Question about FIC VC19 Motherboard
Beep: 6 seconds on, 3 seconds off
This is a new installation. I've been through all the installation instructions in the manual and think I have it right. When I power up, I get a long repeating beep - 6 seconds on and 3 seconds off. The fans all come on. The hard drive powers up. I have a keyboard connected. We have a AGP graphics card, and PCI NIC and USB1 cards. The CPU is a Pentium 4. We have 3 266MHz memory DIMMs (512MB, 256MB, 256MB). All of the above hardware was moved to this motherboard from another motherboard that stopped working (Windows would reboot at random). Any thoughts on how to troubleshoot? Thanks!!
  • arukalas Aug 28, 2008
    I have disconnected all but hard disk and monitor. Still the problem persists. Is there any chance to the glox's Beep: 6 seconds on, 3 seconds off problem if RAM fails or fault in data buses?
  • 432 Answers
Pull all the cards out. Put in the CPU and fan, just one memory chip, the video card and the hard drive. Plug in just the power supply and the powerbutton switch to motherboard. Don't connect anything but the monitor, mouse and keyboard. If you still get beeps, try another memory chip (just one). I don't know the beep codes for your motherboard so we have to do this one step at a time.
Posted on Jun 30, 2007
  • Anonymous Jun 30, 2007
    connect the hard drive the motherboard too. No floppy or cd-rom. Start with bare-bone installation.
SOURCE:
I have bought a used red head safe. It's open but I can't get it to close. Also, I don't have a combination for it and I'd like to make up my own. Can you help me?
Most likely it will not close because the lock has been activated while the door was open. Probably need to take it to a locksmith.
Jan 03, 2017 | Home Security
How do I change the combination on I have a paragon digital lock & safe
TO SET UP OR CHANGE A USER CODE
1. With the door open, locate the red button on the back of the door near the hinge.
2. Press the red button and listen for the beep.
3. Immediately enter your new passcode (3-6 digits long)
4. Immediately after entering your new passcode, press the "A" or "B" button on the keypad. Your new user passcode is now stored.
NOTE:
This safe stores up to 2 passcodes (a user code and a manager code). Entering a third code will erase the
first passcode entered.
SETTING UP OR CHANGING A MANAGER PASSCODE
1. Open your safe with the passcode you wish to change and leave the door ajar.
2. Press the "0" button on the keypad twice. Press the red button, listen for a beep and then enter your new user passcode.
New user passcodes may be 3-6 digits long.
3. Immediately after entering your new code, press the "A" or "B" button on the keypad. Your user code is now changed.
http://www.paragonlockandsafe.com/manuals/mastermanual.pdf
Aug 29, 2014 | Paragon Electronic Digital Safe Jewelry...
CISCO 6248 beep sound
Beep Codes Cause (Depending on RAID Level)
3 seconds on, 1 second off
  • RAID 0: One or more drives offline.
  • RAID 1: Two drives offline.
  • RAID 5: Two or more drives offline.
  • RAID 6: More than two drives offline
1 second on, 1 second off
  • RAID 1: A mirrored drive failed.
  • RAID 5: One drive failed.
  • RAID 6: One or two drives failed.
1 second on, 3 seconds off
A hot spare drive has completed the rebuild process and has been brought into the array.
Jul 24, 2014 | Cisco UCS 6248UP 48-Port Fabric...
I need to reset my combination to my mesa safe
This safe was shipped with a factory Master Code of 1-2-3-4-5-6-7-8.
If you changed the Master Code you will need to use the code you changed it to.
Deleting your current User Codes:
Input * - * lock will beep twice
input 6-6-6-# lock will beep twice
Input current Master Code - # lock will beep twice
Input user number - # lock will beep twice (not user code, user number is which user number you want to delete 1,2,3,4 or 5)
Re-input user number - # light stays green for 3 seconds
Example: * - * - 6 - 6 - 6 - # Master Code - # - 5 - # - 5 #
This will delete user 5
Unsuccessful code change: five beeps, repeat the steps.
Changing User Codes: Code length can be 3 to 8 digits long
Input 4 - 4 - 4 - # lock will beep twice
Input Current User Code - # lock will beep twice
Input User Number - #
Input New User Code - # lock will beep twice
Re-input New User Code - # light stays green for 3 seconds
Example: * - * - 3 - 3 - 3 -# - User Code 2 - # - 2 - # -New User Code - # - New User Code - #
That example will change user code 2.
Unsuccessful Code Change: five beeps, repeat the steps.
There are other things you can do with the MSL-500 lock that comes on the MFL-2014E. You can change the master code, activate user codes, change user codes, delete user codes, set single user or dual user modes (dual user modes requires two user codes to be entered each time you want to open the safe, set the time delay.
The Mesa safe company has a website which does have the operating instructions for the MSL-500 electronic lock. A Google search of "Mesa MSL-500 Operating Instructions" would get you there quickly.
Oct 18, 2013 | Mesa Safes MFL2014E Safe Depository Safe...
