Question about GE (PSS26MSRSS) Side by Side Refrigerator
Both sides freezing in side by side Monograam
My controls are not working. I set it on the correct temperature and it goes right back to 22 in the refrigerator side
  • 700 Answers
Sound like your thermostat is bad. take the model number and the make to the parts house. They will be able to get you the correct one for your unit. then the replacment is rather easy.
Posted on Jan 20, 2009
Illogical ADC assembly (updated info)
Check your coils to see if they are dirty. If they are underneath the refrigerator you can vacuum them as best you can, or if you have access to an air compressor, you could try blowing them clean. Too much dirt on the coils can make you unit work harder and cause warmer temps. What is your temperature in the freezer section. You only need 32 degrees to freeze things, but it should be down below 10 degrees for everything else to work right. Hope this helps!
Aug 05, 2015 | Refrigerators
Why does my Igloo FRW700 wine cooler always cool to 0 Celsius or 32F if you prefer regardless of the temperature setting?
It sounds like your temperature control is not functioning correctly. Most temp controls still have a small mercury switch somewhere in the cooling circuitry. I would hazard a guess that if you can turn the dial to different temp settings and it always goes to freezing at 0C or 32F that your temp switch is either bad or the mercury switch (which tips forward or back depending on the setting to make contact and start the compressor) is stuck somehow so that it always sets to the lowest possible setting for your Wine Cooler. Without actually looking inside and testing circuits, that's my best estimation of your issue. Hope that provides you with a starting point to talk to someone who can help you repair it.
May 20, 2014 | GE Profile 26.6 cu. ft. Side-by-Side...
I have a Samsung Cooltech Plus fridge that seems not be able regulate the temperature correctly. At times the temparature is 22 celcius and food gets spoilt, I tried switching it off and on again but that...
Keep your hand on condenser coil if it's visible or left and or right side body of the fridge. If you feel hot the gas is o.k. Otherwise no gas or chock. You have to repair and refill the gas.
Dec 08, 2010 | Samsung CoolTech Plus / Basic Bottom Mount...
Proper refrigerant levels for Amana Side by Side refrigerator
Hi, normally the suction pressure on a refrigerant -22 system will be between 60 pounds gauge pressure (which keeps it above freezing point) and about 80 pounds. This depends on the temperature condition.Make sure that the superheat and subcooling are correct to see what is to be considered normal for the conditions you have present.
Take care
Jun 03, 2010 | Amana 22.6 cu. ft. Side-By-Side...
GE GSS25LGMA refrigirator/freezer refrigirator side is freezing
There is an electrically activated air dampener in the upper left back side of the refrigerator section which most likely has broken (in the open position), allowing cold air from the freezer to continue to enter the fresh foods section. Replace the dampener assembly.
Mar 29, 2010 | Refrigerators
Evap fan stops running/low cooling, Unplug Frig Evap fan runs
Is there anything obstructing the fan area, ice build up ? It is normal for your freezer to get warm if evap fan is not working, it is essential for it to work :) A defrost cycle should kick on a timer or as needed (adaptive) and there should not be excessive frost buildup that it blocks your evap fan. I would have suggested you unplug your refrigerator for about 10 minutes and see if that resets your control board - if not, then you will need service - either replacing motor assembly or a faulty control board.
Aug 22, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ge fridge GSS25LFGww, fridge part freezing food
Hi, Change the controls back to normal settings. Make sure the freezer is getting 0 to 5 above. If the freezer is getting cold enough, try and turn the cold control to 1 and see if the refrigerator shuts off. It sounds like the cold control in not working properly and will need to be replaced. NOTE: The freezer temp has to be right temp or the fresh food side will not work proper.
I hope this helps. Please let me know if I can assist you further.
Vic
May 30, 2009 | GE GSS25JFM Side by Side Refrigerator
Samsung RS2534WW freezer not working properly
We had to reset the temperature, and what we did was hold the power freeze and the power cool button in for about 12 seconds. It flashed and reset it. My refrigerator still isn't working right but it seemed to reset the temp. I'm not positive this will work for you or not, but may be worth a try.
Jan 29, 2009 | Samsung RS2534 Side by Side Refrigerator
Bottom Door Shelves and Vegetable Crispers Freezing up
I just had a similar problem, and the bottoms of both sides were cold but the top shelves were warm. I found that the condenser fan, the fan right above the cooling coils was not working. This fan circulates the cold air and if it's not working it can't move the cold air to the top or over to the refrigerator side. Open the freezer door and press the switch that tells the computer the door is closed (so the light goes out), if the fan doesn't come on shortly, or only sputters that could be the problem. You will need to take out the back cover over the coils, the ice maker tray and auger motor if you have one and some other parts. Play around with the plug where it goes into the side wall, if you can get the fan to come on and off, it's most likely a bad fan motor....about $55 to replace. As you take it apart, be sure to take some digital pics of the process so you can remember how it goes back together!
Jan 12, 2009 | GE GSS20IEPWW / GSS20IEPCC Side by Side...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
