Dell ispiron mini 10 not charging - Computers & Internet
    Novelist:
    Champion:
  • 233 Answers
The solution to your problem lies in one of the following three areas:
1.) Your dell mini 10 charger is faulty and is therefore not able to pass power to your laptops battery.
2.) The charging connector on the laptop has come loose from the contacts. Therefore a bad connection.
3.) Your battery is faulty.
I think possibility 2 is the most likely, although you will have to test possibility 3 by removing the battery and plugging in your charger and seeing if the laptop powers on.If it does power on then that rules out possibility 1 and 2 leaving a faulty battery.
Posted on Jan 10, 2013
SOURCE: HD laptop Dell ispiron 2200
What is the main reason of getting 150 gb? would you mind to use an external drive. there are those of 234GBs if you don't mind.
Posted on Apr 21, 2008
gpetti2009
  • 92 Answers
SOURCE: WHITE SCREEN ON DELL ISPIRON 15
If the screen works and then goes to white you can check a few thing if you have computer knowledge the lcd has a few connections 1 at the motherboard 2 the back lite which is the white light that youare seein go to this site and look at the diagram to repair Lcd http://www.laptoprepair101.com/
if you have a loose connection it is and easy fix but sounds like the inverter the run about $15 to $25 on ebay Good Luck.
Posted on Aug 08, 2009
parrotheadpc
  • 2600 Answers
SOURCE: i plan on going to the Philippines, can i charge
I believe the power system there is different and unstable at best. Get yourself a computer travel kit that has all the different charger adapters for what country and power grid you are going to be in. I know I was in Macy's the other day and they had a decent one that had a multitude of adapter tips and voltage settings for under 30 bucks.
Posted on Sep 14, 2009
  • 3940 Answers
SOURCE: My dell ispiron 10 1.6GHZ is running at 783MHZ
The system is designed to conserve power unless an application demands more (Intel Speedstep)
Try disabling Speedstep in the BIOS
Posted on Jun 08, 2010
  • 2567 Answers
SOURCE: dell ispiron 1420 new deckcell
First of all, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether.
Posted on Sep 18, 2010
Testimonial: "fixed my oroblem"
Dell inspiron mini 10 will not recognize new battery
THIS IS MOTHER BOARD PROBLEM.
BUT, TRY LOOK FOR SAME LAPTOP AND TRY OLD N NEW BATTERY.
Oct 17, 2012 | Dell Inspiron Mini 10 Notebook
Can't install bluetooth driver on my laptob dell ispiron mini 1012
Kindly download the latest drivers from Dell support website.
Jul 18, 2011 | Dell Inspiron Mini 1012 Netbook...
Jun 08, 2010 | Dell Inspiron Mini 10 Notebook
How do you turn wifi on with a dell ispiron 1525
You can turn your Wireless On/Off on the edge right hand side of the computer. Its ON when its on the side with the LED light which is the Wi-Fi Catcher. Please comment if the information has been helpful. Thank you and regards.
May 11, 2010 | Dell Inspiron 1525 Laptop
What is procedure to recharge the battery on a dell mini 10
When the AC adapter is connected to the system (Either running or off) the battery should charge.
Sep 25, 2009 | Dell Inspiron Mini 10 Notebook
Laptop will not come on
If you have good ac to connector and still no activity(no beeping or lights)  need a new mobo.  Try with no battery in.  Else call dell for warranty or take to shop to replace motherboard.  Dell offers extended warranties.  I hope you reupped it!  I change 5-10 Dell mobo's a day.
James Mac
Sep 07, 2008 | Computers & Internet
You have to look for a ATA-6 5400 RPM hard drive.
e.g. you could use the Western Digital Scorpio 160 Gb
If you need more help, just post some info back.
Apr 21, 2008 | Dell Inspiron 2200 Notebook
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
