We have a marantz PM-44SE amplifier and the speakers are really quiet?
    Problem Solver:
  • 5 Answers
Make sure all your speaker connections and your phono lead connections are good and connected properly.also if you have the correct source(input for cd player etc.)pressed in,this could also be the correct speaker setting(a or b speakers)if your amplifier has a+b settings.check your speakers at the back to see if there are any switches,or if they are bi wirable(if they are bi wireable you will need two sets of wires running to both speakers from both speakers (a) and the (b) terminals,as if this was the case and you are only using 1 set of cables then only the treble may be working without any bass or the other way around.you could also look at your phono leadsby giving them a light twist to see if there are bad connections,if not if you can try and ask a friend or neighbour to try the speakers on their sound system and then you will know if its your amp or speakers that have the problem.i suspect it is your amp,if you have tried these things and got nowhere then you may have blown your output transisters and would be better off getting a new amplifier as it would cost too much to repair.only you know when the problem started and if it was by playing the amplifier too loud for too long then the volume dropped right down the it is probably the transisters that have been blown.hope this helps
Posted on Jan 08, 2013
SOURCE: Marantz PM 4000 has cut out
May be the problem solved here :
http://www.audiotoolers.com/ubbt/ubbthreads.php/ubb/showflat/Number/5316/page/1#Post5316
Posted on Dec 04, 2008
mikeymiddles
  • 58 Answers
SOURCE: marantz pm 7200 integ.amplifier
Dear Sushant,    I do not think your use of an equalizer has caused any problems.  I will explain the proper use of the source/direct button.  This button's function is to monitor the output of a recorder connected to the record outputs of your amp.  When this button is pressed on the sound going to the speakers comes direct from the "source" (cd, radio tuner, phonograph etc.) when in the off position you can monitor the recording of whatever source is being recorded via the tape deck.  This switch must be off to record through the amps record outputs.    To test this, put a blank tape in the tape deck, choose the source as phono and place the dec in record/pause.  With the source direct button pressed on you should hear a change in volume when moving the amp's volume knob only.  When source direct is off you will be able to hear the output of the tape deck, so adjusting the tape deck's record level will also affect the volume coming out of the speakers.  more record level in/ more level out.!    Below is copied from page 9 of your user operation manual for Marantz's explanation of the source/direct button.  image.tiff
best of wishes, Michael Mittelsdorf
Posted on Jan 05, 2009
  • 398 Answers
SOURCE: How do I connect a subwoofer to an amplifier marantz pm-68
double up the speaker and then use the two extra screw to hook sub and center
Posted on Feb 27, 2009
  • 66 Answers
SOURCE: Marantz Pm-7200 left channel weak compared to the right
hmmm. Let's start by swapping the wires you are using for your speakers. Double check the wire connections first, then take the left and place iton the right and vice versa.
Posted on May 05, 2009
  • 99 Answers
SOURCE: Marantz PM-48 connecting to TV
look on the back of the TV and there should be L/R audio outputs (white & red), connect this to a spare input of your amp via a connecting lead eg. AUX or any other input except PHONO.
hope this helps.
Posted on Jul 02, 2010
Marantz problems
The speakers are 8ohms. Always try using speakers 6 or 4ohms. For B&W 683 on PM 6004 is too low. You should go for PM 7000 or 8000 series to catchup with 683. Also when you increase the volume please decrease the bass as well.
You need 8ohm 55w to 90w or 4ohm 80w to 110w speakers.
Jul 20, 2014 | Marantz PM6004 Integrated Amplifier
No power going into my marantz 44se amp.
Check AC main fuse inside the amp located next to the power transformer, if the fuse is open, just put another and if it blows let the amp as is, because if you put more fuses and blow them you just add more damage to the amp, let me know your results.
Oct 12, 2013 | Marantz Audio Players & Recorders
Sound probem of marantz amplifier at right side.
sure it is not the speaker?
switch them and check
Mar 02, 2010 | Audio Players & Recorders
The fuse keeps blowing in my marantz pm-57 amplifier. It says it takes a T 2.5A 250V fuse. I can only find 2.5A 250V fuses. What relevance is the ''T''.
Goo day sir, the T on the fuse has nothing to do on you marantz fuse blowing up, chances are you amplifier is shorted, check you IC amplifier/power transistor for shorts. Check also your speaker impedance. usually they are 8 ohms. You can use a technician's multitester device to check the impeadance. An imbalance or mismatch speaker can cause a fuse to blow and destroy your amplifier. hope this helps.
Jul 31, 2009 | Marantz PM-15S1 2-Channel Amplifier
May 05, 2009 | Marantz PM7200 2-Channel Amplifier
Feb 10, 2009 | Marantz PM-68 Amplifier
Heat in operation of marantz pm 74d
Sounds like your left channel output transistors are getting weak.
Jan 17, 2009 | Marantz PM-68 Amplifier
Can I remotely control speaker outputs on the Marantz PM 8003?
HI...
You need an 8 ohm stereo "L-pad"
Try partsexpress.com
or
mcmelectronics.com
Dec 21, 2008 | Marantz Audio Players & Recorders
Nov 21, 2008 | Marantz Audio Players & Recorders
hope this helps.
Oct 19, 2008 | Marantz PM-68 Amplifier
176 people viewed this question
 Grubhead
Grubhead
