Question about HP Compaq nc6320 Notebook
My laptop cant light up
The charger is good but power goes through my machine
  • HP Master
  • 32,281 Answers
Computer does not boot up The problem maybe the RAM, it is faulty or just needs reseating to make proper electrical contact.
Reseat the RAM and then boot up your laptop. If it still does not boot up then remove the RAM module/s and take them to your friendly computer repair shop and get them to test the RAM for you. Just like you sometimes need a mechanic to repair your car, sometimes you do need a technician to diagnose and identify the fault or faults on your computer. Not only does a good service technican have the experience to deal with this type of problem, they also have the equipment that allows them to look at things the average computer user can't see, and he has a collection of replacement parts that can be used to quickly test individual components on your computer.
Posted on Jan 09, 2013
My power adapter light on but if i plugin to my pc the light off why
usually indecates a short..theres a blocking diode.that only alows current to flow one dirrection.or if theres a burst of current it goes off. thats a safty feature in chargers. therefore when you plug it in its detecting impropper current flow and stopping the charger..Try doing a Hard reset on the computer.I've had that same notbook.There pretty good machines
Nov 23, 2013 | Acer Aspire 4520-5582 Notebook
How do i fix an Acer aspire 4730z that will not charge the battery and has the charge light no longer comes on, is the motherboard bad?
Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
Sep 09, 2012 | Acer Aspire Computers & Internet
Green light cuts off when plugging into laptop
Replace the charger, it probably overheat and died.
Try with a voltmeter to measure the output power (usually aroud 19 V DC)
Then the tricky part, try to power something else with the charger , something who might work with the output power (a car light bulb for exemple).
If it does work then you have a short cut on the motherboard of your laptop if it's the case replace the laptop, it's the hell of a job to repair the motherboard...
good luck
Dec 12, 2009 | Dell Inspiron 1501 Laptop
Power light comes on and goes off and machine is dead
The Motherboard is bad but before you buy one.Try this Remove the memory, cd rom,hard drive battery, power adapter. Press and hold the power button down for about twenty .Replace the memory only,power up if you get the same result the motherboard has to be replace
Sep 15, 2009 | Dell Inspiron 9300 Notebook
Why when power lead is plugged in does my laptop just turn off, the charger charges battery when its off soon as turn it on with the charger still plugged in off it goes.
remove your power lead and battery and try just the power lead by itself
If the power light comes on then you need to try turning on the machine
if this starts up like normal then the battery is at fault
if it does not start and the power light comes on then the fault will be the power connection on the machine,
normally they are a part of the motherboard and this is an expensive excercise to replace
Hope this helps --- Misterdj
Aug 22, 2009 | Sony VAIO GR114MK PC Notebook
Laptop can't pw on wif charger or batt *light go off on charger*
does the machine work at all? at best its faulty charger , I recall a laptop sometime ago I worked on had a fight with what looked like , 3 pints of milk and a cup of coffee showed same syptoms, could be faulty MOBO
hope this helps
Jun 10, 2009 | Dell Inspiron 6400 Notebook
Dell inspiron 9300 wont power up/good battery and charger
check if your systemboar power is on or not, and also check if the fan is spinning or not. If not try and reset your processor.
Apr 20, 2009 | Dell Inspiron 9300 Notebook
I cant switch on my laptop
Sounds like the charger is faulty.
Sep 30, 2007 | Computers & Internet
HP Compaq nc6320 Notebook Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
