at the back terminal.then connect the remaining phono plug into the terminal of the amp directly above the red phono plug,and do the same at the cd player.
Connect a TV to a Tehnical Pro AMP 1100
Depends if your TV has audio outputs. If not use the Headphone Out, just get an adapter cable from that to the amp.
Luck.
May 24, 2015 | Technical Pro LZ-1100 Amplifier
Lz-1100 manual
Contact the manufacturer or try an on line search with Google!
Apr 26, 2014 | Technical Pro LZ-1100 Amplifier
Dieagram to hook up gas lines 1978 low rider harley davidson 2 peace gas tanks
Hi Anonymous, for more information about your question please visit the website below. Good luck and have nice day.
Harley Davidson Manuals Mark Workshop
Sep 27, 2012 | Harley Davidson FXDL Dyna Low Rider...
One of the channels is'nt working it just stop playing
I have the same problem, did you ever get a solution?
Apr 30, 2012 | Technical Pro LZ-1100 Amplifier
Connect a denon amplifier pm-510ae to a technics equaliser sh-8058
Hi Just to let you know what ever you put between the amp and speaker you will degrade the sound quality. Even with the best machines you will muddy the sound. If you read HiFI magizine they will tell you this is true.
But if you don't care about the quality of sound than go ahead hook an equalizer on it. Hope that helps you.
Mar 27, 2012 | Denon Audio Players & Recorders
How to hook up a gemini amplifier?
typically (unless your useing other gear besides mixer and amp) you'd come out of the L/R outs. ( Main outs ) to the Main inputs of the power amp then out to your speakers (outs of power amp). Now the amp could be in bridge mono or other factors but typically, like i said, just
Mixer Out- Amp In- Amp Out- Speakers.
Oct 22, 2011 | Gemini Sound Products GEMINI XGA 2000 2000...
Don't know how to hook up the amp. It came with a wiring kit and I have no idea on how to hook it up.
You need to connect the Power wire (Most likely red wire with fuse) to the battery and run it to where you put the amp. You need to also drill a whole in the car and make sure it is grinded up and bare metal is shown. Screw the ground wire there with a bolt and nut. You will then need to run the rca cables from the amp location to either the back of the headunit if it has RCA outputs, or use a Line out converter, you can get them at best buy. Then you need to find your cars wiring harness code and figure out which is the remote ignition turn on and tap into that and feed that wire back to the amp to turn it on. Hook all wires up and make sure power and ground DO NOT TOUCH.
Jul 24, 2011 | Visonik Dual Bass Box with Amplifier Car...
RCA inputs not working on LZ-1100
Push the input souce select buttons on the front of th unit to select the proper input.
Twist the jacks into the amp to remove any corrosion on the terminals or the cables.
Good luck
Jun 21, 2011 | Technical Pro LZ-1100 Amplifier
Equilizer
I need more information to help you. The equalizer has to go in between two devices to have an effect.
Like this:
  • Multiple units' (CD Player, Tuner, Cassette, etc.) OUTPUTS to Pre-amplifier INPUTs
  • Pre-Amp OUTPUT to Equalizer INPUT
  • Equalizer OUTPUT to Amplifier INPUT
If you don't have a separate Pre-Amp, you have to try something else. Re-post if this is the case...
Dec 25, 2007 | Spectrum Technical Hifi EQ-B5100...
Equalizer hook up.
only hook up to tape monitor or else u wont get an audio signal . .....also hook all equipment to amplifier not eq ...it goes tape cd tuner and any type of external equipment to amp.then find tape 2 it sould be called tape moniter and have a separet botten for u to select it goes record to eq and play from eq
Aug 27, 2007 | Spectrum Technical Hifi EQ-B5100...
Technical Hifi PA2000 Amplifier Logo
81 people viewed this question
Top Technical Hifi Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Technical Hifi Audio Player and Recorder Expert? Answer questions, earn points and help others
