Question about Toys
I have a pair of Amtrak Lionel passenger cars #'s 6403 and 6404. Neither have trucks or couplers. Are they available, if so what are the part numbers? How do they attatch to the cars? Are they
Coupler will not stay closed on tender this was new out of the box
Contact Lionel Customer Service for a repair/replacement or take the tender to a Lionel Service station.
Jan 27, 2016 | Crafts & Hobbies
The 3rd passenger car has short in it and causes green light on cw80 to blink. Checked wires and contacts on trucks can't find problem.
Lionel uses insulated wheels on there power pickup trucks , one side will have insulation bands and one will not , insulated bands need to be all same side on same truck , lead end is different than tail end this is how it picks up power from tracks , sometimes trucks axles get popped out in playing and maybe don't get popped back in the same way , also its possible for insulating bands to get holes in them from use , a dot or two of black latex paint fixes these up (don't paint entire wheel)
Dec 01, 2015 | Lionel The Polar Express Train Set
How do I know the schedule for the amtrak train to san francisco?
if you cannot contact them via internet:
Reservations & Customer Service
1-800-USA-RAIL (1-800-872-7245) or TDD/TTY (1-800-523-6590)
Jul 01, 2014 | Computers & Internet
Thomas engine keeps uncoupling.
Check the warranty. If still under, return it. Otherwise find a store that sells small black rubber bands, around 1/2" in diameter. Wrap one around the coupler behind the knuckle. Check to see if the coupler still opens. If it does move the rubber band either forward or backward until the coupler does not open.
Apr 23, 2013 | Lionel (31956) Thomas The Train Set
Thomas the Tank engine coupler not holding on the cars.
Holiday Tradition Express, engine tender not working. Contacted Lionel Trains, they have no replacement parts or service available.
Best bet is to search the internet for Lionel replacement parts. Try to include as much information in your search.
Dec 03, 2012 | Lionel 11000 Holiday Tradition Express...
I just bought a new lionel o guage remote control track section. My train can run around the oval 3 or 4 times and the uncouple button will cause a coupler to uncouple properly. Then the magnet in the...
sounds like a contact issue clean all connections make sure they fit tightly when a bad connection occures it will cause metal to heat up check both sides of the circuit with an ohm meter
Sep 04, 2012 | Lionel Remote- Control Track with UCS...
How can I fix smoke problem on polar express
Most Lionel engines have a small slider switch which can turn off the smoke generator. Check to see that the switch is in the ON position. Check the engine manual (available from Lionel's website) for the location of the switch.
Also, if the smoke generator is always on and no fluid had been used in the generator, it will eventually burn out. Replacement smoke generators are available from Lionel.
Jan 05, 2012 | Lionel The Polar Express Train Set
Toys Logo
Top Toys Experts
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
