Question about Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher
Kenmore Elite dishwasher will not drain
Wash cycle works fine however drain pump will not engage at end of cycle or when cancel/drain button is pressed. I can hear the electronic click when the button is pressed but drain motor does not start.
  • Bill Lorenzen Jan 09, 2013
    I took everything apart and placed a shop vac on the dump line. I can only assume that thesump pump works under low pressure and the slightest blockake would not allow the pump to run. Seems to be working fine now that I have put it all back together.
    Prodigy:
    An expert who has answered 500 questions.
  • Kenmore Expert
  • 644 Answers
If the drain pump won't run, the most common cause is something hard (like a piece of glass or hard plastic) got into the pump and is blocking the impeller. If you want to fix it yourself, first unpug the dishwasher. Then you will need to either siphon the water out of the sump area or use a wet vac to suck out the water from the sump area. Then remove the toe-kick panel so you can get to the underside of the dishwasher. Depending on the model, you may be able to access the drain pump from there, or you may have to pull the dishwasher out. Then you can remove the end of the drain hose and check the area there. If that's okay, you can remove the drain pump by finding and pressing on the release button or lever, and turning it 1/8 turn counter-clockwise, If there's an obstruction, you will find it now. If no obstruction, then you probably have a bad drain pump and will need to replace it.
Posted on Mar 05, 2015
  • 11 Answers
SOURCE: Model 17019 ~ Clean light flashing
try pushing heat dry then normal back to back three times. then start. this should clear it up but only temporarily. you have a problem in your heat element or your control board.
Posted on Mar 21, 2007
SOURCE: Kenmore Ultra Wash Dishwasher LIghts are blinking....
I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
Posted on Mar 22, 2008
  • 530 Answers
SOURCE: Kenmore Ultra Wash Dishwasher Problem
there is no real way of checking the keypad. Not with a meter but if you push normal wash for example and it does not respond this usually means that you have a bad keypad
Posted on Jan 06, 2009
  • 127 Answers
SOURCE: kenmore dishwasher has stopped draining.
remove the kick panel below the door, place a pan, etc under where the drain hose connects to the drain extension tube, and slide the clamp back some so you can slide the hose off of the extension tube (white plastic tube) and drain any excess fluid into the aforementioned pan, etc., then unscrew the extension tube and check for plugs, or restrictions.
the sump may also be pluged beneath the strainer assembly, and that requires removing the lower spray arm, the water tube that runs up the inside back of the unit, and the upper parts of the assembly below them to access the drain/pump sump area.
last but not least the impeller is jamed and might be able to be freed by removing whatever has lodged within there..
ya never know...
best of luck,
ttfn
Posted on Oct 25, 2009
  • 127 Answers
SOURCE: kenmore dishwasher ultra was quiet guard 3 model
that would be model # 66516012403 correct??
you may have inadvertently set the lock on function..
check this out from your manual...
Lock On
Use the Lock On to prevent unintended use of the dishwasher
between cycles. You can also use the lock feature to prevent
unintended cycle or option changes during a cycle.
When LOCK ON is lit, all buttons are disabled.
NOTE: The dishwasher door can be opened while the controls
are locked. However, the lock must be turned off and the Start/
Resume button pressed to resume the cycle.
To turn on the Lock
Press and hold HEATED DRY for 4 seconds. LOCK ON glows.
If you press any pad while your dishwasher is locked, the light
flashes 3 times.
NOTE: If the Heated Dry option is selected, the light will
temporarily turn off until Lock On glows.
To turn off the Lock
Press and hold HEATED DRY for 4 seconds. The light turns off.
hope this helps,
best of luck,
ttfn
Sears kenmore elite dishwasher does not drain completely
Look at the control panel and you will see a button that says "Cancel" and "Drain" Press the button after the wash cycle has completed and the machine will drain completely.
Dec 28, 2016 | Kenmore Dishwashers
Kenmore elite dishwasher manual
The cancel light is on because the cycle maybe paused or canceled. The lit red button should say Cancel/Drain. If you already tried to press start and if it won't finish the cycle then try pressing the Cancel/Drain to drain and start over.
Aug 15, 2014 | Kenmore Elite Stainless Steel 24" BuiltIn...
Kenmore elite dishwasher model 630 Smart Wash light is flashing
You may want to try:
Press a series of four buttons in quick succession. Press "Heated Dry," "Normal Wash," "Heated Dry" and "Normal Wash" to instruct your Kenmore dishwasher to run a short diagnostic test.
Wait for two minutes while your Kenmore dishwasher runs its diagnostic test.
Press the "Cancel/Drain" button once your dishwasher has completed its diagnostic test. This should reset your dishwasher control panel.
Check to make sure that there's no standing water in the bottom of your dishwasher. Standing water in your dishwasher may indicate that your dishwasher has stopped mid-cycle. You will need to press the "Cancel/Drain" button before you can reset your dishwasher control panel.
Dec 18, 2013 | Dishwashers
Kenmore 665 Dishwasher
Sound like you have a bad control console, which will need to be replaced.
Apr 08, 2012 | Kenmore 13742 / 13744 / 13749 Built-in...
665-110733490 Was working fine ,last night shut it off w/water in the bottom.also pushed cancel/drain did not drain.today I ran A wash cycle but after wash still had same amount water in...
Hello & Welcome to FixYa
Dishwasher not draining completely problem usually occurs due to clogged/blocked drain hose-filter assembly or the drain pump not working. First try to clean the drain hose and drain pump filter located inside the front bottom panel for any clogs, then check drain pump operation. Take off the bottom access panel to clean the drain pump filter and hose. If the problem returns after cleaning then it is the drain pump that needs replacement. Please get back to me if you have any other questions.
Kevin
Jun 09, 2011 | Kenmore Dishwashers
Kenmore elite dishwasher, does not get the dishes wet
sounds like wash motor is not going . it will fill and control thinks motor is working . then it will drain wash water / ( drain pump is a different motor ) and then refill and so on .. never washes but fills and drains and heats. ( look for leakage under the motor i'm sure you will find some ..
Nov 22, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Fills, doesn't pump to sprayer, drains on drain only cycle
Sounds like there is still something in the pump. I am 99% certain this unit has a reversable motor.
Jan 26, 2009 | Kenmore 24 in. 16539 Built-in Dishwasher
Bosch Dishwasher won't drain, cancel drain lights blink
when you said "I can run a wash", does the machine act normal for that time frame up to the point of drain? if yes, the pump is fine. sounds more like the micro chip on the board is "confused", but not sure why.
Jun 04, 2007 | Bosch 24 in. SHX99A15UC Stainless Steel...
Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher Logo
79 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
