Question about Sony Televison & Video
Sony KF-60DX100 blinks 6 times - Sony Televison & Video
circuitcity
  • 137 Answers
SOURCE: Sony KF-WE50
Hello Failrlane.
You have a bad thermal fuse. You must remove the back cover in order to fix this unit. The thermal fuse can be found near the lamp housing. part number for kit: A-1137-954-A
Best regards
Circuitcity
Posted on Jan 04, 2008
welcomejee
  • 10594 Answers
SOURCE: Sony Grand WEGA KF-50WE610 LED blinks 4 times
4 times blink shows Temp Error and requires temperature sensor replacement in Sony KF-50WE610 TV
Posted on May 21, 2009
  • 115 Answers
SOURCE: kf-60xbr800 indicator blinks 5 times
5 indicates lamp ballast failure p/n 1-468-510-15 . but thats not always correct. sometimes the tv doesn't detect it correctly and it's just the lamp XL-2000U p/n A-1601-753-A .
Posted on Sep 28, 2009
welcomejee
  • 10594 Answers
SOURCE: Sony Wega KF-42E200A Projection Bulb
New bulb is just fine.
3 blink shows that lamp cover after replacement of bulb in TV is not fixed properly or not seated well in its position.
Put new bulb and carefully place back lamp cover in its position because lamp cover will press tinny safety switch inside that will send signal to system control of TV that lamp is installed properly.
Turn On TV and get vivid picture of Sony.
Thanks.
Posted on Oct 17, 2009
  • 3 Answers
SOURCE: I have a sony KF-42WE610. When I go to power it
More than likely it is the G1 board or Thermal Fuse. I replace the thermal fuse and it is still giving me the 6 blinking red lights. Thermal fuse is $40 and cheapest G1 board I have found on-line is $120. I am about to pull the trigger on the G1 board and give it a shot.
Posted on Mar 04, 2010
Sony Grand WEGA KF-60XBR800 Service Manual
Lamp/Bulb A1601-753A (XL-2000U) .
http://www.shopjimmy.com/dlplamps?tv_brands_select=Sony&tv_models=Sony+KF-60XBR800
Apr 29, 2014 | Sony Grand WEGA KF60XBR800 60" Rear...
No tv red blinking lights
Blinking of standby light are fault indications. How many times the standby light blinks at a time. Count it, and inform me.
Sep 02, 2012 | Sony FD Trinitron WEGA KV-30HS420 30" TV
KF-60DX100 HAS ROUND CIRCLE IN MIDDLE OF SCREEN
optical engine issue, not an easy fix due to cost. Contact sony and see if they will comp you the part. Then have a local guy put it in for you
May 03, 2012 | Sony Grand WEGA KFE50A10 50" SDTV LCD...
Sony LCD Model KF-60WE610 lamp was replaced and then it shortly after stopped turning on. Blinks Green 6 times then Red 6 times Please help!
For Sony Model KF-60WE610, KF-50WE610, and KF-42WE610, the Diagnostic Code of power light indicator flashing 6 times green, then flashing 6 times red (6 red etc), means you need to replace part number A-1302-272A G1 BOARD, COMPLETE. See Sony Service Manual, 4. Chasis-1 at part Ref no. 103. The Power Board sits vertically in two slots on the left side of the electronics board. 4 wire connectors to remove when replacing. This component fits all 3 KF models listed above.
Jun 22, 2011 | Sony Grand WEGA KF60WE610 60" Rear...
I HAVE THE SONY GRAND WEGA MODEL# KF-50WE620 WHEN I HIT THE POWER BUTTON IT BLINKS GREEN 6 TIMES THEN RED 6 TIMES AND WILL CONTINUE TO BLINK RED 6 TIMES OVER AND OVER
A 6 blink error code on this model is letting you know that your G1 board is not putting out your +17 volt supply. You can inspect that circuit if you are experianced, or just swap out the board.
Apr 01, 2011 | Sony Grand WEGA KF-50WE620 Television
My sony kf-60dx100 has double image RED COLOR..What can be wrong?
The convergence is off. If you can't adjust it from the settings then the board itself is off - refurbish it. Here's the kit for it
http://www.tvrepairworld.com/sony_repair_kits
Oct 11, 2010 | Sony Grand WEGA KF50WE610 50" Rear...
May 21, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Sony kf-60dx100 convergence
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 22, 2009 | Sony Grand WEGA KF60DX100 60" Rear...
Sony kf-60we610 stand by blinks 5 times
Hey there,
I've had my Sony KF-50WE610 for approx. 4years now and have just experienced the prob you described (though I didn't think to count the number of red blinks). I called Sony TV technical support (888-772-7669, #3 for TV/digital cameras, #1 for TV, then #1 again I think). They said that if the power/standby light blinks 5x, that means there's something wrong with the lamp driver and service will be required. Needless to say, I better go home and count my red blinks! Good luck, I hope this helps a bit. Have a happy and safe holiday!
Dec 09, 2008 | Sony XL-2100U Projector Lamp for...
Televison & Video Logo
41 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
