Question about Cell Phones
Vol. control not available with this accessory error
I faced the same problem with Nokia 110 after using a headset. With or without headset this problem shows up while changing volume during a call in every profile.
Finally, I restored this with "restore factory setting"...but I dare not to use a headset again before knowing the solution. Please Help!
send me the solution: senbihan@gmail.com
Thanx,
Posted on Jan 28, 2013
When calling my number the answering message is only partial then the phone disconnects will not allow a message to be left
Hello, it seems that the answering mode is set to announcement only, to change to answering machine, at base station press Menu and Vol + or Vol - to select answering machine, again press menu and Vol + or Vol - to select answering modes, ANNC & REC means answering machine, ANNC ONLY, only plays the recorded greeting, press menu to save selection.
Jun 25, 2015 | Motorola Mobility L702C DECT 6.0 Telephone
How do you access call waiting while on an existing call?
Hi, you need to adjust flash time, by default is 600ms (0.6 seconds) the options are from 90ms (shorter) to 700ms (longest). To do it , go to base, press MENU and then VOL + or VOL - to select SETTINGS, press MENU again and VOL + or VOL - to select FLASH TIME , then press again MENU and VOL + or VOL - to select flash time you want, press MENU to save. If none works you should ask your phone company about flash time value or if call waiting and call hold are active on your line and if they require any special operation or code to use them.
Jun 04, 2014 | Motorola Mobility L702C DECT 6.0 Telephone
We have a 3.5year c30 volvo and have recently had a problem with radio where it plays at maximum volume and we cannot control. Also notice rear parking sensors also stopped working at the same time. Any...
both accessory were installed at the same time the vol control knob grooves worn out,rear parking sensor not working may be the wire cut out visit to the accessory fitment shop
Sep 21, 2013 | 2010 Volvo C30
I have a 42inch sharp aquos LCD tv and there is no power. The power button keeps blinking. There is no picture and sound. What is the fix to this problem.
Power problem are cause by many reasons, i.e Power supply circuit, Lamp driver circuit and most often the TV detects an error cause by power surges. To protect TV from further damage most LCD TV have protection circuit built internally. If this is the reason of your LCD TV not powering On, an error data must be reset back to zero.
To change data you will need to access the service mode and change the value of lamp error code to zero (0). Entering service mode requires a trained TV technician. Changing data can cause more problem to your television. If you are not qualified to service your television, please do not go to service menu codes. Moreover below are the process, pls do so at your own risk.
* Unplug the TV * Press and hold the {VOL -} + {CH+} buttons located on LCD TV unit (not in remote control) Note: If above didn't work, alternately use (VOL -) + (TV/AV input) buttons located on LCD TV unit (not in remote control) * While holding the above buttons, plug in the TV. * The TV will turn on with the "K" or "K123" appears om screen. * Use {CH+} {CH -} buttons to go and display the service menu. Note: If above didn't work, alternately use (VOL -) + (CH -) buttons. * Search for "LAMP ERROR menu" from the displayed service menu by using "up or Down cursor" from remote control, or alternatively use "CH - or CH+ to select "LAMP ERROR" * change it to zero (0) value, using {VOL+} or (VOL -) on remote control. * Turn the set off to exit the Service Menu.
Jul 03, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
TV dead other than green flashing light
The problem might be cause by lamp error, need to access the service mode to change the value of lamp error code to zero (0). Entering service mode requires a trained TV technician. Changing data can cause more problem to your television. If you are not qualified to service your television, please do not go to service menu codes. Moreover below are the process, pls do so at your own risk.
* Unplug the TV
Jul 03, 2011 | Sharp AQUOS LC-32D44U 32 in. LCD TV
Says there was a format error has music on it but won't play
The Format Error will get displayed in the Walkman Player when the unit is Formatted using the format utility in windows explorer or with other internal malfunction.
To resolve the issue, try resetting and then perform the Formatting the In-built Memory option in the Walkman player.
To reset the Walkman, press the RESET button near the USB Jack for more than 1 second with a thin instrument such as a paper clip.
If the issue persists, FORMAT the Walkman.
To FORMAT the Walkman, press and hold the MENU button in Stop mode until the SEARCH Menu appears.
Then, use the control Jog to select Advanced Menu and press > VOL to confirm.
Again, use the control jog to select FORMAT and press > VOL to confirm.
Now, select OK and press > VOL to confirm.
Formatting appears and starts formatting the Walkman.
When the Formatting complete, COMPLETE appears.
Press the > VOL button to return back to the playback screen.
After Formatting, download the MP3 File Manager Application to transfer the songs from the Computer to the Walkman.
This will resolve the issue.
Thanks for using FixYa.
Dec 08, 2010 | Sony Walkman Bean NW-E307 MP3 Player
How do I do get to the set up mode using controls on the TV set? Want to do a channel search
Hello
To autotune do the following steps.
1.1 Press MENU to access MAIN MENU screen,
then press CH UP (8) or DOWN (9) to
move the " " mark to "SET UP".
1.2 Press VOL (+) or (-) to access SET UP
mode, then press CH UP (8) or DOWN (9)
to move the " " mark to "CH SETTING".
1.3 Press VOL (+) or (-) to access CH
SETTING screen.
1.4 Press CH UP (8) or DOWN (9) to move
the " " mark to "CH SEARCH", then press
VOL (+) or (-) to access CH SEARCH
mode.
START
2.1 Press VOL (+). The tuner will search
through all available channels in your area
and add them into the TV's memory.
STOP
2.2 Press VOL (-). CH SEARCH will stop at
the current channel and will not add any
higher channels.
2.3 Press MENU to exit.
Nov 21, 2010 | Sharp 25K-S180 25" TV
Low volume sound
your better check the volume control of your computer....i mean the vol contrl on the start menu-accessories........
Feb 02, 2010 | Insignia 2.1 Speaker System (3-Piece)
Trying to get it to run in vista and get an error "illegal function call"
In most cases Illegal Function Call Errors (or General Protection Faults) are caused by Windows Memory leaks causing insufficient memory to be available to perform the requested function
Dec 20, 2009 | eMedia Music Corporation Guitar Songs Vol....
I NEED A CODE FOR SKY REMOTE
Hi.
Here available codes for Sky Remote: sky remote codes
Nov 05, 2009 | Televison & Video
Cell Phones Logo
79 people viewed this question
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
