Question about Lenovo ThinkCentre M57p Small Form Factor PC - Intel Core 2 Duo E6550
Lenovo ThinkCentre Intel Core 2 Due do not want to start up,what do i do?
It just beeps then go back to reloading.
  • Lenovo Master
  • 27,725 Answers
The beeps are post during post the very first work is done by the ram,all the memory in the ram is first transferred to the hard disk,and remains active untill turned off. WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Make sure that your RAM and Cmos battery have secure dust free seatings some Motherboards cmos batteries are soldered in. Do not use solvent that may attract dust and never poke things like cotton buds in to slots. lightly rub an alcohol (Methylated Spirits) on a cloth not to hard let the alcohol do the work on the copper gold or silver tabs Allow the pins to dry. They will air dry in a matter of minutes If reseating the memory did not resolve the issue try swapping the location of the memory. If you have only one stick of memory in the computer try moving it to another slot and then boot the computer. Check the memory module and memory slot contacts. They are either copper tin or gold. The colour will tell you which they are. Mixing tin and gold can result in corrosion that prevents proper contact. Look for any sign of physical damage to the memory module, memory slots or the motherboard.
Reseat the memory modules. You should hear an audible click when they are in place. Do not use too much force to reseat the memory module in to the slot this can cause damage to the module, slot or motherboard. The hardware that you are trying to access is damaged or failing.
There is a connection problem such as a bad cable for internal hard drives
Test all power and data leads that attach to your hard drive SATA
the leads from your MOTHERBOARD TO THE HARD DRIVE make sure they have a secure dust free connections and are not faulty. Make sure all leads that are attached to your drives dvd\cd and floppy (If Applicable) have secure connections and are not faulty.
Computers need Power and Data to travel through every working device and continue an uninterrupted cycle and have an end so any faulty leads will end up with a computer error.
Could be a problem with the Hard Drive or the Hard drives PCB http://www.onepcbsolution.com/ Hope this helps.
Posted on Jan 09, 2013
I have lenovo thinkcentre A57, i can't access in bios setup while pressing F1, F8 or F12, when i'm pressing any of them the computer continue to boot in a black screen. Sincerely: Juls
To start the Setup Utility program, do the following:
1.
If your computer is already on when you start this procedure, turn off the
computer.
2.
Repeatedly press and release the F1 key when turning on the computer. When
you hear multiple beeps or see a logo screen, release the F1 key.
Note:
If a Power-On Password or an Administrator Password has been set, the
Setup Utility program menu is not displayed until you type the correct
password.
Jun 25, 2015 | Lenovo ThinkCentre A57 Desktop - Intel...
Intel Core 2 Duo E6550 audio drivers
on the Lenovo support pages I found three audio drivers for your system (thanks for machine details) they depend on your o/s, and can be found here (select drivers > audio, you can you can type your os in the box to give only result)
http://support.lenovo.com/gb/en/products/desktops-and-all-in-ones/thinkcentre-m-series-desktops/thinkcentre-m57
18.December.2014
May 30, 2014 | IBM Lenovo ThinkCentre M57 - Intel Core 2...
After i change the processor dual core 1.80ghz on the IBM thinkcentre M 55e 9632 series the monitor only showing, cpu=1processors detected,cores per processors=2 intel pentium dual cpu 2160 1.80ghz 1527...
HI,
I am sharing some general info:-
If you are change processor no problem, some point see you like after change processor any beep sound, processor more hitting.
Second check it *********** board power come or not, your display cheap more hitting or not. Check RAM proper connect, your all cable proper connection. If all things ok then may be your PC not supported processor.
Thanks..
Oct 14, 2013 | Lenovo ThinkCentre M55e 9632 PC Desktop
Send your email address to me by Fixya comment. I've audio drivers. Let me know, whether can I send it to you by return mail.
Jul 08, 2012 | IBM Lenovo ThinkCentre M57 - Intel Core 2...
I want to get LAN Drivers for Windows XP and nothing more.
There are 3 different types of LAN chips in a Lenovo ThinkCentre M55p : Broadcom, Realtek and IBM. Install this and run it
http://www.piriform.com/speccy
it will tell you which is in yours, then go to the site of the manufacturer of the chip and get the generic driver.
May 14, 2011 | Lenovo ThinkCentre M55p Desktop - Intel...
4 beeps and no screen when i turn on my enovo desktop
One long beep followed by three short beeps means that either the video card isn't installed or the memory on the video card is bad. Reseating or replacing the video card will typically fix the cause of this Intel beep code.
Mar 10, 2011 | Lenovo ThinkCentre M55 Desktop Core 2 Duo...
Have Thinkcentre which boots in Win 7 and 2 Win XP
Try to re-install 2 Operating systems use this order,
1,Install windows XP by booting the XP cd,
2,and then install Win 7 by booting from Win 7 cd.
Then while you restart computer there will be a prompt menu asking to select OS to start. Thanks
Jul 25, 2010 | Lenovo ThinkCentre M57 Desktop - Intel...
Lenovo ThinkCentre M57p Small Form Factor PC - Intel Core 2 Duo E6550 Logo
52 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
rey francis basa
rey francis basa
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
