Question about Proform XP CrossWalk 580 Treadmill
Does not go all the way up or down
Stays inbetween 6and 8
    Top Expert:
  • Proform Master
  • 12,223 Answers
PleaSE run THE SOFTWARE CALIBRATION, for easy diagnose, troubleshooting and fix it.
Lube the elevation motor, see the diagram attached.and proceed
God bless you
Posted on Jan 07, 2013
Power wont stay on
It sounds Kirby has a new model with a new type of switch go back to the shop you bought it , if you have not read the manual , a tip , 1 look how the dustbag is connected it must be good connected if not the problem is there , second the hose the hose must be connected good because if not the problem is there more options are not there for the master switch . if its controlled that the switches are god pushed in by mechanic parts of the dustbag connector or hose connector , it must run and stay on power the dustbag is the one that is the most probable connection what maybe not enough is turned to the motor housing have a stabil working on -off switch. if it not does made difference go immediatly back to the shop. with proof of purchase, you get an other new one if its a factory failure. or the powercable was accidentially bruised between a door or linger behind the powerplug and that why its faltering maybe.
Apr 21, 2015 | Kirby Vacuums
How do I remove - pop up - the back seat bottom part of a Toyota Matrix?
sit on seat hands down in front push down and back while also lifting front edge
Feb 07, 2015 | 2010 Toyota Matrix Automatic
Heater&a/c stopped working
First thing to do is get the computer scanned for trouble codes.
It could be a thermostat or several other things.
Feb 28, 2013 | 2006 Chevrolet HHR
The neutral lite wont stay on , the foot lever is not allowing it to go to neutral
The neutral light won't stay on because the gearbox isn't in neutral. try rocking the bike backwards and forwards, kick the gears down as many time as you can (at least 6) and then try moving the gear lever up one until the bike moves freely backwards and forwards. Your bike should then start. It would be easier to identify any problems if you let us know the make and model of the bike.
Feb 11, 2013 | Motorcycles
Program chanel memory
Try an auto tune process to get all channels in sequence. Refer to its user manual for details.
Apr 22, 2012 | Televison & Video
Linsky cisco E 1000 will not recognize belkin wireless usb adapter N150
You have to check if your router is properly configured.Try changing the settings of the channel from Auto to channel 6and the b and g mode into mixed mode.
Feb 18, 2012 | Cisco Linksys E1000 WirelessN Broadband...
How do you remove the seat from a 1996 honda shadow vlx
Hi, There are two allen key screws that keep the pillion seat secured down. The riders seat then slides backwards to remove. Have a look inbetween the riders seat and pillion seat from either side of the bike. Prise the gap apart with your fingers and look inbetween. About an 30mm or so inside, you will see an allen key head screw. It is easier with a screw driver that takes an allen key drive as is very awkward to get a normal allen key down that deep. You will need to be in very good light or use a torch to look inbetween the seats as its very hard to spot. When you have removed the screws from both sides the pillion seat just lifts up and forward. The riders seat lift up and backward. Cheers
Jul 26, 2010 | 1996 Honda VT 600 C Shadow
Tv won't stay
It sounds like the convergence went out. STK 394-250 and some pico fuses. Check that the error code is 2.2 before you replace any parts.
To check the error code simply hold down the menu and device buttons for 5 sec and count the flashes inbetween pauses. Goodluck.
Jul 05, 2010 | Mitsubishi WT-42413 42" Rear Projection...
Trouble loading movie onto play and play back
download AVS Video Converter 6and convert the movie into a VP6 Flash Video (.flv) and it should work.
Apr 19, 2009 | Sylvania SMPK8854 Digital Media Player
Proform XP CrossWalk 580 Treadmill Logo
59 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Electro Med Services...
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
