MAYTAG MAXIMA ERROR CODE F09 - Washing Machines
2 Suggested Answers
hwy505
  • 7 Answers
SOURCE: Error code F09 for HE3T Kenmore waher
Shannabug is right on the money. I had the same problem a few days ago. F09 came up - I hit pause twice - since there was water still in the drum I did a spin and drain.
NOW UNPLUG THE WASHER!
Right below the kickboard there are three torqux screws - now's a good time to get a Torqux folding key set. Once removed - give the side of the kick board a rap on the side - sometimes you may have to use an object to hit it with - it'll fall right off.
On the bottom, dead center is a white cylinder facing you with a screw cap. This is the filter/catch basket - to the right of that is your pump.
Before you screw off the cap, make sure you have lots of paper towels - I had a shop-vac - as I loosened the cap I had the vacuum **** up the water that was coming out - I removed the filter and there was two pencils in there - apparently my son never emptied his pocket. I put the shop vac into the filter chamber and started sucking up anything else that may have been there.
When you put the cap back on, ensure the little notch on top of the cap is facing up, and screw it back on securely. Put the kick board back on - and you're ready to go.
If you continue to have a problem you can clean out the drain tube with a shop-vac - and/or purchase a new pump - but now you see where it is, and how easy it is to change it - you can now save yourself a few hundred dollars by changing it yourself!
IMPORTANT - BEFORE YOU DO THIS UNPLUG THE SYSTEM. This will make sure no injuries, and while you are doing the filter, the computer is getting to reboot itself.
Posted on Dec 20, 2009
How do I clear the fault codes ?
How To Fix Maytag Washer Error Code F9 E1 ...
www.appliancerepairlesson.com/2013/.../maytag-washer-error-code-f9-e...
Dec 10, 2013 - The error code F9 E1 will be displayed on most newer Maytag washers and ..... My whirlpool duet wfw94heaw0 gives the error code F09 E01.
KitchenAid f09 error code Dishwashers Questions ... - Fixya
Nov 29, 2015 | Dishwashers
What does error code f09 mean on a bosch vented dryer,?
F09 error is no heating, you can fix that by opening up the back and pressing the red cutout button which will restore hot air.
Jan 30, 2015 | Bosch Dryers
What are the error code for F09 and E02. for maxima maytag
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Dec 09, 2014 | Maytag MHW6000XG Maxima High-Efficiency...
ERROR CODE F09
A typical HE3 Kenmore Elite washer the F09 code indicates and overflow has been sensed. This can be because of suds or a failure of the pump or pressure switch.
Suds is a common problem with the newer 2X-3X super concentrated detergents.
A pump that is partially blocked might cause this error
Oct 06, 2014 | Washing Machines
Error code f09 e01
Did you clean the tube that goes from the tub to the drain filter then the drain pump it is behind the front panel also make sure there is nothing in the drain pump stopping the impeller from turning.
Jan 29, 2014 | Maytag MHW6000XG Maxima High-Efficiency...
Getting E02 and F09 error codes on my Maytag Maxima MHW6000XW front load washer
Here is the manual. Hope it helps: http://www.applianceblog.com/mainforums/attachment.php?s=001fc13abc99c02a4aa812a23c01ac7e&attachmentid=13030&d=1381289434
Jan 05, 2014 | Maytag MHW6000XW - MaximaTM...
Maytag Maxima E05 & F06 error codes on washer
My F06 E05 error returns within a moment of clearing all errors. My Maxima has no tach line from the M to the MCU. MCU commo fault is a different error. So does anyone except Maytag really know what this error is? And Maytag only wants to send a service guy to bleed some money from you.
Oct 21, 2013 | Maytag Washing Machines
Washing Machines Logo
3,120 people viewed this question
Top Washing Machines Experts
