Question about Optoma PRO250X Projector
How to clean inside the lens of PRO 250X Projector
  • Optoma Master
  • 3,904 Answers
You don't. It is sealed.
Posted on Jan 07, 2013
How do I clean the inside of the lens on my wonderwall 1625073 projector
It is recommended only cleaning the outside of most projector lenses. However if obstructions have worked their way into the case and will not leave the lens, you may be able to remove the bulb (carefully, following the manuals instructions for bulb replacement)
And gently spray inside towards the lens where the bulb was. However, keep in mind the display itself sits between the bulb and the lenses,
Some projectors have air fins along the sides of the lens, some air in these fins can also loosen debris away from the lens.
Ensure the front of the lens is not dirty and that the focus has been properly adjusted before cleaning the back of the lens.
Nov 28, 2014 | Office Equipment & Supplies
HOW DO YOU CLEAN THE INSIDE LENS?
You probably don't need to. I know you may see what looks like a lot of dust, but unless it's completely covered, that dust on the lens has very little effect on your projected picture. If it is really bad, you can try to open it up and clean the lens with a lint-free lens cleaning tissue (NOT FACIAL TISSUE) and a couple of drops of distilled water (or lens cleaning liquid). But you best bet, if it's really dirty is to take it to a service facility.
Apr 14, 2014 | Sharp Pro PG-D120U Multimedia Projector
How do I clean the dust off of the inside of Ox Pro projector lens?
Most models are very similar. Here is a video of a similar repair.
Apr 29, 2012 | Office Equipment & Supplies
There appears to be dust or snow on the lens
This is a dlp projector and has a bad DMD chip. Most models are very similar. Here is a video of a similar repair.
Mar 23, 2011 | Mitsubishi XD211U DLP Projector XGA 2000:1...
There is dust inside the lens. how do I clean the dust from inside the lens?
Your projector needs little maintenance. The only thing you need to do on a regular basis is
to keep the lens clean.
Never remove any parts of the projector except the lamp. Contact your dealer if other parts
need replacing.
Cleaning the lens
Clean the lens whenever you notice dirt or dust on the surface.
• Use a canister of compressed air to remove dust.
• If there is dirt or smears, use lens-cleaning paper or moisten a soft cloth with lens cleaner
and gently wipe the lens surface.
Never rub the lens with abrasive materials.
Nov 27, 2010 | BenQ MP623 DLP Projector
Im getting spots projecting on image
Check for dust on the lens. There may also be dust inside the projector on the mirrors, lenses, or LCD. If cleaning the lens on the outside doesn't resolve your problem, I would contact a professional to get the insides cleaned out.
Good Luck!
Feb 05, 2010 | ViewSonic PJ556D DLP Projector
How do you clean inside the lens
canned air. if you take the lens assembly apart to try and clean it any other way, there's a slim chance you'll get it back together properly. plus, they thread lock it. it's usually air-tight, but if it isn't, used the canned air to blow the dust out. chances are, the dust is inside the projector itself and on the back side of the lens assembly.
Jan 26, 2010 | Lightware VP 800 Plus Multimedia Projector
At the top of my projector image there are a series of blue dots
You need to clean the mirrors inside your projector, you can either open the shell and use compressed air, but i will recomende u to go to someone who works with things like that. Its cheap to clean a projector by a pro, it takes a pro about 10-15 minits to do it.
If u gona use compressed air, make sure u biy air special for elecronics and nevere ever hold it near the mirrors.
Nov 13, 2008 | Sanyo PLC-SW30 Multimedia Projector
My projector turns on then off
Probably your projector filter is full of dust, and probably even the inside id full of dust. You need to clean the filter and you need to clean the inside. The fan starts coz the lemp inside cant get any air, as soon as you turn the projector on it gets overheated.
Go to a pro and let him/her clean your projector good, then it should work properly again. And make sure that you clean the filter at least 3-4 times per year.
Good luck
Nov 01, 2008 | Sanyo PLC-SW30 Multimedia Projector
My projector Benq pb6200 needs cleaning from the inside how???
I have an Optoma EzPro 737 DLP projector that accumulated dust inside the lens and for ages I couldn't figure out how to get rid of it. It cast shadows onto the picture and scattered light outside the edges of the picture. I thought I'd have to dismantle the whole lens assembly (then realised that this is virtually impossible without being an expert). I then stumbled upon a little black rubbery plastic panel on the side of the light path, which unclips. I then realised that the dust had built up on the lens that sits in front of the DMD chip (the thing that makes the picture).
Here's what I did, with the case open and having vaccuumed out all the dusty parts of the projector to avoid making the situation worse:
- Took off the little rubbery panel,
- Removed the lamp from the projector and placed a flashlight inside, shining into the light path (or a mirror directing light from a table lamp above)
- Looking directly into the lens from close up, you should be able to see the particles of dust stuck to the inner lens (with a nice magnified view)
- First tried blowing air into the gap on the side of the light path (I used a balloon pump).
- Next, I poked a piece of thick nylon fishing line into the hole so that it could touch the surface of the inner lens.
- While looking into the lens, I could see the tip of the nylon, then directed it to the largest dust particles and used it to scrape them off (nylon is much softer than glass, so won't scratch the lens).
- This was quite time consuming but I got rid of the most obvious bits.
I'm not sure how different this would be for another model of projector - but I hope it helps!
Dec 16, 2007 | BenQ (200NSH-LAMP) Projector Lamp for...
Optoma PRO250X Projector Logo
51 people viewed this question
Top Optoma Office Equipment & Supplies Experts
color wheel light...
Electro Med Services...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
