Question about Frigidaire Affinity ATF6000F Front Load Washer
Front load washer starts an stop - Frigidaire Affinity ATF6000F Front Load Washer
  • Official Brand Answer
  • 4,342 Answers
Hi Tyron Tutwiler - First, does the drain pump make a humming noise? If so, you possibly have a restriction in the drain line. Try setting the cycle to spin only and verify if water pumps out. Also try to rotate the drum manually (when it is not in use) and see if you notice a bumping sound as well. If you do, then the drum is not balanced and probably the bearing and pulley system behind the drum will need repairing. Other possibilities could be are a faulty door lock, timer, pump, or control board not communicating correctly. In this case I would contact a professional to move forward accurately to properly diagnose and repair the washer.
Posted on Jan 09, 2013
Is it normal for the washing machine to start and stop the spinning while the machine is in each cycle? Should it take over an hour to run one wash cycle?
Yes...they use less water...so they start, tumble, then cycle again adding more water. I use the fastest setting on all my clothes which is 1/2 hour. It also does start and stop during spinning to tumble the clothes. It speeds up as it goes thru each stop till it spins real fast. All my clothes wash perfectly on fastest cycle.
Aug 13, 2014 | Bosch Nexxt 100 Series WFMC1001UC Front...
Front load washer, try to spin, but stops altogether and want wash it fills up but want wash
Make sure that you don't over load the washer. As it starts to spin back and forth it is sensing the load balance as the clothes fall back and forth. If it doesn't sense a balanced load because the clothes can't fall back and forth it will not start the wash process. Refuse your load and try again.
Oct 16, 2013 | Frigidaire GLTF2940ES Front Load Washer
Cylce stops after 1st drain before spin out
I have kenmore washer front load H2 after 1st circle of wash it stop and start beeping with code F11. My email address is anarfi1212@ live.com
Jan 21, 2010 | Kenmore HE2 Plus Front Load Washer
Front load washer not spinning correctly
I had the same problem, once I remove the shipping bolts on the back of the machine it worked fine.
Feb 01, 2009 | Maytag Neptune MAH9700 Front Load Washer
Maytag Neptune rinse cycle doesn't start.
cold water valve screen plugged or bad valve, just check it!
Aug 06, 2008 | Maytag Neptune MAH6500A Front Load Washer
GE Adora front load washer overloaded now won't start
Washers - Resetting Electronic Controls on a Washer
If there is a pause in the washer cycle, the controls will lock up. The pause can occur because of a power failure or it was put in the test mode at the factory.
Also, if the washer was stopped before the cycle was complete or the consumer has pushed the stop/pause button to temporarily stop the cycle and the cycle is not reset. Over a period of 24 hours, the washer will pump out and spin, but will stay in the final spin.
To correct the situation, shut off the circuit breaker for 30 seconds or unplug the washer, then turn the timer knob around and back to any position other than final spin. Verify the water is turned on and restore power. This should resolve the issue.
Apr 23, 2008 | GE WSXH208A Front Load Washer
Frigidaire Affinity ATF6000F Front Load Washer Logo
211 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
