Question about HP PSC 950 All-In-One InkJet Printer
When I turn the printer on and try to use it it flashes error b8142b84 turn printer off and on, so I do. Then when I try to print again it does nothing.
  • Anonymous Jan 21, 2009
    got the same problem when returning to the country after 5 weeks away think it may be due to cold will try again when the house gets warm errer code was c00f0401
  • HP Expert
  • 297 Answers
The b8142b84 error isn't documented by HP, but you should check your voltage to the printer. Move the printer to another room and plug it in to see if you still get the "turn printer on/off" message. If printer power up fine in another room, you have a bad outlet, or surge protector at its original location.
Solution to try for the cofo401 is found here:
Posted on Jan 22, 2009
Show the error light
Hi Karthik,
Try this:-
  • Check the paper roll and probably re load it.
  • Turn the printer off.
  • Press and hold the power button and then switch the printer on.
  • Release after the first flash of LED light.
  • The printer prints a test page.
  • Turn it off and then on again and then try printing.
Hope this helps.Thanks!
Please rate this answer.
Dec 11, 2011 | Citizen CTS651 Thermal Printer
Orange Error light is flashing on printer, have tried changing the PHD, all toner is new, have tried unplugging power supply and data cable... still have the flashing error light. Recently tried to do the...
Have you tried cleaning the ctd sensor? I had this same problem, and using a dry cotton swab over the ctd sensor (located on the inside of the front panel) solved the problem for me.
May 05, 2011 | Dell 1320c Laser Printer
HP psc 1310 - gave paper jam and print cartridge error. There was not paper jam and paper jam message went off. My son changed one of the print cartridges, although it still had ink in it. The error...
clean the rubber rollers of the printer and try to print. if it is still having the same problem. reset the printer by unplugging the power cord of the printer while its turn on. then plug the power cord back in. once the printer is on press and hold the power/on button and the size button. when the on button is flashing then release the buttons and try to print again
Oct 28, 2009 | HP PSC 2410 All-In-One InkJet Printer
My Canon i 560 s will not print and this is the error message, I followed instructions, no change, won't print, yellow light flashes ,"Operator error. Press the printer's RESUME button. If this doesn't...
Turn off your PC, turn off the printer. Open the printer and check for paper jams, push/pull the ink cartridge carrier left to right to ensure it also isn't jammed.
Only use a small amount of paper (10 sheets). Too much paper can sometimes block the feeder
Turn everything back on, try again.
Jul 02, 2009 | Canon BubbleJet i560 InkJet Printer
Error flashes
I've read several posts on the "red flashing error light" on the Brother HL-2170W. I have mine hooked to a mac - but I'm sure the pc is the same way. One other previous post said look for a paper jam. Well, there are only a few places to look...and I found no paper jam UNTIL I removed the toner cartridge and looked UNDER the cartridge and VOILA, there was a paper jammed underneath. I removed it and I'm back in business. Normally paper jams when it is almost out of the printer and you can locate it by opening the back of the printer. Well, this one was "sneaky" and hid completely underneath the toner cartridge.
Hope this helps someone else...
May 25, 2009 | Brother HL-2170W Laser Printer
Received the following message when I tried printing - "System Error. The printer failed to print due to a system error. Try printing again. If unsuccessful turn Windows off and reprint." Can you sugg
Turn it off and unplug it for about 30 seconds. Plug it back in, turn it on and try printing a Self-Test (Setup, 2, 5). If this works, try printing your document again.
Apr 14, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Epsom TM-U220 Error Codes
From the manual its probably one of this item.
-printer temp is too high
-cover is not properly closed
-print head is not in the correct position
-paper cutter is not in the correct position
-paper jam
Try turning off the printer, remove the power cable, turn it on again for 5 seconds to reset it. Connect back power cable, press the feed button and turn it back on. The printer should do a self test, turn it off and on again after the self test. It should make the red light go away.
Oct 27, 2008 | Epson TM-U220 Matrix Printer
My canon LBP5200 does all the usual whirring and stuff as if its about to print, when the paper feed normally starts instead the alarm light flashes and the following shows on screen :- Printer error....
The fuser unit is faulty.It sits at the back of the printer and disconnects by unlocking 2 blue levers.reseat it and try again,if not you need a new fuser
Aug 06, 2008 | Office Equipment & Supplies
Error Message problem
Try to find anything that prevents the printer form moving the paper or print head. If everything is fine try reinstalling the printer driver.
If that does'nt work... get your printer serviced.
Oct 18, 2007 | HP PSC 2355 All-In-One InkJet Printer
HP PSC 950 All-In-One InkJet Printer Logo
285 people viewed this question
Ben Johnson
