Question about Pool & Spa
My jandy aqualink freeze protection goes on every night and can't be deactivated. I live in California so it's never cold enough to freeze my pipes and I am spending a fortune on electricity with my pool pump running all night. I tried lowering the freeze protection settings but that doesn't help. Can I just cut the air temperature sensor or cover it up? I've tried everything else I can think of. Thanks
    Top Expert:
  • Pool & Spa Master
  • 7,361 Answers
Go to system set up freeze protect and un high light or turn off
Posted on Oct 30, 2017
4 Suggested Answers
  • 125 Answers
SOURCE: Aqualink is running in freeze protect, however pump is not. 20 de
Trouble Shooting Guide
Posted on Mar 04, 2009
  • 990 Answers
SOURCE: Freeze protection is activated on
You don't adjust this. You will need to replace the air sensor. You can get the sensor at or through any pool shop and it is simple to replace. You will find it hanging under your box by the equiptment, or somewhere close in the shade. Follow the wire into the box and find the terminal block it screws into. You will need a tiny flat screwdriver for this. Remove the old one and install the new one, close the box and your done.
Posted on Sep 04, 2010
  • 10515 Answers
SOURCE: I have a Jandy Aqualink
Since the controller tells you the sensor is shorted there is a temperature sensor inserted into most likely the return side of the pool plumbing has a small wire. A nut holds the sensor in place on the plumbing side and the wire connects to the board via a plug. The sensor is a thermistor also called a thermal resistor whose resistance changes with temperature and tells the boards circuits what the temp is. If you go to the Jandy web site you can get the part number and replace it. If its warranty have them do it.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Jul 09, 2011
Freeze protection temperature in wrong
go into menu then find freeze protect it will ask which auxillaries to be selected select with an x in front then set temp for freeze protect
Mar 19, 2014 | Pool & Spa
Aqualink freeze protection
go into system set up find freeze protection highlight what pumps and accessories you want to protect and what temp to activate
Jan 17, 2014 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
How do i remove freeze protect from my hand held device
go to system set up find freeze protect any aux that is checked un check and that will un freeze protect it
Dec 10, 2013 | Jandy Aqualink Pda Ps4 Wireless Handheld...
How do I remove item from aqualink rs4 freeze protection
go into system setup go to freeze protect un highlite what you dont want to go on
Feb 01, 2013 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
I've got a Jandy PDA, PS4. How can I set the Freeze Protect below 34 degrees?
It doesn't set below the freezing point. That is exactly the point of the minimum setting of 34 degrees - just above the freeze point. If it would set below that temperature it would freeze.
Jan 25, 2013 | Jandy Aqualink Pda Ps4 Wireless Handheld...
Freeze protection interrupts spa operation in cold weather
the filter pump is used for other features during spa use disable the freeze protection but turn back on after using spa
Jan 01, 2010 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Usig/overriding freeze protection on a pol/spa filtering system
Any entry into SERVICE mode from the outside panel will override a freeze protect. Be sure to put it back to AUTO in order to resume freeze.
Nov 24, 2008 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Understanding how to use spa with freeze protection on
freeze protection will always be on. when you're done using the spa just push the heater/spa button. it will turn off. when ever the air temp drops below 37-39 degrees the air sensor will tell the system the it's getting cold and it will kick on the pump. you can change the it under settings menu if you want other pumps to come besides the filter pump
Nov 22, 2008 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Pool & Spa Logo
67 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
