Hi, I have a Hotpoint Aquarious washing machine (UK). It has developed a leak and seems to be overfilling however it does stop filling. Hope you can help.
    Problem Solver:
  • 10 Answers
I can not see the entire front of your machine, are you sure its over filling? I use a front loader also, at the bottom of my front loader is a small door, when I open it there is a drain pipe inside, sometimes the drain needs to be cleared. I am hoping this is your issue and that this is a quick fix for you.
If not, you can check the back of your washer where your water hose connects to washer. Inside the hook up is a screen (on your washer) sometimes these become clogged due to mineral deposits in the water.
Posted on Jan 07, 2013
  • 27 Answers
SOURCE: HOTPOINT aquarious extra
whare the option buttons are if you number them 1 to 5 from top to bottom if led 2 and 4 are flaching this is a time out draining and you will need to check your waste hose for twists traps and kinks also check Filter if there is a user servicable one on the applionce and check plumbing. This is a comman fault and if you get hotpoint out to it even if it is only a day old they will charge for the call out as it is classed as user error or faulty instalation this works on all WF,WD & WT modles with 5 option buttons on the left habnd side the applionces with digital displays will show F-05 insted but it all means the same
Posted on Feb 22, 2008
  • 1462 Answers
SOURCE: Hotpoint Washing Machine Model # VBXR1060T4WB Filling Problem
problem could be the pressure stat which is a switch which detects water level or the pipe leading up to this switch or the air chamber the pipe goes to.
take top off. locate the pressure switch - has a small diameter pipe going to it. remove pipe and fit a similiar one. put on fill and pressurise this pipe by mouth and water fill should stop. if it doesn't, then switch is faulty.
if this is ok, examine carefully the small diameter pipe for splits and blockage. also check the air chamber for build up of gunge
Posted on Nov 16, 2008
  • 53 Answers
SOURCE: error code F-05 for hotpoint aquarious washing
your pump/filter/outlet hose is blocked. clean it all out with the power off.
Posted on Oct 30, 2009
  • 86 Answers
SOURCE: Hotpoint Aquarious WF210. Machine stops mid
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} For Hotpoint, Creda and Indesit error code definitions use this link. This will give you some idea as to where the fault may be.
Posted on Mar 06, 2010
  • 1382 Answers
SOURCE: Door will not open
Remove the top cover, and release the door catch from inside the washer, you will probably need a screwdriver or similar to do do this.You will need to replace the door catch and spring, and possibly the door lock, as it may break when you force the door open.
Thank you !!
Posted on Jun 28, 2010
Hotpoint aquarious 1200, not completing a washing cycle
where does it come to a stop
five mins in to progam or at rinse
Jan 13, 2014 | Washing Machines
Lights flashing
temp solution, switch on and off at wall socket with on/off switch in and out, untill only on/off switch is lit, then use wall switch for power on off. worked for me.
Jul 13, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aquarious WF210. Machine stops mid cycle...Reduce Creases and Time Saver lights flashing. On-off flashing quickly. Any suggestions ?
Mar 06, 2010 | Hotpoint Aquarius WF210 Front Load Washer
Washing machine overfilling
Hello
Welcome to fixya.
I'm Huuum and happy to assist you,
You said, your washing machine overfilling.
please give us more information .
What is the manufacturer and model number of your problem washer?
Thank you
Sep 29, 2008 | Washing Machines
WF540 - Won't work and rinse hold and wash enhance lights flash?
Hi ya, just a quick suggestion, have you cleaned the filter on the front of your machine?? My machine did this and it was only when i cleaned the fluff and the 5 pence pieces from this filter it stopped, Hope it helps
Dobby
May 11, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint aquarious hault code
fault can be due to more than one cause. take top off machine locate pressurestat - usually a round device with anything from 3 to 7 wires to it and a small diameter tube to it. check no split or crack in tube and that it is not blocked. the small diameter hose goes to an air chamber. often this air chamber gets clogged especially if you use liquid detergent. if clogged, clear it with hot water. pressurestat may also be faulty but these are a reliable device. to test, remove small dia tube and attach your own tube. with machine in fill mode, blow into tube and you should hear a click and water stops ps i live near truro
Apr 17, 2007 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Ultima VTD20/VTD00
possibly it is overfilling - the pressurestat has a overfill function which turns on the drain pump. how high does the water level get when this happens?
Mar 25, 2007 | Hotpoint Ultima WF860 Front Load Washer
Washing Machines Logo
66 people viewed this question
Top Washing Machines Experts
