Question about Smith Corona Electra Xt Portable Typewriter 8170
I have a Smith Cornona Electra XT. It still turns on, but when I do turn it on, the carriage automatically goes back and forth non-stop and it's like you arre holding the return button down conti
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 18 Answers
Find the problem, some linkage is sticking and you have to trace it through. Spray with WD40, then when working spray with other light oil, cause WD40 does not stay. Most likely the carriage return release . Take bottom off and watch what it hits on the left side, Also the tab button locked down will do this.
Posted on Nov 08, 2017
2 Suggested Answers
JUSTOLDJIM
  • 475 Answers
SOURCE: carriage return problem
The tab button may be stuck or the carriage release lever is stuck or a broken escapement.
Posted on Dec 31, 2008
2005 Ford F-150 4x2 Super Cab Styleside ignition froze, can NOT turn key...help
Battery charged pull the steerinh wheel left foot on brake them turn key on our chrusler i jave to tap the key culinder 3 tomes with the end of the key befor iy will turn hoi may hsve to take cylindet ouy and jave lock smith drill thr pins out as o think you hsvr to keep same key and so forth of not ny whole colum at junk yard snd swop
It
Jan 08, 2017 | 2005 Ford F-150 SuperCab
What do you need help with? Hp Deskjet 2645 is showing error code and it refusrs to print
The carriage that goes back and forth when printing may not be moving freely. Turn off all power and see if you can move it back and forth easily. If not, put a drop of light oil on either side of the cartridge holder and slide it back and forth. You can also clean off the carriage rod with a cloth before oiling.
If this does not clear up the error code, the main board has failed and it will not be worth repairing, unless the unit is under warranty.
Oct 04, 2016 | HP Office Equipment & Supplies
How do I fix my Smith Corona SC110 Typewriter?
make sure the right hand platen knob is tight hold the platen and turn the knob top toward the back of the typewriter until it is tight
Aug 17, 2014 | Smith Corona Wordsmith 100 Typewriter
Where can I find a manual for an old smith corona XL electra typewriter?
Google smith corona dunkirk ny.
they will be able to help you.
DickyO
Sep 24, 2013 | Smith Corona Electra Xt Portable...
What can I do about a carriage that shudders when I turn the machine on but it does not move freely. I have a SC 110 electric typewriter
Usually it is because of some obstruction, or the main shaft is gummed up.
Open the cover to check if there are no foreign objects lying in the way of the carriage.
Also, part of the packaging included a rubber sleeve that stopped the carriage from sliding around during shipment. It may be still there, who knows?
You may also try a few drops of oil, preferably the sewing machine type.
If you turn the machine OFF, can you manually slide the carriage back and forth?
Jun 16, 2011 | Smith Corona Wordsmith 100 Typewriter
How do you unlock a De Ville 410
Are you saying the carriage is locked, so it can't go back & forth? Sticking out of the right-hand side of the carriage are two tabs; I think they're light blue. Pressing down one one locks the carriage. Pressing down on the other unlocks it. When the carriage is unlocked and moves out of the way, you can see the ramps and notch molded into the bottom of the case to hold the carriage for shipping.
Feb 17, 2010 | Smith Corona Office Equipment & Supplies
I TURNED IT ON AFTER A LONG PERIOD OF NON USE. AS
Dosen't sound to good. While it's off try moving the carrier (print head) back and forth it should move freely if not put some WD40 on the silver shaft it slides on.
DickyO
Feb 09, 2010 | IBM Wheelwriter 30 Typewriter
Have a Smith Corona Electra 110. The ribbon doesn't turn, whether it is set to go one way, or the other. The side that's driving the ribbon makes a little **** with the keystroke, but goes back to starting...
Make sure that the ribbon has been intalled into the reverse guide forks on either side where the ribbon comes out of the spools. The ribbon should have a rivet in the fabric near the end of the ribbon so make sure you have the proper ribbon. The machine may require lubrication. You might also try taking the ribbon out and moving the R side to the Left just so you can type a little bit. Thsi may loosen the mechanism.
Nov 04, 2009 | Smith Corona Office Equipment & Supplies
Carriage return problem
Dec 24, 2008 | Smith Corona Wordsmith 100 Typewriter
Smith Corona Electra Xt Portable Typewriter 8170 Logo
63 people viewed this question
Top Smith Corona Office Equipment & Supplies Experts
James Cagle
James Cagle
Hjalmer Lamminen
Hjalmer Lamminen
Jim Keysor
Are you a Smith Corona Office Equipment and Supply Expert? Answer questions, earn points and help others
