Why is my goclever r103 not loading??
When i switch it on, the android word appears but doesn't load
SOURCE: phone not loading g1
You may need to wipe the factory setting. To do so, Turn Off the cellphone, now keep on holding the Home button and turn on the cellphone. It go to the recovery console, now select WIPE or press the short keys mentioned over there and restart cellphone.
Note: You will not loose any data but you may need to resign to google and also may need to install some application.
Thanks and regards,
Anil.B.R
Posted on Oct 06, 2010
  • 20 Answers
SOURCE: The dry sensor cycle will stop after 3 min... I
Try checking the dryer vent to be sure it is not clogged or partially blocked with lint. You may have to replace the sensor if all else is well
Posted on May 15, 2011
  • 6277 Answers
SOURCE: AEG L76650 Front load washer.
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
Posted on Jun 06, 2011
vinzen
  • 217 Answers
SOURCE: I've got Nikon F65. I
I don't know this model but you can try this.Drop the film canister in and pull the film strip out and place on the film advance sprocket.Rotate the sprocket by hand/thumb until film is seated (1 turn). If the auto feed is working you will be OK. 2 other things ,1 of course load film in dark area, 2 check the batteries on the camera first, if they are week your film advance wont work ,Good Luck.
Posted on Jul 29, 2011
  • 263 Answers
SOURCE: Window 7, compaq: it doesn't load cd/dvds
There is a good possabilty that the drive is bad and you might have to replace it with a new one
you can get a new one at NewEgg.com for less then 20.00 Before you order one see if iis SATA or ATA Sata has a small red strap cable attiching it to the mother ATA has a large cable about1.5 inches wide and it is very easy to install
Posted on Aug 26, 2011
Netbook manual goclever R103
SD = Secure Digital - which means there is a small (on one side) slidable lock - if locked, you cannot access the card. Check that as probably needs sliding to free the card for use.
Sep 01, 2014 | Cameras
Tip
How to hire android app develop?
While hiring android app developer, you should remind these things. Hiring a developer who
  • Doesn't Have a Good Sense of Product Behavior
  • Doesn't Own at Least One Good-Looking App on Google Play
  • Doesn't give Poor Time Estimations
  • Doesn't Have Experience with Releasing an App and Publishing It on Google Play
Hire Android App Developers Android App Programmers
on Feb 13, 2018 | Android Apps
Android tablet won't load
http://www.pandawillforum.com/showthread.php?15703-Universal-WM8650-Uberoid-v12-1-(CUSTOM-ROM)
Feb 10, 2013 | Android 7 inch Tablet
I have a Sharp Aquos LCD TV Model LC-32BX6M , when I try to connect a new generation Android TV Box HDMI Out to TV's HDMI input the Android Logo appears and after sometime the screen goes blank t
im not sure but could it be a comparability issue with the device and the wake up signal from the device to the tv? android systems use a Linux based file system, so the problem may be in the tv's input settings. hdmi input from the device to the tv. and then go to tv input mode and see if putting the device in another hdmi port doesn't work.
Oct 15, 2012 | Sharp Aquos Televison & Video
My kenmore front load washer doesn't want to start all lights are working but nothing happens even the door won't lock
your door switch is the problem,where the door latch goes into the machine a little switch sites behind this a safety feature and if this is broke the machine will still switch on but will not work it will need replaced they are cheap.adrianxxx
Jun 02, 2012 | Kenmore 44072 Front Load Washer
Android tablet keeps getting error when trying to connect to the net. process com.andriod.browser has stopped unexpectedly.
Personally I'd flash it. I think you've got something corrupted in your system and its being triggered when you attempt to access the browser. Alternatively you can try downloading a different browser (http://www.4shared.com/android/ki088UbS/Dolphin_Browser_v200.htm) click download now wait the 20 seconds and an apk will show up for you to install. You will have to set your reader to accept outside downloads its in settings. Yea other than that do a full flash. Go to the support section of the cruz website and you'll be following the process for upgrading the firmware.
good luck
Jan 01, 2012 | Velocity Micro Cruz Reader R103
Compaq Presario F761 Won't recognize DVD RW Drive
First try to load the drivers for the system. Go to dell website provide the service tag and try to install the drivers. If this does not work then take the back up of data and do a simple factory restore.Check out my blog Click here
Kindly click skip ad in the top right hand side to view the article
Nov 27, 2011 | Compaq Presario PCCOM2232US Notebook
When I download apps the icon doesn't appear on the screen of the ipod and i can't find the down load but itunes says it there
Si the software up to date? Look to see if any updates are available while connected thru Itunes.
Oct 24, 2011 | Apple iPod touch
Youtube on phone dosen't load up properly and i don't know how to rectify the problem
Note: In 2G YouTube will be very slow.
I'm assuming you have 3G enabled.
Go to Android market. and search for installed applications.
Select Youtube, apply the updates and restart Youtube.
If this doesn't work, Uninstall Youtube and re-install it.
Thanks,
Mr.Maduraikaran.
Oct 15, 2011 | LG GT540 Cell Phone
Computers & Internet Logo
145 people viewed this question
David Payne
David Payne
