Question about Heath Zenith Designer Series Wired Plus Wireless Doorbell - Mediterranean White, DC-3348
Can you show me a picture of the stay that holds and presses against the button
My health zenith wired/wireless door bell keep saying install cover
2 Suggested Answers
SOURCE: door bell keeps saying install cover when hung on the wall
I have had this problem before. There is a small button on the chime frame that is pressed when the cover is installed. For some reason the cover does not clamp on tight enough to fully compress that button, so it doesn't recognize that the cover has been installed. A thin shim taped or glued to the plastic leg that compresses the button should fix the problem. The shim could be plastic or thin cardboard but it won't have to be very thick.
Posted on Jun 16, 2012
Testimonial: "I didn't notice this answer before joining and asking again. Thanks, I'll look for it."
WIRELESS DOOR BELL BUTTON SL-1695-rx
Heath/Zenith SL-6166-C Wireless Plug-In Door Chime Kit ...
www.amazon.com > ... > Door Chimes & Bells > Kits
Amazon.com, Inc.Heath Zenith SL-6198-B Wireless Doorbell Replacement Battery. Total price: ... Plug-in doorbell chime, doorbell button/transmitter with battery, hardware pack ...
Oct 16, 2015 | Home Security
When our neighbour's wireless bell is rung our wireless bell rings as well
Open up the back of your bell and the back of your button. There should be switches you can move. Just move them the same on the button and the bell. This will make it so yours doesn't ring when theirs does.
Sep 11, 2012 | Heath Zenith Designer Series...
Door bell keeps saying install cover when hung on the wall
Jun 16, 2012 | Heath Zenith Designer Series Wired Plus...
I need a new push button for an sl6195 rx
Heath-Zenith (I beleive they bought DESA) makes a battery remote push button bell that says its compatible with all Heath Zenith chimes. I bought one at Home Depot and it worked for my SL-6195-RX. (an on line doorbell seller and the Home Depot assoc all said it wouldn't work.)
UPC is 16963961975.
Item also shows a code "11G43" on a sticker on the back of the package.
Nov 04, 2011 | Desa International White Wireless Plug In...
I have a door chime SL-6195-RX with outside door push button. I have changed batteries in both units and still does not work.
The contacts in the outside push button unit may need cleaning. They do get dirty over time. If that doesn't solve your problem you can contact the Zenith Company, who is now is the manufacturer for tech service issues. 800-858-8501.
Hope this helps solve your problem.
Mar 07, 2011 | Desa International White Wireless Plug In...
Hello! i've purchased one of your door chimes
Each push button should have jumpers in the back of them. By the description you say its the wireless but your text describes wires. If it is the wireless there should be jumpers, little black blocks that make an electrical connection, inside the push buttons and the receiver. Be sure you read the manual about which ones go where for your dual operation.
Jun 24, 2010 | Heath Zenith SL-6136-WH Basic Solutions...
My Zenith C32V28 television does not display the top and bottom of the picture. I phoned Zenith tech support who told me that it was the satellite signal. I called the satellite provider who advised me it...
This is applicable to Bell Television Services (Canada)
I solved the problem myself after two calls to both Zenith and Bell Television satellite service. On the bottom left of the Bell remote control there is a * (STAR BUTTON). Press this * button and within two seconds you must press the channel change button up or down. This will do two things. One; it changes the channel; and also changes the ratio of the satellite signal. There are three satellite signal ratio settings. Try this when you are tuned to a TV channel such as BNN (Canada) (Business News) or The American channel which has a stock ticker usually displayed along the bottom of the TV screen. Select the ratio (setting) that allows the stock ticker to be displayed......hope this helps.........Jim McP
Nov 10, 2009 | Zenith C32V28 32" TV
Heath Zenith Designer Series Wired Plus Wireless Doorbell - Mediterranean White, DC-3348 Logo
32 people viewed this question
Top Heath Zenith Home Security Experts
Mike
Domenico Grillo
Are you a Heath Zenith Home Security Expert? Answer questions, earn points and help others
