I have to hold the start button in in order to keep it running
  • 27,725 Answers
The switch might be faulty also could be dust clean your computer of all dust .
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules
Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards.
Have a close look at the power switch for secure dust free connections you might even remove the switch to have a close look the replace it sometimes just cleaning and replacing things to there original positions gets them working again
Posted on Jan 07, 2013
Can't get my iPad to turn on! Have tried pressing the button for a long time, still not turning. What else should I do to get started?
In order (stop if one works):
1. Recharge at least an hour from power adaptor rather than USB computer lead.
2. Reset by holding down Sleep/Wake button on top right of tablet while at the same time pressing down home button. Keep both depressed 15 seconds. If slider appears or screen dims, keep pressing till Apple appears.
3. Restart (display not working) by pressing and holding Sleep/Wake button till power off slider appears. Drag slider to right. Wait 2 minutes. Press and hold Sleep/wake button till Apple appears.
4. Recovery Mode. With device powered down, hold sleep/wake button down and drag slider to off position. Then plug USB into a computer (do not have usb cable connected to iPad yet) running latest version of iTunes. Hold down Home button while plugging USB cable into iPad. Keep Home button down until Connect to iTunes appears. If does not appear, start Recovery Mode procedure again. When Lightning cable, arrow, and iTunes appears, release Home. Click OK to restore to factory defaults (erases data). Restore data from earlier backup. (Summary of method from Phone Cruncher site.)
Aug 28, 2017 | Tablets & eReaders
Dryer won't stay running without holding down the start button
It may be the centrifugal switch on the motor. The push button starts the motor and as the motor spins up to speed the centrifugal switch closes to keep the motor running. Hope this helps.
Jan 02, 2014 | Admiral Dryer. 6.5 cu. ft. Electric Dryer...
My start button on my gas dryer
That is VERY DANGEROUS.............I would NOT recommend doing that under any circumstances.........it could be a safety device that is keeping the start button from working in order to keep it from shorting out.............
also, it could be the start button itself but, it is not worth the chance that it could catch fire.
Jul 15, 2010 | Maytag PYE2300AY Electric Dryer
We have to hold the start button down when for
if you have to hold down the start button to keep it running then the motor is shot-mike
Jan 29, 2010 | Kenmore 63952 Electric Dryer
Unlock ipod touch
just plug it into your computer and sync it up with itunes. once it's done, unplug your ipod and it will be unlocked.
if you haven't installed itunes yet/synced it to any computer then you will have to do a full restore in order to get it back to working order. which means losing any information, pictures, videos, songs, etc on it. it will revert it back to factory setting and have only the apps it had when it was first taken out of the box.
2 i've found that you can accomplish this:
- Start by plugging the iPod touch into a computer then hold down the power button for about 5 seconds until you see the red slider button to power it off, slide to power off the iPod touch. Then press and hold both the power button and the home button at the same time until you see the Apple logo, then release the power button but keep holding in the home button. Hold the home button in until you see the iTunes logo on the iPod touch, then let go of it. You can then restore your iPod using any computer but keep in mind that you will lose everything.
- Make sure your iPod Touch is completely turned off and unconnected from your computer. Hold down the Home button, and connect it to your USB cable. It will automatically turn on when you connect the cable. Just keep holding the Home button until the Connect to iTunes logo appears.
Sep 23, 2009 | Apple iPod touch
PUSH TO START BUTTON DOES NOT WORK
its not the start button check the door switch if broken or actuator is broken you get the results as you dry
Aug 21, 2009 | Kenmore Dryers
Press start button and dryshuts off when start button is released
There is a switch assembly on the motor that activates when the motor is running. Centrifugal switch. It keeps it running when you release the switch. That is where to start. Eric
Jun 11, 2009 | Kenmore 74992 Gas Dryer
Kenmore 73954 : Only runs when the START button is continuously pressed
The start button starts the motor heater and energizes a relay that latches closed to keep the motor and heater running untill the timer switch or door switch cut the power to the relay and the relay opens.
The latching relay has failed or disconnected
if all the cables are attached to the relay
replace relay
not an expensive item, usualoly good for 10years
dryer circuits look like this, the start switch and relay are drawn just to the right of the motor, this diagram has no relevance to the physical position of the parts
Aug 22, 2008 | Kenmore 63942 Dryer
It won't start now!
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted. http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe You need to put the device into "recovery mode" before you run the tool. - Turn the device off (hold power for 20 seconds) - Slide the hold switch into "hold" position. - Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer. Then run the recovery tool. Select format when prompted. Best of Luck.
Sep 22, 2007 | SanDisk Sansa e260 MP3 Player
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
