Question about Smeg 24 in. DWF614SS Stainless Steel Free-standing Dishwasher
SMEG DF612FAS DISHWASHER E8 ERROR - Smeg 24 in. DWF614SS Stainless Steel Free-standing Dishwasher
3 Suggested Answers
SOURCE: smeg code E8
I have exactly same problem. Have you solved it yet..
Posted on Aug 30, 2008
  • 6 Answers
SOURCE: e8 error code on smeg dishwasher
Thanks to hijoloo for pointing me in the right direction. The offending part is the diverter valve, a paddle inside blocks one of two outlets in turn actuated by a micro switch, a motor and reduction gears. Check switch for continuity with multimeter (ohms) then check motor and gears turn freely by hand. My problem was a stiff paddle due to limescale. Soak in boiling water to free off then oil cog (externally) and rebuild.
Posted on Nov 19, 2011
Error 8 light on. I think all lights flash, then far right light stays on. Recently had issues with it. Not emptying properly. How do I fix it??
6. Troubleshooting
In case of a malfunction, the dishwasher will identify the program by switching on a combination of lights.
When an alrm is present, all the PROGRAMS lights (4) come on, while the PROGRAM PHASES lights (7) identify the error code:
E2
The system which limits the water level inside the dishwasher (safety unit) has been tripped.
E3
The appliance is not able to pump out the water.
E4
Temperature sensor disconnected.
E5
The appliance is not able to take in water.
E6
The appliance is not able to pump out the water from the tank.
E7
The appliance is not able to measure the amount of water loaded accurately (on models with turbine flow-regulator only).
E8
Anomaly in the system which distributes water to the basket (where installed).
56
CODE
E9
PHASES LIGHTS
DESCRIPTION
E1
The anti-flooding system (if installed) has been tripped.
The maximum level of water for loading has been exceeded (on models
Jun 02, 2015 | Smeg 18 in. DWD409SS Built-in Dishwasher
Error 8 . How do I rectify it?
6. Troubleshooting
E2
E3
E4
E5
E6
E7
E8
56
CODE
E9
PHASES LIGHTS
DESCRIPTION
E1
Thjere is something wrong with the distribution. Check for blockages.
E8 error code on smeg dishwasher
turn the washer on its side and open up the bottom black plastic plate, than disconnect the two black hoses from the white pumphouse in the middle of the washer. disconnect the connector and open carefully the housing by removing two screws and the motor. check the switch and clean the white housing. Check also if there is nothing inside the rotorhouse. after this build every thing back and hope that its running. it worked for me. succes!
Jun 07, 2010 | Smeg 24 in. DWD1SSE-1 Built-in Dishwasher
DWF614SS smeg dishwasher E8 error code
hijoloo.
Apr 12, 2010 | Smeg 24 in. DWF614SS Stainless Steel...
Smeg code E8
Aug 17, 2008 | Smeg 24 in. DWD1SSE-1 Built-in Dishwasher
I have a smeg dishwasher which keeps displaying error code 8. I know this has something to do with the water supply to the baskets but have checked and there does not seem to be a blockage. Any help...
Hi
I saw your post today and see your fault was dated back in July 2008. Well its a year late and I had the same problem coming up on my machine SMEG DWI 614, error E8 to be exact. After 6 hours of trying to resolve this cleaning PCB, etc. (one can see its the recession and money is scarce) I finally pulled out the diverter valve, dismantled it and left it in some boiling water with limescale remover. I made sure the plastic teeth in the mechanism could spin properly and inserted back into the machine....
And finally the machine works once again. It was 6 hours of my time but probably saved me +/- £150.
Later
Jul 12, 2008 | Dishwashers
Dishwasher Smeg DWD409SS
Hi
Please go to www.smeg-service.co.uk/support
Jun 22, 2008 | Smeg 18 in. DWD409SS Built-in Dishwasher
Error message on Smeg dishwasher
i have error 1 on our dishwasher any clues ?
Apr 23, 2007 | Smeg 18 in. DWF410SS Slim-Line...
Smeg 24 in. DWF614SS Stainless Steel Free-standing Dishwasher Logo
50 people viewed this question
Top Smeg Dishwashers Experts
Cleverer2
Are you a Smeg Dishwasher Expert? Answer questions, earn points and help others
