Question about Lexmark X5470 All-In-One InkJet Printer
Lexmart X547O Dead !
Power to machine.
No function at switch on button.
  • 1 more comment
  • John Quinn
    John Quinn Jan 22, 2009
    Hi Sanurulz
    I have tested the adapter output and have power coming from it to the machine.
    Got the on /off switch mother board out, and am trying to check switch, but it appears there is power there too ?
    It has got me bamboozled !
    John.
  • treeniap Feb 08, 2009
    I just got the X5470 printer back out of the box and it is dead!
    Power block has power and the little green light, voltmeter reports its at the 30v it should be. So power seems to be going to the printer.. And It worked fine a few months ago when i put it away.
    But now it is completely dead!?
    Any ideas?
  • GGiraffe1 May 18, 2009
    The printer was working fine this morning, then I accidently unplugged
    the adapter. When I plugged it back in, no power...nothing. After
    trying to plug and unplug for a while, I noticed the red light under
    the ink cartridges was on, but no other power. I took the adapter down
    to a battery store, which said the adapter was fine. Great! But how do
    I get power back to my printer? What can I check? How can I fix this at
    home? Any ideas?
  • Lexmark Master
  • 684 Answers
In this case check whether the black adapter which goes inside the Printer does have a light on it and should be a bit warm if it is there is a problem with the Printer if it is not there is a problem with the Adapter............
Good Luck
Posted on Jan 22, 2009
I replace my machine for fuser flim unfortunately the screen shows 'E000000' How do I correct this error code?
  1. Try first to clear the error
    clearing the error may not fix the fault
    Press the *with a circle around it then press 2 and 8 at the same time then press *again /press copier touch button/function/clear/error/ok button then switch off m/c on hope it works
    also:
    Additional Functions: Click the Additional Functions button once. Do not hold down.
  2. Two and Eight Buttons: Click the 2 and 8 buttons at the same time once.
  3. Additional Functions Revisited: Click the Additional Functions button once again. Do not hold down.
  4. Copier Button: The System Management screen will open. Click the Copier button on the screen.
  5. Function Button: Click the Function button at the top of the screen.
  6. Clear Button: Click the Clear button on the screen.
  7. ERR Button: Click the ERR button to highlight it.
  8. OK Button: Click the OK button at the bottom of the screen.
  9. Power Off/Power On: Power the unit off and back on using the switch on the side of the unit. The error will be cleared.
  10. Restart eCopy:Once the unit is back up, restart the eCopy machine.
    https://www.question-defense.com/2008/11/10/canon-imagerunner-error-code-reset
Apr 14, 2016 | Canon imageRUNNER 2520 Laser Multifunction...
Why is my indesit wixxe 127c dead
If power is getting to the machine and you have verified this, the programmer might be the issue... it usually is.
.Please be cautious as regards safety
Good Luck
Jun 10, 2015 | Indesit Washing Machines
Model bizhub 36...
There is only one button to turn ON the machine Model bizhub 36.If the button is ON and machine is dead then it can be the problem with power supply.Replace the power cord and then check.
Mar 07, 2015 | Office Equipment & Supplies
ON button is "dead",stuck "in".
If the switch under this button is jammed in the "ON" mode it will be impossible to isolate the function it controls. You may be able to live with this, if it means you can still use the machine as you prefer.
BUT if you want to fix it, it may mean that you have to have the switch panel front, and/or the circuit board behind it replaced.
Poppa
http://www.cdbaby.com/cd/poppamadison
Aug 22, 2013 | LG WM2277H Front Load Washer
Does the Lexmart 1100 Printer need operating software?
You likely mean LEXMARK. The printer will function without software other than what is in internal to it (firmware). If you want to print from your computer, you will need the print driver installed.
Apr 12, 2013 | Lexmark Color JetPrinter 1100 InkJet
Child lock is stuck on and machine won't start
Does this help?
If you wish to prevent small children or pets
from climbing into the machine, you can
deactivate the automatic door opening
function.
1. Turn off the machine using the main power
switch.
2. Press the Door Open button while
simultaneously pressing the main power
switch. Release the buttons.
3. Press the Key button and the red field goes
out. Automatic door opening is now
deactivated.
4. Press the Start/Stop button to save the
setting.
If you want to reactivate the function, follow
the instructions above, but when you press
the Key button (point 3) the red fields light up.
Store the setting by pressing the Start/Stop
button.
Do let us know if it does
regards
Feb 01, 2011 | Asko W640
Power switch does not turn computer on
If the switch has a (O) and (I) on it ,the (I) should be pushed in.
Jan 10, 2008 | E-Machines eMachines Desktop PC
Won't work
When well Lexmart have the proper driver for me to install? Its been almost two months since I first contacted them by phone,I'm asking for someone to call me in the afternoon to explain when I can have my printer working, I need it bad! Phone#501-812-0691 Thank You Keeling
Mar 11, 2007 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Lexmark X5470 All-In-One InkJet Printer Logo
109 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
