Question about Speed Queen / 649P3
How do Install 649P3
We previously converted to LP but now need to change back to gas. Is there a manual out there for this?
Cecilware fms40 fryer convert to lp gas
Most NatGas devices will convert to use of LP by changing the orifice.
GRINDMASTER CECILWARE F177A ORIFICE 52 1 16 LP GAS
Oct 05, 2015 | Cecilware FMS-40 Deep Fryer
Looking for the manual, also want to change from LP to NG. Need instructions for same.
To change from lp to Ng the change required is different jets in the burners Nothing more
go to a shop that sells gas cookers. B B Qs and they will have the jets in stock
ask as to adjust the air shroud to keep the air mixture right
Apr 12, 2015 | Grilling
Changed maxitrol regulator to lp to much pressure
If you only changed the gas regulator for use with LP (the regulator located at the connection of the gas service) then you still need to change the orifices for all burners, top and oven. Of course I assume this model can be converted for use with LP. Some models cannot. A new range that can be converted for LP typically includes the needed LP orifices. A card with the LP orifices is typically located at the gas regulator.
May 31, 2014 | Kenmore 72132 / 72134 Gas Kitchen Range
Ho to convert a frigidaire natural gas dryer to a lp gas dryer?
Kits should be available at Sears.com, need to be a certified technician to change it. Involves changing igniter, burner scoop, and adjusting air shutters.
Feb 22, 2014 | Frigidaire GLGQ2152ES Gas Dryer
Gas stove need to switch to propane
Hotpoint supplies the orifices and instructions with each range for converting. It is just that it is hidden, they attach it to the gas regulator. The regulator is near the bottom back typically. Here is a cut out from your use and care manual.
CONVERTING TO LP GAS (or converting
back to natural gas from LP)
This range leaves the factory set for use with natural
gas. If you want to convert to LP gas, the conversion
must be performed by a qualified LP gas installer.
The conversion instructions and LP orifices can be found
attached to the range next to the pressure regulator.
Keep these instructions and the orifices in case you want
to convert back to natural gas.
May 13, 2010 | Hotpoint RGB745 Gas Kitchen Range
Convert back to natural gas
the burner orfices will have to be changed ans pressure reg / some have either /or reg / just turn lever to the fuel you are using . but always change the orfices to gas or lp . blk is lp copper nat gas .. you can probably do it with out the instructions it's very simple .. if the other set of orfice's are not in or on range then order them for your model . ..mm
Dec 12, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
How do you convert the oven to lp gas on ge xl44 range
if this is a new stove need to change the pin in the regulator ,
then need to replace the stove top orifices from gas to l.p.
check under the stove for pieces they tape them under there by the regulator -- that how i found mine under my new jenn air
check the stove companies web site for a users manual also
Feb 19, 2009 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Converting a GE Profile Gas Range from LP to natural gas
GE ships gas ranges set for natural gas, with the LP orifices included, usually on a metal tab held with one screw right near the regulator (where the gas connects to the range). If the range was converted to LP, the person who did the conversion was suppose to put the natural gas orifices back in that holder. If they are missing, comment back on the exact model number and I can look up the part number(s) for you.
Jan 06, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Dryer won't heat
Hello tfulton1963,
The fact that it worked for 3 days and then failed suggests that it is probably something else. You may have a non-resttable thermal fuse that opened or the gas valve itself isn't functioning. Can you see the glow of the igniter when it starts? Are you sure the burner is getting gas from the inlet valve?
These are the basic components to investigate.. Let me know the outcome of these checks and we can get you going again if none of these work.. Regards
Oct 10, 2008 | Amana NDG7800AW Gas Dryer
Speed Queen / 649P3 Logo
24 people viewed this question
Top Speed Queen Washing Machines Experts
Terry Schneider
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you a Speed Queen Washing Machine Expert? Answer questions, earn points and help others
