Question about Frigidaire PLCS389EC Stainless Steel Dual Fuel (Electric and Gas) Kitchen Range
Error code f30
Fault code 30
Why does my kenmore range beep and show an error code every time I open the oven door?
See if this helps...
http://link.brightcove.com/services/player/bcpid1910171499001?bckey=AQ~~,AAABAWGODxk~,hLHEX2tm6AFlgSDzRIBPGX7yjI__nHLT&bctid=1974107068001
Also
Sometimes shutting off the circuit breaker that the range or oven is connected to for 30 seconds will clear the fault, error or function code.
Also
F3 or F30 means that there may be a problem with the oven sensor.
Your oven sensor may need to be replaced.
Jul 08, 2014 | Kenmore Kitchen Ranges
What does the F30 code mean on my Maytag washer?
I just spoke to a repairman who claims he's been working on Maytag washers for twenty years and has never heard of an F-30 error code. He says all Maytag error codes are four digits, and this isn't a real thing. Like I'm lying. While he's saying this, I'm watching the F-30 code flash on my machine. My God, you can't find anybody who knows how to fix anything any more...
Sep 01, 2011 | Maytag MAH6700AWW Neptune Front-Load...
Showing F-30 error code
F30, indicate an electronic communication problem with the washer. Some Duet models are equipped with electronic displays that will read "F30" when this error occurs. Models without displays instead illuminate a given combination of LEDs to indicate an error. In the Duet Sport, for example, when the "Wash," "Rinse," "Spin" and "Cycle Complete" LEDs are are illuminated at the same time, an F30 error is present.
Other comments about this problem suggest "storing" detergents on the top cover. A new, full bottle of Tide caused problems for us. Cleared the top of it, problem solved.
I suggest visit and check this link: Use and Care Guide
Hope helps.
May 16, 2011 | Whirlpool Washing Machines
F30 comes up and the drain basket is empty
F30/31 - Motor Error
If this error occurs then you should try to run the programme again, but a persistent problem will need to be looked at by a professional. A F30/31 error code can indicate a fault with the carbon brushes, drive belt, motor relay or PCB. You can buy spares for your Hotpoint washing machine at many places on the 'net, simply Google for it.
Nov 09, 2010 | Washing Machines
Error codes
hi there
ur error F-30 indicates an open probe connection....
for (F30 or F31) Check resistance at room temperature & compare to *RTD Sensor resistance chart. If resistance does not match the RTD chart replace RTD Sensor Probe. Check Sensor wiring harness between EOC & Sensor Probe connector.
if ur not confident and comfortable abt doing this work... i suggest u call a tech....
good luck and stay safe.....
have a nice day
Jul 16, 2009 | Frigidaire FEB27S5A Electric Single Oven
Fault code of F30 comes on and water goes straight through my WE127E, can you assist? recently replaced the broken drum spring.
The F30 error code will flash when the dispenser motor cannot be driven to its proper position.
* It could have a mechanical failure in the linkage between the dispenser motor and the top of the dispenser.
* Loose wire connection between the machine control board and the dispenser motor
* Failed dispenser motor
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 29, 2009 | Washing Machines
Kenmore elite he5 - error code F30
F 30 code can be reset by un plugging power cord for 5 minutes also pull out the detergent dispenser and reach all the way in to the back there is a small plastic flapper valve move it from side to side with your finger this will rest code f30 and save a tech visit..
Nov 10, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore electric Range 2005
we are baking at 350 and we just received an F30 error and the oven shut off. can you tell me what this means
Nov 04, 2008 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
HOTPOINT ULTIMA 1200 WM72 Error Code
f30 code means there is a problem within the motor curcuit,check connections at the motor and check motor brushes are not worn.
May 05, 2008 | Hotpoint Ultima WF860 Front Load Washer
Kitchen Ranges Logo
15 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
