Question about Sharp AR-5320 Black and White Copier
Sharp MX-M350N simulation mode - Sharp AR-5320 Black and White Copier
  • 140 Answers
SOURCE: IN MX-M350N SHOWS "REMOVE PAPER FROM TOP TRAY" AND DOESN'T PRINT
You probably have a paper jam in the auto feed unit. Open the auto feed and check for bunched up paper and if you don't find any open the side doors and check for paper jams there. Let me know what you find.
Posted on Feb 13, 2009
  • 12 Answers
SOURCE: Sharp AR-M350N memory?
AR-M350N may be have 16 Mbyte of internal memory.
You could expand it until 256 Megabyte.
I attacched to this post an image that describe compatible expand memory.
Posted on Nov 04, 2009
  • 34 Answers
SOURCE: How to clean data off harddrive
It should say in you admin operators manual or go to settings and then admin password, which should be "admin" and look through there and hit factory default. That should do it, if not I can check further.
Posted on Apr 30, 2010
hamzaskilltd
  • 316 Answers
SOURCE: Sharp AR-M350N that is throwing a F1-87 Finisher Trouble
IMC PWB communication error
Posted on Jun 12, 2010
dwylie76
  • 80 Answers
SOURCE: I need to enter simulation mode on Sharp MX-M260N.
Simulation Mode is # * C * What do you mean by the MIB? I know that you can setup settings for the SNMP on the webpage of the copier. Have you tried that?
Posted on Nov 10, 2011
Sharp mx-m264n how to enter simulation mode
1. Entering the simulation mode
Perform the following procedure to enter the simulation mode.
"#" key "*" key "C" key "*" key
OR
"#" key "INTERRUPT" key "C" key "INTERRUPT"
Sep 14, 2015 | Sharp Office Equipment & Supplies
H3-00 error
Main code 14 Start key Sub code 0 Start key
OR
2. Canceling the simulation mode
When the clear all key is pressed, the simulation mode is cancelled.
When the interruption key is pressed, the process is interrupted and the
screen returns to the sub code entering display.
* After canceling the simulation mode, be sure to turn OFF/ON the
power and check the operation.
Note: If the machine is terminated by a jam error or paper empty during copying in the adjustment by the simulation, recopying is required.
DO NOT CONTINUE RESET AS THIS CAN CAUSE A FIRE AND RUIN A PERFECTLY GOOD DAY.
Apr 24, 2015 | Sharp Ar M350n
HOW DO I FIX ERROR MESSAGE H3-00 ON MY MX M753N
OR
DO NOT CONTINUE RESET AS THIS CAN CAUSE A FIRE AND RUIN A PERFECTLY GOOD DAY. REPLACE THE FUSER UNIT
Feb 25, 2015 | Sharp Mx-M753n mx-M753n
How can I delete the Memory of RESENDFAX for MX-2310?
Try this while you're at it.
# * C * to enter the simulation mode.
Simulation 66-10 is the image memory clear which clears the print/scan/fax memory. DO NOT EXECUTE AND OTHER SORT OF CLEARS IN THE MENU.
Copier Collin Houston TX Copier and Imaging Expert
Feb 08, 2015 | Sharp MX-2310U Color Printer : 2310U
How enter sin simulation mode in sharp MX-M354N
To enter simulation mode you need to press the following 4 buttons in quick succession:
# * C *
The # & * keys are to the left & right, respectively, of the zero key,
the C key is the red C to the right of the number 3 key.
Hope this helps
Jan 14, 2015 | Sharp Mx-M354n Mfp
Unable to print double sided on sharp mx-m350n with window 7
I had the same exact problem. Go to control panel>hardware and sound>devices and printers. Right click the printer and select printer properties. Click the configuration tab and make sure the duplex module is checked. This should solve your problem.
Jul 03, 2012 | Sharp Office Equipment & Supplies
I need to enter simulation mode on Sharp MX-M260N. Also, I am looking for the MIB code to enable/disable copier via SNMP
Nov 08, 2011 | Sharp MX-2300N Color Copier
How do you put a ip address in a sharp mx-m350n thank you.
Here is a link the administrator manual (http://www.sharp-ro.ro/dyn_pdf/doc-MX-M350N-139.pdf) on page 13 it tells you how to set the IP address.
Jan 22, 2010 | Sharp MX-M350 All-In-One Printer
HOW TO RESET SHARP COPIER AR-M350N AFTER FUSER WAS CHANGED. CODE H3-00 STILL APPEARS.
must enter into simulation mode. press"P""*"Clear""*" then press"14 " then press "start" then press"0" then "start" again. if 14 doesn't work substitute 15,16 or 17.
Nov 04, 2009 | Sharp AR-5320 Black and White Copier
Sharp mx 2700n how to go SP mode and i get error code h5.01 how i solve this problem
Use SIM14 to
cancel the trouble.
1) Copy mode key ON → Program key ON → Asterisk (*) key
ON → CLEAR key ON → Asterisk (*) key ON → Ready for input of a main code of simulation
enter 14
accpet yes clear..
machine should restart.
You may have to have a tech look into why this is jamming...
Hope that helps
Lbcoaster
Dec 23, 2008 | Sharp MX-2700N Color Copier
Sharp AR-5320 Black and White Copier Logo
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
