No sound coming from reciver checked cables and wires and they are all good
    Genius:
  • Audio Player... Master
  • 1,054 Answers
What brand/model #
Posted on Jan 07, 2013
Reciver is going to protection mode and sound turns off
is some speakers is defective, or not present (connected), check all cables
Jun 06, 2010 | Harman Kardon AVR 340 Receiver
Radio come on but do not recive or put out no sound
There is not enough information here to solve your problem but I can give you some places to start. Check your Mic something as simple as a broken ground wire could cause this. A quick check to see if the s meter is moving with signals could tell you if you have signal coming into the radio. Try another mic do some further diagnostics or seek professional help. There should be a CB shop around near you if not look for one at a truck stop.
May 17, 2010 | Galaxy Radios DX-33HML 40-Channels Base CB...
Pioneer inno will not recive xm singal
Are you still having this problem? Sounds like you just aren't getting a good signal. Antenna is not properly mounted, not getting good singal.
Or, the antenna and/or cable is damaged.
Apr 02, 2009 | Pioneer XM2go Inno Satellite Radio...
Having troulble getting sound from playstation3
hi my first going at doing this -
have you tried adjusting the sound settings in the ps3? i have found that if you set that right (ie hdmi) they you should solve this issue
Jan 13, 2009 | Denon AVR-3806 Receiver
Tv
The changeover only effects those that use either rabbit ears or a rooftop antenna. It sounds like you have cable TV which will not change. No converter box should be needed if you have cable or satelite.
Dan
Jan 06, 2009 | Televison & Video
Connecting to surround sound system
Hi to connect your ps3 to your tv all you would need is a hdmi to hdmi connector which would mean the sound would come straight out of your tv. The sound comes directly out of the hdmi cable. If you want to connect the ps3 to an external reciver you might want to get an AV reciver with HDMI inputs. This would connect to your tv and you can switch channels to different sources connected into the receiver, also they come with very good seperate speakers so you wouldnt have to use you telly speakers and you can connect your directv box into it aswell.
Alternatively you can connect the audio phono outputs from your AV multiout connector on your ps3 (the cable should be provided) to a seperate sound system with phono AUX inputs, these are found on most soundsystems but check with whoever your buying it from. But this means that you cant use the HDMI output of your PS3 for video just the AV multiout video signal (which is a bit rubbish, so I suggest the latter solution.
Hope this solves your problem
Rob
Nov 26, 2008 | Audio Players & Recorders
Can't get audio via optical port.
ok, i think the problem lies with the tv, there must be a setting in the sound menu to use optical as sound out, as the sound will be via the HDMI cable, i applogise if you have checked this.
Sep 09, 2008 | Sony BRAVIA KDL-40V3000 Television
Theres no sound coming out-does this package have all the wires or do i have to purchace more? rca souround sound system ,model rt2870
i dont know if you have found a solution yet but this is what i did i bought a optical digital audio cable that is supposed to connect to your direct tv reciver but you connect it to your tv and to the rca and there will be sound
Aug 24, 2008 | Audio Players & Recorders
No volume
Protect is on because one of your speaker's or wires is shorted out. It comes on to protect the amp from frying, check ALL of your wiring and speakers for shorts to ground, NONE of the speaker wires should go to chassis ground only the stereos negative (-) speaker termina.l
Checking your speaker is easy, take a (D) cell battery and a couple of wires and connect the wires to the speaker, you should hear a click if the speaker is working properly. Good Luck
Leadispenser
Jun 10, 2008 | Kenwood KDC-MP235 CD Player
Direct tv cable
ok if its only the rf cable and the ac cord yes you can do it your self.you have one cable out from the sat reciver going to the dish. Find an area that the pooch didnot chew through cut off the bad part of the wire. find the wire that goes to the tv set. if its the coax disconnect from the reciver on both sides and go to the store and buy a new cable (unless you have coax wire and know how to put on f fittings) also while your there buy a small extenstion for the other cable you cut. also your gonna need a a female barrel connector as we;ll as an rg6 type rf fitting for the end you cut. have the guy at the store explain to ya how to put on a f fitting. If the ac cord was chewed buy a simple cheap extenstion cord too. Go home and first put back on the cable you took off the output of the sat reciver and the other end to your tv set. then put on the f fitting the guy explained to ya how to put on and then install the barrel connector then the short extention wire to the other side of the barrel connector then the other end of the rxtenstion cable to the sat output. Now if the power cord is chewed im surprised the pooch is not fryed!!!lol Simply cut off the bad part take the extention cord and cut of the end you dont need take off about 1 and a 1/2 inches of the insulation on bothe parts(reciver and cord) twist together and tape separatly or use wire nuts on them . then you are good to go. BUt one more little thing are you using video cables between the tv and the sat. reciver?? well why didnt you say so LOL simplyu pull out of both ends and go to rat shack or something like them and buy an inexpensive pair of cables and remeber yellow is always video red is alway right audio and white is left audio Hope this clears things up for ya.!!!!
Apr 02, 2006 | RCA DRD450RG DirecTV DTV Receiver
14 people viewed this question
 Grubhead
Grubhead
