Question about NAD C370 2-Channel Amplifier
C370 faint crackling sound left channel
Started a while ago after a party, problem went away for a while, but is back now. Happens on both channels (A and B speakers) but only left channel. Quite faint high frequency almost like a constant whisper. Any thoughts welcome.
  • alexpatel
    alexpatel Jan 08, 2013
    Thanks, but it's an internal problem to the amp causing the interference I think
    Problem Solver:
  • 5 Answers
Have you tried looking at your phono leads,turn volume down until it is low enough that you can still hear the music playing,give the phono leads a turn to see if its a loose connection.if not,try the right channel phono in the left channel to see if this fixes your problem.also you could do the same with your speaker leads and see if that solves the issue.maybe a bad connection is the cause?.it may also help to try and move your cd player away from your amplifier.it could also have been overdriven (played too loud for too long) on the night of the party,only you will know if this was the case or not.
Posted on Jan 08, 2013
  • alexpatel
    It's not a bad connection or a the phono cables. It was over driven a lot, up to around 3am I think but soft clipping was on and the speakers can take it so nothing was broken as such. Yesterday it stopped, today it has come back. Sometimes when I turn the amp off and on it's ok for a while then starts again.
VOTIT
  • 2071 Answers
SOURCE: NAD C370 problem
Sounds like a headphones and the power is there,of course power supply is good because there is a little sounds.This is the most common problem of the power amp.section.The solder holding the IC of that power amp.is crack you better reheat or resolder it.The cause of cracking is the vibration and temperature changing it tooks how many years that's crack comes out.The big IC there which you going to reheat is the STK IC.If nothinng improvments happen,you better change that IC,so better performance comes out,.
Posted on Jun 17, 2008
Grubhead
  • 5190 Answers
SOURCE: NAD C370 Right channel distortion
Sounds like you have lost the power amp transistor(s) or IC for this channel.
Posted on Feb 16, 2009
petraman7
  • 1175 Answers
SOURCE: no sound from amplifier on both channels
Hi...
All the main power supply capacitors need to be replaced.
I'm figuring it's an older unit?
Let me know
Thanks,
Scott
Posted on Mar 24, 2009
  • 4234 Answers
SOURCE: Hi, I have a second hand NAD 3240PE amplifier, the
Crackling is usually a dirty control. Try using an electronics cleaner (with lubricant) and spray out all of the controls and switches. With the unit off, work the controls and switches back and forth to "spread" the lubricant. I would spray, work and spray again.
Update this with the results and also see if the crackling is related to the overall volume level. If tied to the volume level, there could be a transistor inside that is breaking down and causing distortion.
Dan
Posted on Dec 28, 2009
  • 185 Answers
SOURCE: my NAD C350 amp only powers one speaker channel
over heating is a sign of overloading or over bias
Posted on May 27, 2010
Why i can hear faint sound on my mixing amplifier
Depends on what sound it is. If it's a hum, then it could be a fault. If the hum is on one channel then the place to look is that channel. You can compare the good channel with the bad one for clues as to what.
If it is in both channels then you are looking at the power supply. Or something common to both channels.
Hum is most often caused by Electrolytic Capacitors.
Crackling noises are caused by resistors, or transistors, or IC's.
Jul 01, 2016 | Audio Players & Recorders
Left speaker not working, system crackles if left side is active, alright when left side shut down.
Get a meter and check the resistance on the speaker. Looks like a speaker may be blown but with the description of the crackle noise from the slide controls you might have a bad pot in the unit or the pot has come loose from the board. This could explain why the speaker blew out
Jul 30, 2015 | Behringer Europort EPA150 Ultra-Compact...
Why does the left channel of mixer randomly crackle, distort, and/or cut-out?
left channel control pot dirty most likely. is there a slider type pot on channel? this would have to be cleaned with dustoff spray.
May 06, 2012 | Behringer Music
Hi, I get very intermittent hissing/crackling from the left channel of my NAD C370. I've replaced the speaker wire and the wire that I'm using for bridges on my AE Evo 3 speakers which seems to have...
Could be caused by a burnt resistor in the channel of the main power amp. You should be able to see it. It might have been caused by the faulty speaker wires.
Oct 07, 2017 | Audio Players & Recorders
Losing the right channel
usually this would indicate a dry joint inside or some other temp related intermittent fault, component problem. Take it to a tech and tell them what happens
Sep 17, 2009 | NAD C370 2-Channel Amplifier
Channel 2 crackles
Make sure your speaker wiring does not come close to the 12v power cable running for your amplifier. If your amplifier's 12v power cable runs on the drivers side of the vehicle, run your speaker cables on the passengers side and make sure your tweeters have a high pass filter to stop any pickup of engine sound (When you are driving you *WILL* notice it at high RPM. a HPF (High Pass Filter) will also stop those nasty hissing sounds on S's.
Feb 11, 2009 | Alpine PDX-4.100 Car Audio Amplifier
Speakers crackle, then sporadically stop
Sounds like an amplifer fault. Many of these Midi system use a large black IC attached to a metal heatsink. They control both the power amp and pre amp on both channels. When they go wrong they can cause all sorts of effects,
If you can repair things I would look at that. If not get ready for a large bill. If it's the IC some are expensive, it does most of the work!
Jan 25, 2009 | Sony CMT-HP7 CD Shelf System
Aug 29, 2008 | NAD C370 2-Channel Amplifier
No output from left channel after crackling sound
Marantz SR 5200/6200 lost audio or crackling on left or right channel except in mode s-direct is now fixed !
The root cause is a defective inegrated circuit on DSP board (the one with digital inputs). To fix it change the chip CS4391 by a new one or better by the improved version CS4392. On my device a capacitor was cut close to this IC : replace one 1uF after changing the IC. For any question search me with my callsing "F5RCT"; i have a spare IC for the one who is able to change it !
I'm amateur radio and engineer
Jul 08, 2007 | Marantz SR-4200 Receiver
After a while the system starts crackling and eventually sound deteriorates to thundering in speakers
Hi, I have exactly the same prob and I belive that it is in the amp module?! I am going to take mine in for repair as my other sony HT amp has just give up the ghost, (STR-DE435), it has a protector prob and is probably not worth repairing, although it is a great amp. If anyone knows the solution to this prob it would be great to hear it!!!
Nov 21, 2006 | Sony DAV-SA30 System
NAD C370 2-Channel Amplifier Logo
197 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
