Question about Fujitsu (MAN3367MC-P) 36 GB SCSI Hard Drive
Can i remove my jujitsu scsi hard drive from a failed system and use it on a sata system?
This is on a dell precision 530 workstation that shuts down following logging on even occasionally in safe mode. I simply need to get the data off the drive.
2 Suggested Answers
  • 110 Answers
SOURCE: how to recover data from corrupted hard drive?
try other usb port, or other computer and see whether the hdd is detected. If still not, try to go to device manager ( http://www.computerhope.com/issues/ch000833.htm ), and then assign a drive letter to the hdd. After that, try to access it from Computer, if not able to access it, format it (use quick format) and then use this file recovery program called asoftech data recovery to recover your files.
http://www.asoftech.com/articles/free-data-recovery-download.html
Posted on Oct 30, 2012
Upgrade hard drives on 670
There is a 2TB limit with MBR (Master Boot Record), but even a larger drive can be partitioned. So a single 4TB (biggest on the market) drive will look like several drives.
External drives that are bigger than 4TB are really several physical drives combined by an array.
RAID 1 requires optional SCSI drives, cables, and even software?
http://support.dell.com/support/edocs/systems/ws670/en/ug_en/before.htm
Add on SATA 3 cards to PCI are not a good idea if you are looking for speed. They just bottlenecks the throughput.
Oct 22, 2012 | Dell Precision Workstation 670 PC Desktop
Can I boot from a SATA drive and access pre-existing SCSI Drives?
You need to install the driver of your scsi controller for win7/64. Then you'll see your datas on win7.
Jul 08, 2012 | Dell Precision Workstation 670 PC Desktop
I cant get my Dell Precision 690 to recognise a hard drive
Double check the bois to ensure you have all the Sata ports turned on. I have found in some Dell computers the only ports turned on are the ones in use when shipped from the factory.
Feb 01, 2012 | Dell Precision Workstation 690 - 750W...
Need internal drive for dell precision 670
You have two options with the WS670. You can use standard IDE (PATA) drives or you can use SCSI drives (up to Ultra320). If you are already using SCSI HDDs in the system, you would most likely be best served by sticking with SCSI for your hard disks and leaving IDE for your optical drives which I believe is the default configuration, but it can be modified when ordering the systems. If you are already using LVD drives, just go ahead and slap another one in of any size. If you want to use IDE, your maximum size will be dicated by the chipset used in the system (information not available on the Dell website).
Jun 09, 2009 | Dell Precision Workstation 670 PC Desktop
Can't fin hard drive in bios
try switching the jumper pins on the hard drive to slave instead of master theirs alot of stuff that can cause this like the hard drive might have died but thats only one reason and that might not be it at all
May 28, 2009 | Dell Computers & Internet
Hard drive is not detecting intermediately
try a different SATA power connection, sometimes they work loose and this issue occurs.
Apr 03, 2009 | Dell Precision T3400 PC Desktop
Dell Precision 670 throws "BIOS not installed!" message
i think this means that the harddrive needs to be refoarmated as the bios sees no logical drive in which the boot.ini file resides
Sep 01, 2008 | Dell Precision Workstation 670 PC Desktop
Dell precision 670
Ok go to bios setup and then "load bios default" and press "F10" to save and exit. i will tell you in case this not work just tell me.
Jan 18, 2008 | Dell Precision Workstation 670 PC Desktop
Fujitsu (MAN3367MC-P) 36 GB SCSI Hard Drive Logo
22 people viewed this question
Top Fujitsu Computers & Internet Experts
Computer Links
Tony
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
