Question about Pride Mobility Products Pride Legend XL - 4 Wheel HD Scooter
Colt xl8 code 7 fault changed speed pot still cuts out
  • mark
    mark Feb 04, 2013
    its a electronic 1 and thanks will check that
  • Pride Mobili... Master
  • 1,263 Answers
Hi, can i ask you what the pot was like , a electronic one or mechanical one ?
If it's Electronic check there is a 24v - + plus voltage on the red and black cable. This is a common problem with these scooters.
regards
www.gewizrepairs.co.uk
Posted on Feb 01, 2013
  • Robin Hill
    Robin Hill Feb 01, 2013
    hi, can i ask you what the pot was like , a electronic one or mechanical one ?
    regards
  • Robin Hill
    regards
How easy is it to change the brake lever and hydraulic reservior on a Pride Colt xl8
The brake lever IS the hydraulic reservoir. I wouldn't want to try replacing it since it requires a lot of dissembling of other components to get to the lever and brake lines.
Aug 11, 2016 | Pride Health & Beauty
Hi, i have a pride colt xl8, it makes a continuous beep when switched on, status led is fine , not flashing to show a fault, how can i stop this beep?
Make sure the disengage lever is in the correct position. If it is, then the position switch on the lever is bad.
Jul 22, 2016 | Pride Health & Beauty
I have a pride classic xl8 i will be go along at top speed and then for no apparent reason it starts to go slow then quick then slow
This could be something to do with the HI-LOW speed switch or the connections on it or back to the control unit. Check for loose connections first. If you have a meter, check the resistance across the Hi-LOW switch.
Nov 13, 2014 | Health & Beauty
Mitsubishi colt fault code
code p0500 refers to vehicle speed (VSS) -circuit malfunction===causes wiring ---VSS---ECM
replace the VSS
I do not have the other codes available but from your description of the faults and the fact that the VSS is involved I suspect that the other codes will refer to a TCM problem
Mar 02, 2014 | 2004 Mitsubishi Colt 1.3
7 bleeps on my GO GO ELITE TRAVELLER SCOOTER
Hi. 7 beeps is fault code for a faulty speed potentiometer. Might also be a broken wire on the pot or a faulty connector. Most times, a new pot will fix the problem.
Good luck. Neil.
Jul 08, 2010 | Pride Go Go Elite Traveller Plus HD 4...
I have an xl8 mobility scooter that keeps cutting out and stopping dead, i then switch it off and on and it starts, could it be the motor?
My Pride Colt XL8 keeped cutting out (7 flashes of LED, Speed pot error) , checked all the cable connections up tiller arm as recommended by Pride technical support, worked for about a week, then problem returned. Eventually took to Pride dealer, with problem occasional occurring,they found it to be the lower tiller cable support bracket straining the cables connector intermittently and so removed the bracket, the problem then was solved !
Oct 19, 2009 | Pride Mobility Products Pride Legend XL -...
Pride mobility legend XL throttle/speed fault
what about the overall connection , start at the handlebars from the speed pot,
Take off the rear cover , first remove the seat, pull the connector one by one and plug back in,
chec kthe connectors around the speed pot , in particualar if there is a circuit board.
Apr 24, 2009 | Drive Medical Mini Phantom Three Wheel...
Pride Mobility Products Pride Legend XL - 4 Wheel HD Scooter Logo
195 people viewed this question
Top Pride Mobility Products Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
Robin Hill
Robin Hill
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
