Question about Sebo X4 Bagged Upright Vacuum
The hose attachment will not fit back into the vacuum it about 2inches not going into the fittmnent
We have been using it for about three months with no problems at all now suddenly we cannot seem to get the pipe to fit back into the cleaner please help thank you
    Scholar:
  • 108 Answers
Did you break the end of the wand off possibly? It should just slide in and out but if you broke the tapered end off it wouldn't fit.
I'll include a link to a page with pictures of what it should look like.
Good Luck!The Vac Dr
http://vacuummedic.com/product.php?id=482
Posted on Jan 15, 2013
2 Suggested Answers
reddevil6
  • 1673 Answers
SOURCE: sebo x5 vacuum cleaner
The full bag light comes on when it is getting full or a blockage in the hose or the dirt inlet by the brush roll. Other then that, there is a circuit board called the computer controller, part #5740ER and is giving you a false reading and causing a shut down.
Posted on Jun 22, 2008
I have the dc 17 animal model and there are no instructions in how to use the attachments,how they connect and so on.I have to assume that this is not an uncommon question considering that the box was...
You can call the Dyson helpline for information on how to fit the attachments. Generally, you can fit them on the wand and the hose (wand - directly on top of the red piece of plastic, hose - take the wand off the back of the vac and press the red button where the hose connects to the wand - this will remove the wand and you can attach the tools to the hose). With a DC17 Animal you probably have a Mini Turbine Head (a tool with its own brushbar - greay with red bristles) - if you have a gray button on it this is probably making you ask how it attaches to your vac - this tool is actually compatible with many other Dyson models but in your case it just fits on top of the hose and/or wand - it doesn't click into anything. As long as the fit is tight/snug, you're good.
Jul 14, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Kirby turns on with hose attachement but not with head attachment
Front of the unit, black switch that is pressed by this plastic protrusion from hose coupling has two parts. It is because ANY generation Kirby has speeds - HIGH for vacuuming with hose and LOW for using it with nozzle.
Looks like the switch went bad (Switch HERE)
We have instructions for replacing it too.
The "funny noise" with hose throws me off a bit though. Check if there is nothing in the hose (put a nickle through it).
Good Luck
May 29, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Where do I connect the hose and it's attachments
You need the suction/blower connector on the hose:
This must be for G4 or G3 model as later models had this part a bit different.
For rest of the attachment go HERE.
I can sell you used FULL G4 attachment set for 99.00
Good Luck,
Rocky
Apr 05, 2009 | Kirby G4 Bagged Upright Vacuum
I havent used my shampooer for over a year, and i am now having t
These are the parts-Tank,tray,brush roll,brushroll housing,belt,hose,foam screen(small,quarter sized plastic screen)large foam air filter,(should be on the air inlet at tank).
Starting with brushroll,install belt over brushroll,and place brushroll in the trayInstall the brushroll housing over the top of tray..Looking thru the back,turn the belt lifter knob until the hook inside picks up the belt.Raise the height adjuster on the Kirby all the way up.Attach the entire assembly to the front of maching,and lock it on.Now turn the belt lifter clockwise until the belt drops onto shaft.Snap the elbow end of hose to tray.Before attaching the other end of hose to tank,make sure the foam screen is fitted onto the small outlet at tank,then install hose.Note:Sometimes the screen will be in the tank end of hose allready.Without this screen,you wont get foam,only solution.Make sure the foam air filter is installed in the large opening at the tank,or dirt will get into tank,clogging it.Install the tank to the blower side of machine.You should be ready to go.Lower the height adjustment all the way down.
Dec 15, 2008 | Kirby G4 Bagged Upright Vacuum
I have borrowed a kirby from my friend and i would like to wash my couches, please would you be so kind as to assist and let me know what tools i would need to use to be able to do so??
You need the upholstery attachment (it looks like a trigger sprayer with a plastic jar attached)You MUST have the foam screen that fits on the front of the trigger,without it,you will only get solution.The trigger sprayer fits on the end of the hose.The other end of the hose fits on the blower end of the machine.You must remove the bag,and attach the hose at this end.The trigger sprayer deposits the foam,and you work the foam in with a soft cloth or brush.When dry,switch the hose to the suction side,and vacuum out the foam.There is also an adapter (about the size of a styrofoam cup) that attaches to the front of the machine to allow it to be used when using the hose on the blower (bag) side.
Dec 14, 2008 | Vacuums
Suction loss when handle is tipped back to clean carpet
can any one help,
Our Dyson Animal vacuum has plenty of suction when it is upright and the attachments are being used off the hose, but when the handle is tipped back to begin cleaning carpets the beater head is getting no suction. As the handle is being tipped back you can hear what sounds like a flapper valve in the body of the vacuum opening and then all the suction just goes away.
Nov 19, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
Eureka Boss - no suction in upright postion
when mine does that I find that the hose is not connected properly where it comes off to use the attachments.
If there is suction there, it is a straight shot to the floor unless it is loose where it fits together.
Jun 04, 2008 | Eureka 5892AVZ Bagless Upright Cyclonic...
Intermittent Power brush
I would first check where the hose attaches to the canister. There are 3 power leads; if one is bent, this might produce what you describe. You might even try wiggling this connection to see if it affects operation.
The other place you might see a problem is where the hose connects to the handle itself. There are 3 wires that attach from the hose. This is a bit tricky to remove as it's basically a force fit and take some effort to remove.
Dec 15, 2007 | Kenmore 22812 Bagged Canister Vacuum
My G3 works with the hose, but not with the Tech Drive
Try removing the nozzle and poking a screwdriver in the little slot for the safety switch and seeing if it runs. Maybe the nozzle's poker isn't pushing it in adequately?
Apr 30, 2007 | Kirby Generation 3 Bagged Upright Vacuum
Sebo X4 Bagged Upright Vacuum Logo
43 people viewed this question
Top Sebo Vacuums Experts
Nick Olsen
Masters Engineering
Level 1 Expert
Are you a Sebo Vacuum Expert? Answer questions, earn points and help others
