Question about Toshiba Satellite A135-S2276 Notebook
My laptop I got a laptop for christmas and it has a built in webcam and i can show my webcam at all how can i get my webcam to show cause when i click show my webcam it wont like you know click!
My built-in webcam doesn't work. It only shows a plain black. Please help me. My laptop is Acer Aspire 5755G
First : You have to check if the camera driver is installed on your device,you can do that by going to Start Menu then go to Control Panel then find the icon called System then open it then go to Device Manager then check there and look for Camera ,then right click on it then Properties then update driver
Feb 17, 2013 | Computers & Internet
My laptop is not showing that i have a built-in webcam
Go to Toshiba website and download the drive software and then install it.
Feb 03, 2013 | Toshiba C655D-S5303 Laptop X2 1.6GHz 3GB...
I have a motion tracking camera. It says its installed properly, and the ulead software it came with installed. At first, the icon was on the taskbar. I clicked. Nothing. Then the icon disappeared. I went...
You may have a conflict - try disabling the built in cam
> Start > Control Panel > Classic View > Device Manager
Expand the 'Imaging' Folder and right click on the built in laptop webcam text - select 'Disable'
Lots of problems here with Windows 7 and webcams
If it still gives problems trial it in Compatibility Mode
Right click on the webcam icon on your desktop or the webcam file from 'All Programs' - select 'Properties'
Select the 'Compatibility' tab
Select 'Compatibility Mode'
Use the dropbox to show the OS you have successfully used before
Click OK
Restart your computer
Everything mentioned is reversible so worth a try
Aug 23, 2010 | Gear Head WC755IPT Webcam
How do iget my built in webcam working for my
Hi there, please follow the steps.
1. Double click my computer then double click USB Video Device. You
can see your self then. If the USB Video Device not showing there then
you have to install the cam first.
2. Power On the laptop & after ready your OS for work just put your Dell driver DVD in DVD RW/ROM. when its open, that time just select webcam driver and install it as per your operating system. Usually Dell user's are install Broadcom driver for webcam.
So do it and after finish restart the laptop. Your will see your cam is ready for use. Then follow the first instruction.
Feb 15, 2010 | Dell Inspiron 1545 Notebook
Asus X71SL laptop - webcam issue
Go to the Camera Assistant Software on your computer, then go to Properties, then click on one Flip Vertical Arrow Twice then you should be all set.
Jul 02, 2009 | ASUS X71SL-B2 Laptop
I can not find my built in webcam anywhere but in network
if you have vista installed when you click "start"button there is a search engine located just to the top of the button.if you click there and enter "webcam" then vista shows the options automatically. however if you are using xp, then go to search and give webcam.exe in the search address bar. you will be able to find the options to access it
Jun 21, 2009 | Gateway M-1626 Notebook
Overiding the webcam built-in to a Dell 1720 laptop
Normal 0 Right click on My Computer and click on PROPERTIES.
Then click on DEVICE MANAGER, and then click on Imaging Devices.
Next click on the + and then on the camera, right click and then click on DISABLE.
Then click on the Red X in the upper LEFT corner.
Then get out of that and install your new camera.
Make sure to disconnecting the Camera from the USB port and reinstall the software program. When the program asks you to connect the camera to the USB port, do so and it should work.
Hope this helps. Bud
Jan 01, 2009 | Logitech QuickCam Pro 9000 Web Cam
Dont Know How To Turn On Microphone on webcam
Normal 0 Go to Control Panel and Click on Sounds, Click on Audio, then Click on the Microphone. Then Click on the drop down and select Camera Microphone.
Click OK and it should work.
Dec 25, 2008 | Logitech QuickCam Communicate Deluxe...
Web cam problem
I think ur laptop webcam driver not installed properly.If ur laptop have windows vista operating system then do these steps.
Goto Start - Programs - Recovery Manager - Recovery Manager.In that recovery manager,click on next.Its shows the Software reinstallation page.Click on next button two times.Its shows the software lists.Select the webcam software and click on next button.After reinstallation completed , u restart laptop and check it.
If ur laptop have windows XP operating system then u uninstall the webcam software through Add/Remove program and restart it.After restarting ,Reinstall the web cam software and check it. If u doesnt have webcam drivers then u go for nearest service centre and install it.
Thanks
Mar 11, 2008 | Acer Aspire 5630 Notebook
Web cam
Thanks
Mar 10, 2008 | Computers & Internet
Toshiba Satellite A135-S2276 Notebook Logo
50 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
