Only when you can put in the correct unlock code, or the password you used to setup the Apple ID the phone is registered to.
You even can't reset it to factory settings, without the password.
The phone is protected well.
EMERGENCY CALLS
Emergency calls can be made in all device conditions as long as there is any
available network signal. From locked screen conditions press the Emergency
Call button to open the dialler, then dial 000 and press the handset icon to
make the call. In all other conditions press the Home key to return to the
home screen then press the handset icon to open the dialler. Enter the
Emergency number (000 or 112) and press the handset icon to make the call.
make sure the sim card if it has one is all the way in,i know my blackberry did that if the sim card was knocked lose,my iphone will only allow emergency calls when its locked.
You can have the keypad locked by opening the menu and setting in phone settings the time requried to lock the key pad. so after using the pad locks and will not dial any numbers.
the calls to emergency is because of this being active.
Your phone has not been fully registered to by the carrier you're using (AT&T ???) and until you do that, the default "slide for emergency call" display will be there.
■ Lock the keypad
To lock the keypad to prevent keys from being
pressed accidentally, in the standby mode,
select Menu, and press * quickly; to unlock,
select Unlock, and press * quickly.
When the keypad lock is on, calls may be
possible to the official emergency number programmed into
your device.
Enter the emergency number, and press the call key. The
emergency number you have entered may not be displayed on
the screen.
