Question about Frigidaire Affinity ATF6000F Front Load Washer
Hoe do i reset frigidaire atf6000fs1 washer - Frigidaire Affinity ATF6000F Front Load Washer
2 Suggested Answers
Jahn27
  • 1554 Answers
SOURCE: I have a Affinity frigidaire front load washer and
Disconnect power then open the door and remove the spring-hoop assembly that secures the door gasket. Peel off the part of the door gasket near the door lock and switch assembly. Remove the screws securing the door lock and switch assembly to the front panel then pull the door lock and switch assembly out. Transfer the wires to the new door lock and switch assembly then install into place. Put the door gasket back and secure it with the spring-hoop assembly. Click on the link below for the detailed procedure.
Replacing the Door Lock and Switch Assembly on Frigidaire Affinity and Gallery Front-Load Washing Machine
Posted on Nov 13, 2010
My atf6000fs1 front loading washer is tripping the GFCI outlet instantly when the washer starts. Any suggestions for where to start looking? I used an extension chord to test it on multiple GFCI's i
Hello friend, thanks for your post!
I see that your Frigidaire washer, ATF6000FS1, is tripping the GFCI outlet in your home. Typically for any Frigidaire appliances it is not recommended to be plugged into a GFCI outlet or extension cord. I would recommend trying a different outlet to see what the outcome is. Hopefully this information is helpful. -Matt
Sep 11, 2014 | Frigidaire Washing Machines
What are the cubic feet for the affinity atf6000fs1
Hello Friend, this is Z. That's a great question!
I show that your Frigidaire Affinity washer (ATF6000FS1) has a total capacity of 3.5 cubic foot. Hope this helps! If there is anything else that I can help you with, please feel free to reconnect.
Jun 12, 2014 | Frigidaire Affinity ATF6000F Front Load...
Changing door lock on atf6000fs1 washer
Good Afternoon Friend,
I understand you want to know how to replace the door lock on your Frigidaire washer, model# ATF6000ES. Typically, this is not a do it yourself repair, as there are no step by step instruction manuals. I suggest contacting your local authorized technician for further assistance. They have been trained on your appliance, and should be able to replace the door lock with ease. Hope this is helpful.
-Best Regards-
WP
Jun 11, 2014 | Frigidaire ATF6000ES Front Load Washer
How to change seal on atf6000fs1 washer
I understand you want to know how to replace the seal on your Frigidaire washer, model# ATF6000FS1. Typically, this is not a do it yourself repair, as there are no step by step instruction manuals. I suggest contacting your local authorized technician for further assistance. They have been trained on your appliance, and should be able to replace the seal with ease. Hope this is helpful.
-Best Regards-
WP
Door won't unlock on my ATF6000FS1
Hello Friend, this is Z. Thank you for allowing me to assist you!
I see that your Frigidaire washer (ATF6000FS1) door will not unlock. Sometimes, resetting power to your washer for about to 10 minutes does the trick. Once you turn on your washer, select a normal cycle and verify if the door will unlock. If not, your washer may possibly have a faulty door lock assembly, or a communication problem with the control board. You may want to connect with a local servicer who will be best equipped to pinpoint the problem. If you don't know a qualified technician, you can use the service locator option on the manufacturer site to find one near you.
Jun 04, 2014 | Frigidaire Affinity ATF6000F Front Load...
My frigidaire affinity front load washer ATF6000FS1 wont fill with water
Hello hitman43 - Are the house valves turn on fully? Most common cause is a faulty switch that doesn't allow the value inside turn or a kinked fill hose. Other possibilities can be water valve faults, faulty control board, pressure switch or wiring failure. Contact a professional to move forward accurately.
Jan 01, 2013 | Frigidaire Affinity ATF6000F Front Load...
How do you service the lint trap on FRIGIDAIRE FRONT LOAD washer MODEL ATF6000FS1?
What are meaning by service? You can clean it out and even clean out the coin trap of the unit for regular maintenance.
Aug 09, 2012 | Frigidaire ATF6000ES Front Load Washer
My washer will not drain the water and the spin-Model ATF6000FS1
I had the same problem but bought a new washer. As we were parting this washer out we found that there is a black rubber boot the attaches to the water pump. There is a filter inside of this boot and it was clogged with hair, string, and almost 2 bucks in change. No wonder it wouldnt drain. Check yours and see if thats your problem too!
Oct 05, 2009 | Frigidaire ATF6000ES Front Load Washer
Frigidaire Affinity ATF6000F Front Load Washer Logo
87 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
