Question about Exercise & Fitness
Treadmill blowing electrics when switched on - Exercise & Fitness
    Top Expert:
  • 12,223 Answers
Step 1:
1) please use desk lamp and connect in outlet wall, where the treadmill is connected.
2) if the breaker or fuse is blown, the problem is the outlet wall.
3) Test the wire ground with DVOM, if there are touching with another wires inside of the outlet
4) test the another wires white + black, if there are touching, or there connecting with the carcase from the outlet and repair.
Step 2:
1) if the problem if the machine: please test the power cord use the DVOM for continuity
see the video for measure continuity
2) test the main switch from treadmill
3) test the reset switch for continuity
4) test the fuse +c.breaker for faulty with contunuity and repair
5) test the power supply continuit see the block diagram
treadmill blowing electrics when switched on - 1_7_2013_4_33_20_pm.gif1_7_2013_4_33_45_pm.jpg
Step 3:
please test the main motor for open or faulty see my personal TIPS for motor help.
2) test the output main board , for input voltage motor, if there are NOT the board is faulty,replace the boaatd use the DVOM for measure Voltage.
use the diagram above mentioned.
Posted on Jan 07, 2013
Why is my treadmill not working, moved it from my garage into one of me bedrooms , took the power socket wires out now it isn't working
You may have too much on at once. You should contact an electrician to evaluate the electrical current going to the breaker from that circuit.
Jun 01, 2016 | Reebok TR2 PremierRun Treadmill
Fuse keeps blowing immediately when switching on the treadmill, why does this keep happening?
A fuse is designed to prevent excessive current from flowing into a circuit. If the latter is not protected by the fuse, the excessive current can either cause some serious damage or the excessive current can overheat parts and perhaps result in a fire.
So, you are drawing too much current and that explains the small plume of smoke you experienced. If an electric motor runs slow because of excessive friction or load, it will use too much current, overheat and burn out the windings. Disconnect the motor and attempt to run the unit with the motor disencumbered. If the new fuse does not blow, then the problem is with the drive mechanism. If fuse blows, the problem is with the electronics and not the motor.
Aug 26, 2015 | Exercise & Fitness
Second hand Nordictrack.exp.1000, was running.only.13min...shut.down...checked electrical outlets...treadmill completely.shut down?
did you check the breaker switch. it is either by the main power switch or is part of the power switch. follow the cord to the treadmill and check
Jul 29, 2014 | Exercise & Fitness
Life Fitness 4000 repeatedly blows outlet circuit breaker
If there was a fuse in the treadmill it certainly wouldn't cause your main circuit breaker to blow. It sounds like the motor burnt out and shorted- which is causing your house circuit breaker to blow. There is a chance that the ball caused some other damage that is creating the short but my bet is on a burnt out motor. You would need to disassemble the unit and test for short circuits to verify.
Mar 04, 2014 | Life Fitness Lifefitness 4000 Treadmill...
GE3100T treadmill stopped working
HI,
All the treadmills have a power switch with Auto reset. If there s any overload detected it will automatically reset to off position To prevent any further damages. Just check the power switch of the treadmill. If its it off position then turn it one and check the treadmill. If the switch again rest to off position then try to call for a tech to repair the treadmill.
Ajin
Feb 23, 2013 | Exercise & Fitness
I have a T700 treadmill and the breaker blowed. I got a another breaker but it also blowed. What can be making the breakers blow ?
Hello, what do you mean by the breaker is blowing? The one in the fuse box or the switch on the back of the treadmill?
If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
Feb 06, 2011 | Horizon Exercise & Fitness
Treadmill electical issue: My Spirit SR275 Programmable treadmill blows the panel electrical fuse for our workout room when I start the belt. I can operate other treadmill control functions without blowing...
A treadmill has a high current draw -- it should be on a dedicated 15 amp-circuit -- if sharing a cricuit, it's not unusual, from time to time, for it to trip a breaker or blow a fuse in the main panel.
Charlie
Jan 12, 2011 | Kitchen Ranges
When I turn on my treadmill it sparks and blows my gfci
Sparking means you have one of the electrical wires insulation broken or missing, causing a 'short'. check around the spark area for an exposed wire. if it sparks where you plug it in then the short could be any where along the electrical cord.
One other possibility could be a bad receptacle, try plugging something else into the receptacle, if it sparks also have the receptacle changed.
Apr 28, 2009 | Nordic Track NordicTrack Treadmill, A2550
York treadmill
Depending on where you let the smoke out, but I would say yes. Remove the covers, I would look at the lower board first see the blackened areas. But the important question is why did it blow in the first place?
Gerritt
Serving the Twin Cities
Mar 12, 2009 | York Exercise & Fitness
Exercise & Fitness Logo
94 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
