Question about HP Compaq nc6320 Notebook
Hp compaq nc6320 no power
Good charger but no power light up
    Sergeant:
  • HP Expert
  • 427 Answers
Have it checked in service. It seems to be motherboard problem
Posted on Apr 17, 2013
mellomania
  • 121 Answers
SOURCE: HP Compaq nc6320 Boot Disk
in case you can get a non boot disk , u can install it by using a start up floppy disk for win9x
Posted on Nov 15, 2007
AvioriX
  • 689 Answers
SOURCE: compaq - will not turn on - plugged in?
Disconnect the AC adaptor, Take the battery out and press and hold the power button about 5 seconds. After that connect the AC adaptor and insert the battery turn it on. If issue persist please inform for further troubleshooting.
Good Luck
Posted on Mar 01, 2008
SOURCE: Describe your HP Compaq nc6320 PC Notebook Problem
i have a Compaq nc6320 when i plug in the power cord the electricity led doesn't want to turn on i have changed the cords and the adapters and i doesn't power on or even charge the battery, did any one have an idea what to do in this problem?
Posted on Apr 10, 2008
SOURCE: HP Compaq nc6320 PC Notebook Problem
unplug the internal battery for 5 minutes, then reboot with power battery out (only on mains). It is documented in the manual.
Posted on Nov 03, 2008
sparkyuiop
  • 91 Answers
SOURCE: HP Compaq nc6320 PC bios password
Ok, as long as the high security level has not been set in the bios then the following will work to reset / disable the bios password.
1. Remove the battery and mains adapter.
2. Remove the memory cover on the back of the laptop and remove the 2 keyboard screws.
3. Open the laptop and at the top of the keyboard you will see 4 sliding tabs. They are located between the 'Esc & F1 keys' 'F4 & F5 keys' 'F8 & F9 keys' and 'F12 & delete keys'. Slide these down and lift the keyboard up and pull forward slightly so as to disengauge the bottom lugs. Be carefull as there is a ribbon cable at the bottom that does not need to be tugged or removed.
4. You will now see at the bottom behind the keyboard a small battery connected to the motherboard. Gently pull the small white plug upwards untill it is removed from the board.
5. Wait 5 minutes and re-connect the small battery plug.
6. Re-install the keyboard and push back the clips. You do not need to replace the screws yet.
7. Apply the DC jack and power on - DO NOT INSTALL THE MAIN BATTERY.
8. Turn the laptop on while pressing f10 repeatedly but slowly - Do not hold it.
9. If high security is disabled you should now be in the setup screen, select 'Restore Defaults' and press F10 to save.
10. The password is now removed.
If this does not work then HP say that there is no other way to reset it. Im not sure about that, there probably is by some method of de-soldering the bios chip. However the above method worked for me so I hope it does for you. Please rate if you have any luck.
Sparkyuiop.
Posted on Dec 03, 2008
How do i fix a problem of green power led continuously blinking in Hp compaq nc6320 laptop even when the battery is removed and the motherboard is outside the case?
HP Notebook PCs - Troubleshooting LED Blink Codes or ...
h20564.www2.hp.com/hpsc/doc/public/display?...na...
Hewlett?PackardHP Notebook PCs - Troubleshooting LED Blink Codes or Beep Codes During Startup or Boot ... HP Pavilion and Compaq Presario notebook computers built in 2009 or later use blinking LEDS to identify ... Press the power button to turn on the computer, and look for blinking LED lights on the keyboard. ... Continuous blink.Missing: green ‎nc6320
HP Notebook PCs - Computer Does Not Start and Emits an ...
support.hp.com/us-en/document/c01732674
This document pertains to HP and Compaq notebook computers. .... light next to thepower socket or the light on the AC power adapter and note its condition: off, blinking, or constantly on. ... Battery power LED off, and Caps Lock/Num Lock off.Missing: green ‎nc6320
HP 6735s won't boot, power LED blinks 7 times - HP ...
Feb 03, 2016 | HP Computers & Internet
Laptop mouse pad doesnt work if being used on flat surface
Power drain would be a better solution in this case.
1.first shut down the comp
2.unplug the charger
3. remove the battery
and after press and hold the power button for 60 seconds without any charger and the battery.After the 60 seconds replug the battery and the charger and turn the computer .
Oct 27, 2009 | HP Compaq nc6320 Notebook
Inverter part no
HP/Compaq Power Supply / AC Adapter, 120W (18.5V 6.5A), PPP017L PA-1121-12HC, 384023-001, 391174-001
Mar 11, 2009 | HP Compaq nc6320 Notebook
Laptop dows not charge.
No, you have to replace fried charge controller IC with exact one, or it'll not work.
Jan 02, 2009 | HP Compaq nc6320 Notebook
Blinking power button, no responce from the laptop
sound like you charger is broken, i think tose use the same charger as the compaq presarios, evo's if you can get a used 65 wat that problem would have been fixed, but those are still pretty new, i think you can get a new charger for free if it's still under warranty
Dec 24, 2008 | HP Compaq nc6320 Notebook
Try unplugging internal battery for a minute or two it worked for me.
Sep 01, 2008 | HP Compaq nc6320 Notebook
Mar 31, 2008 | HP Compaq nc6320 Notebook
Compaq - will not turn on - plugged in?
Good Luck
Mar 01, 2008 | HP Compaq nc6320 Notebook
HP Compaq nc6320 Notebook Logo
139 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
