Question about Brother CS-6000
Bobbin won't wind
My machine won't let me wind bobbin - I can hear it running, but nothing is happening. Heard I should take it apart and oil inside, but I don't know how to take apart.
Hope this video will help..
bobbin won't wind - utube.png You-Tube video "wKssuOo3VbM" placeholder (do not delete) utube.png
Posted on Jan 11, 2013
SOURCE: Can't wind the bobbin
Hi again,
Well we finally downloaded a service manual that cost a few bucks, then finished getting the machine apart, then found a small rubber O-ring that had obviously gotten hot when spinning after the tangling of the thread on the bobbin stem. You could see where the heat had melted tiny teeth marks in the ring and it was stretched out of shape. It and yours too will need to be replaced.
If you or someone you know is mechanically inclined, you will need to take five screws out of the back including a hard to find one under the foot raising lever (lower the foot), then one form the front that is under the thread cartridge, and you will have to remove the bobbin winding plate cover which is held by one small screw, and then remove a small screw from the support bar.
Posted on Nov 10, 2008
  • 16 Answers
SOURCE: Bobbin winder shaft won't spin. LCD says bobbin winding.
I had the same problem. The trick is to make sure that when you put the bobbin on the winder that the notch on the bobbin clicks on the notch holder. So turn the bobbin on the winder until you hear a click or that the bobbin can not be turned. To check if the bobbin is on the holder correctly start the bobbin winder without thread. If the bobbin is engaged on the winder it will spin, if not then it is not set on the notch. I hope this helps.
Posted on Jul 07, 2009
  • 52 Answers
SOURCE: Brother SE-270D sewing machine bobbin won't wind
the rubber ring on the bobbin winder has probably gone bad which would mean replacing it but you can buy a portable bobbin winder called a sidewinder for around 20.00
Posted on Jul 16, 2009
  • 96 Answers
SOURCE: My bobbin thread keeps getting tangled and
there is a screw on the side of the bobbin case, which needs to be turned to the left or counter clockwise to loosen the tension and also change the needle because a burr on the end will cause problems with bobbin thread
Posted on Dec 13, 2009
  • 244 Answers
SOURCE: When I turn the knob
Have you removed the bobbin case to clean it? If so, it probably needs to be reseated. Remove the bobbin. Take out the case and reinsert it. If you can't get the bobbin out easily, there is probably thread clotted up somewhere under the feed dogs. I usually gently rock the handwheel back and forth as I brush the bobbin case area to begin dislodging the "clot." It also helps to remove the throat plate so you have a better view of the mechanics under the feed dogs. You'd be surprised at all the goop that can be caught but you can't see. If you do find a thread clot, use a machine brush and tweezer to gently remove each thread bit. I really hope this helps you. If it does, please come back to Fixya and rate my advice. Thanks!
Posted on Aug 02, 2011
Bobbin won't wind and display shows me in bobbin wind mode and won't turn off, so i can't use the machine at all
it sounds like it's a problem with the computer motherboard and the
machine needs to be checked
Dec 04, 2012 | Sewing Machines
My bobbin won't wind the tread
Did you remember to put your brother into winding mode?
Dec 02, 2012 | Brother XL-2230 Mechanical Sewing Machine
Is the hand knob and the clutch the same thing? It won't wind the bobbin.
I don't know that machine specifically, but generally, there is a wheel or disk or something inside the hand-wheel that is the clutch. It needs to be disengaged to wind the bobbin. Here are some options: 1. if there is a wheel with serrations on the edge, turn it clockwise until the hand wheel moves freely. 2. if there is a button, press it until you hear a click and the wheel turns freely. or 3. if there is a disk with a depression on one side of it, press in on the depression as though it were a button.
BTW, don't you have a manual for it? If not, it's available for download at: http://www.singerco.com/accessories/instruction-manuals/search
just put 132 into the search window and there it is.
Sep 09, 2012 | Singer Featherweight 132Q Mechanical...
Brother VX1435, needle won't move
some machines when the bobbin winder is engaged will not sew, do you
have to disengage the center wheel in the handwheel to wind a bobbin?
or do you have to just move the bobbin winder spindle to the right to
wind the bobbin?
do you have a manual for the machine?
Sep 06, 2012 | Brother VX1435 Mechanical Sewing Machine
Bobbin won't move
try changing the needle
rethread the machine top & bobbin
make sure the bobbin is wound correctly & inserted correctly
into the bobbin case
if these suggestions don't help then you might think about having
the machine checked at a sewing machine shop
Aug 05, 2012 | Brother PC-420
Bobbin winder on Pfaff 2170
sounds like the machine needs to be checked, since the bobbin icon
isn't showing up, could be something wrong with the computer
part of the machine
May 30, 2012 | PfaFF Sewing Machines
Why will my curvy not thread the bobbin or sew?
every one is asking the same question about the machine, if you don't
have a manual I'm putting in a link for a free one
http://www.singerco.com/uploads/download/1199_8770-efs.pdf
if you have the machine plugged into the wall outlet & into the machine
correctly, & it won't sew, you may have to send the machine back & get
a different kind
Apr 21, 2012 | Singer Curvy 8770 Electronic Sewing...
Bobbin won't wind on singer 5500 just makes motor noise
the machine probably needs to be serviced
Apr 13, 2012 | Sewing Machines
Cannot wind the bobbin
Check to make sure that the bobbin is locked onto the winder. If is not locked on then nothing will move. I know I had this problem as well and found that the bobbin must be locked on the winder.
Aug 24, 2008 | Brother CS-8150 Computerized Sewing...
Bobbin will not lock on bobbin spindle, what can I do?
Mar 20, 2008 | Brother CS-8150 Computerized Sewing...
Brother CS-6000 Logo
77 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
