Question about GE Profile : Profile Spacemaker 1.8 Cu. Ft. XL1800 Sensor Microwave Oven
GE spacemaker xl1800 smoking and burnt electrical smell
MicrowaveSvc
  • 9098 Answers
SOURCE: GE Profile Spacemaker® XL1800 Microwave Oven
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose connection on the control unit circuit board
- bad magnetron or other high voltage part
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should be a very helpful "mini-manual" hidden inside the unit behind the control panel.
Please write back with more details if you need further help.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Dec 04, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: My ge profile spacemaker xl1800 turntable stopped .
It's probably a bad turntable motor or coupler.
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Posted on Jan 13, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Broken handle on GE Spacemaker XL1800 microwave
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Sep 07, 2008
vitg55
  • 78 Answers
SOURCE: My Ge SpaceMaker XL1800 Microwave Oven won't power on any more.
1.Check power outlet for working.
2.If it is than you have broken fuse inside the m/w.
3. To change the fuse you have to disconnect the power to m/w, take the upper grill off, take the screw on top of control panel, lift the control panel up and removed. The 20 Am fuse located behind this panel.
I’m happy to help further over the phone at https://www.6ya.com/expert/vitaliy_f406165329c75ede
Posted on Dec 15, 2008
SOURCE: have a ge spacemaker xl1800 - f3 error
I had the same problem. I removed the grill and opened the control panel as I read an answer from "GENE" on APP (Appliance Pros) that this indicated a short in the circuit board (TouchPad). I was going to replace the faulty circuit board but when I opened the control panel there it was......One wire harness had just came unplugged!! I plugged it in, reassembled and the microwave works again!
Mike
Tampa, FL
Posted on Jan 14, 2009
I have a GE Spacemaker XL1800, no heat and a humming noise.
magnetron problem DON'T KNOW IF WITH FIXING - WOULD LIKE TO KNOW MYSELF
May 02, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Spacemaker XL1800 (JVM1850CF001) This microwave stopped heating and started making a humming noise while trying to cook. I read some possible parts that will fix the problem. How difficult would a megatron...
look behind front control panel. there is a tech sheet. you can trouble shoot this problem, but you may need a voltmeter and an amp meter. it sounds to me like the high voltage transformer is bad or not working. it helps power the magatron. the hum is the mag trying to work, but it doe'nt have the high voltage it needs. this unit new sells for appr. $350.00.
Feb 01, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
In model spacemaker xl1800 no heating but all
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
gfj
Jan 12, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE SPACEMAKER XL1800 MODEL: JVM1860BF001
MAGNETRON, 99% of the time with your complaint
Nov 20, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Capacitor burned out? horrible burnt smell.
YOUR GOING TO NEED A NEW MICROWAVE . the cap may be bad but the real bad smell you have is most likely the HV tranformer , if the magntron shorts to ground there will be a small smell if you dont pick up on that and your microwave is set to run another few mins the transformer will overheat and burn , then the fuse blows and the controls shut down . the end result , you have more parts bad than you have good . if you google " GE SPACEMAKER MICROWAVE FIRE ' you will see your not the only one , its getting to be COMMON . good luck
Mar 08, 2009 | GE XL1800 1100 Watts Microwave Oven
GE Spacemaker XL1800 does not heat. All other functions appear to be working normally, the light comes on and the turntable functions. When turned on, it makes a humming noise slightly louder than normal,...
Possible bad heating element, You should remove the cover of the unit and look at the heating element with the power off. Until you get your problem resolved I would recommend not to even turn it on due to the fact that you are unsure what is going on and you smelt some burnt smell. Just for safety until you fine the problem
Feb 21, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Can not change interior lightbulb
how do I change the little light bulb on the top to take off the cover what do i need.
Please, lvinci@gmnew.com
Feb 01, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE spacemaker xl1800 microwave "burnt paper" smell
Hey
There are several things you can do to help git rid of that smell
First get a mild cleaner with bleach (soft scrub ect!) and clean entire oven inside and try getting that scorch mark off! a little pressure should lessen it ! (there is no filter inside! The plastic inside covering holds smells for a long time! you can also put a cup of white vinigar inside warm on high for 1 minute and leave in overnight!
Please take a second and rate my response
Thank You1
Jan 23, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker XL1800(JVM1850CF001) - Loud Humming noise
You either have a bad magnetron tube (5 or 10 year parts warranty item through GE Factory Service 1-800-432-2737 or www.geappliances.com) or a shorted high voltage rectifier. I think the light being out is a secondary problem.
Dec 18, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker XL1800 first no inside light followed by loud noise
I agree that the light is unrelated. 99.9% chance you have a bad magnetron tube but it is covered by either a 5 or 10 year parts warranty through GE. Call GE Factory Service at 1-800-432-2737 or schedule online at www.geappliances.com
Dec 16, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Profile : Profile Spacemaker 1.8 Cu. Ft. XL1800 Sensor Microwave Oven Logo
181 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
