Question about Dell Dimension 5150 (DIM515MIN) PC Desktop
PC no longer detects mice
I have just replaced a faulty ram stick inside this old PC I was able to boot up fine but the PC didn't detect the usb mouse that had been used with it up until now. I rebooted into the setup menu and was able to confirm that the keyboard still works and all for RAM sticks are working. I tried using another mouse which also didn't work and confirmed that that mouse worked on another computer. As far as I can tell it is only mice it has stopped detecting. When the PC boots up it enters a profile select screen and I can't seem to get to the desktop using the keyboard alone. I have tried a few other solutions I found through a Google search but nothing has worked yet. So I am asking here, hopefully someone can provide a solution. Thanks in advance for any help.
    Problem Solver:
  • 11 Answers
You said that you are using a USB mouse, when you tried another mouse on this PC was it also a USB mouse, or one of the more basic mice you plug into the tower? I suggest trying to use one of these mice so that you may have a working mouse, and then if that works use it to try to get at some of the input settings that could be in need of adjusting.
Hope this helps some.
Posted on Nov 12, 2013
5 Suggested Answers
mbase213
  • 728 Answers
SOURCE: RAM installation
Hi hunter555,
First off, you've done a lot of work for nothing. What you need to do is put back the new memory. When the Dell Bios boots, it confirming that it has detected the new memory. What you need to do is hit the F1 key to reboot and continue on to the XP installation. When you open the case, it will say the same thing. Don't worry about it, it's only confirming that the case was opened. Typically, I shut off the case intrusion detection, only because I'm always adding things to the machines and it's just a extra step I have to take to boot. However, it's good to know that your bios is confirming that you've opened the case, and that you've put in new memory. You want to make sure that the setup recongizes the entire memory in the banks. So, go to the system information page and make sure that it's reading the original and the additional memory 256k you added. Otherwise your done.
Good Luck
Mark
Posted on Jan 14, 2009
  • 22 Answers
SOURCE: dell 2400 ram upgrade problem
RAM can be finicky so first test all memory slots with a known good stick (your 512MB). Make sure you're starting from a complete power down and you get a POST beep (hopefully your system is set up to beep when it powers on) and everything loads up all the way through to your OS.
Once you do that with all your memory slots test with the new stick by itself in all memory slots. If neither of the memory slots work with the new stick but you verify that it works in another system you should then check your BIOS settings and RAM timings to ensure compatibility with your stick. If you can't find the timing on the RAM stick itself, look up the manufacturer's part number for the information.
Posted on Feb 03, 2009
  • 3 Answers
SOURCE: Windows XP CD cannot be detected in Dell Optiplex gx260
Your optical drive might be dirty or bad. Try an official Dell disk to see if it will read it, especially a Dell drivers and Utilities disk. Also try a boot flash drive or boot floppy(since your system is a older) to get the system up. If your system comes up any of those ways, I would try a disk cleaner. If that doesn't help, then you probably have a bad cd drive. You could also look in bios setup to make sure the bios is showing your cd drive. It should list it there somewhere. Probably on the first page.
Posted on Feb 08, 2010
mouse_kil
  • 93 Answers
SOURCE: Keyboard & Mouse not inputting..Dell
Check that batteries are charged and installed properly.--make sure driver disc is installed if applicable- check instructions as some wireless suites need you to push a small connect button to initialise them . Also try shifting the usb conector into another USB port if it is notm getting reconised.
I hope this helps
Andrew.A
Posted on Apr 09, 2011
How to fix no boot device on emachines e442 for free
First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Sep 09, 2012 | eMachines E442 E442-v133 15.6" Notebook...
Computer does not boot up
if you can be more specific about the problem, maybe we can help you out.... is the psu fan turning? what about the led in front of your case? or they're working just fine but the lcd didn't display anything? or there's only the cursor blinking in the screen?
try to get inside the bios setup by pressing f2 or del button.. check your hard drive... is it detected by your board... go to the boot order, make your hard drive as your first/primary boot order... then save by pressing f10. if you still having the problem, re install the window.... hope this will help
Jun 17, 2012 | Dell Dimension 2400 PC Desktop
Gaming mouse cannot detect
try to plug into every usb slot... see if your mouse can still work or not... but i recommend you to bring that mouse and claim for it warranty....
ps; if you plug your mouse into the PS/2 port, u need to restart your pc. i hope this will help you.
Jun 13, 2012 | Computers & Internet
I have a disk crash on an ASUS computer, 3 years old. The Disk is a SATA. How can I get my machine to boot ?
First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty. Next - to check if the harddrive is faulty, remove the hard drive and insert it into an USB hard drive adapter and connect it to a workingcomputer's USB port. If this computer cannot see itas an external hard drive and you cannot open the various folders and files,this confirms the hard drive is faulty. Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
Aug 12, 2011 | ASUS Eee PC 900 Notebook
Not detecting keyboard with computer
hi ''' if your keyboard is brand new and you just bought it on a store so it is guaranteed good, then you tell me when you connect it to your PC it does not work '''' try to do it again, shot down properly your PC and then connect key board , after boot wait for it to be detected
Jul 12, 2011 | HP D8597A Keyboard
When I turn it on it doesn't boot, it makes a beep every 10 seconds or so, and the moniter says no signal. I dusted out the inside and it worked fine for a few weeks but now its not working again. I tried...
It normally means that it hasnt detected ram or some other similar piece of hardware, try making sure all your ram sticks, cpuand heatsink and hdd are connected properly
Dec 12, 2010 | E-Machines eMachines Desktop PC
Computer will not boot up, replaced hard drive as only 20g with a 40g was working fine when bought, put in win XP disc but nothing showing on screen. Tried another graphics card but to no avail. Intended...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
hope this helps
Nov 16, 2010 | Computers & Internet
Asus p5 vdc-x motherboard not recognizing ddr2
Ok i am just guessing here
maybe your motherboard does not support
ddr2 rams and hence it wont boot up as it does not detect any ram in the slots......
try to boot with one old and one new ram (ddr and ddr2) and post the result
are you sure whether the ddr2 ram is supported?
Jun 30, 2009 | ASUS P5VDC-X Motherboard
External USB Drives No Longer Detected
There are two possibilities:
The Mybook USB/ATA controller board is faulty.
In this case you can simply take apart the enclosure and mount the disk into a new enclosure. WD Mybooks are SATA, but double check the hard disk connector to ensure.
The hard disk inside is faulty.
In this case repair may be expensive. You need to locate a data recovery facility with a 'clean room' , the cost is usually more than $800.
If this happened after a power surge, then the problem is most likely a faulty controller board.
If instead you have dropped the hard disk it is possible an hard drive failure, in that case repair will be expensive.
A replacement enclosure will stfrom art about $20 on Ebay or Amazon, and must not necessarily be WD .
Check if your disk is Sata or PATA (IDE) before buying the enclosure.
Apr 22, 2009 | Western Digital 320GB MyBook External USB...
Dell Dimension 5150 (DIM515MIN) PC Desktop Logo
43 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