Intel 31 3 beep sound solve
3 Beeps usually means a memory issue. If you've recently added or tried to add additional memory to the computer and have started getting these beeps. Remove all new memory you've added to the computer. If the computer works fine after removing the new memory you're encountering either an incompatibility or defective new memory.
Jun 02, 2012 | Intel DG31PR Motherboard
Does the Timex Men's T77862 Expedition Digital Compass Watch allow for military time usage? ie-24 hours, instead of 12 hours
Here is a link to the Timex support page with the download links for all the different instruction manuals:
http://www.timex.com/info/Product_Instruction_Guides_Downloads
And here is the direct link to the manual for the Expedition Digital Compass model:
http://assets.timex.com/user_guides/W215_M179/W215_M179_NA_EN.pdf
To view the Support Page or the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents.
You can download this free at WWW.ADOBE.COM if necessary.
Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.
See page 1 of the manual for instructions which basically read as follows:
1. In TIME mode, press and hold SET/RECALL. Time zone will flash.
2. To set, push + or - to select first or second time zone.
3. Press NEXT. Hour digits flash.
4. Press + or - to change hour including AM/PM. (Scroll through 12 hours to get to AM/PM).
5. Press NEXT. Minute digits flash.
6. Press + or - to change minutes.
7. Press NEXT. Second digits flash.
8. Press + or - to set seconds to zero.
9. Press NEXT. Day of week flashes.
10. Press + to - to change day.
11. Continue pattern to set month, day of month, 12-hour or 24-hour time display, MM.DD or
DD.MM date format, turn hourly CHIME on/off, turn BEEP on/off. If you select BEEP on, a
beep will sound every time you push a button (except INDIGLO).
12. Press DONE to confirm and exit or NEXT to continue and set second time zone, if desired.
I hope that was helpful to you, good luck.
If you choose to rate this solution using the Thumbs Up scale provided, I thank you very much for your time and consideration.
Joe.
May 25, 2011 | Timex T77862 Watch
No problem I just forget how to change my ironman 30 lap timex watch time from 12hr to 24hr! Please help :-)
And here is the direct link to the manual for the Ironman 30 Lap model:
http://assets.timex.com/user_guides/W89_M877/W89_M877_NA_EN.pdf
Thank you very much and good luck.
Joe.
May 23, 2011 | Timex Watches
Bought a electronic deadbolt at Rona (Rona Collection). Installed it and i can open/close it with the remote control or a key. Can't open it by entering a code. I thought the factory code was 1234, but...
Rona Electronic Deadbolt Lock Instructions:
Default Master Code:123
Resetting Master PIN:
  • Remove batteries and put them back. You will hear a long beep and a short beep.
  • Press and hold the 0 button until you hear 3 long beeps and the LED flashes red for 3 seconds. You are now in program mode.
  • Within 10 seconds, key in a new master PIN (up to 12 digits) and press the UNLOCK button.
  • Key in the master PIN again and press the UNLOCK button. The LED will flash green for 1 second and the resetting is complete.
Adding a PIN:
  • Key in master PIN and press UNLOCK button
  • Press and hold 0 button until you hear 2 short beeps and the LED flashes for 3 seconds.
  • Release 0 button and you are in the Add PIN mode
  • Within 10 seconds, enter a new PIN and press the UNLOCK button. You will hear one beep.
  • Key in the new PIN again and press the UNLOCK button twice. When the LED stops flashing the PIN has been added.
Sep 23, 2010 | Deadbolt Locks & Locksmithing
I need a instruction maual for a itrax bluetooth device
Pairing With A Bluetooth Enabled Cell Phone
1. The BTCK06 and the Bluetooth enabled cell phone should be within a distance of 3 feet
(1 metre).
2. With the BTCK06 OFF, press the MULTI-FUNCTION Button (The bottom button) for 6 seconds.
The Red & Blue LED's will flash alternatley and the speaker will make a long BEEP sound.
3. The Bluetooth cell phone will search for nearby Bluetooth devices. The cell phone will display the
BTCK06 in the list of Bluetooth devices. If you are using a "dongle" type Bluetooth adaptor,
follow the manufacturer's instructions for that device.
4. Select BTCK06 to add this Bluetooth device into the list of the paired devices.
5. Enter in the PIN Code "0000" and your mobile phone will show that pairing is complete.
6. If Pairing is successful, user will hear a long BEEP and the Blue LED will flash about every
3 seconds.
Nov 24, 2008 | Cell Phones
Open Questions:
SBCglobal MAil CuStOMeR {1^855^536^5666}#[email protected] Service IDAHO This SbcGlObAl mAiL USA phone number is ranked #2 out of 2 because 7,728 SbcGlObAl mAiL USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:855:,:5365666 is to reach the SbcGlObAl mAiL USA Tech Support department for problems like Where to buy, Complaint, Tech support, Repairs, Returns. As far as we can tell, SbcGlObAl mAiL USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. SbcGlObAl mAiL USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I********** and ways to call or contact SbcGlObAl mAiL USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling SbcGlObAl mAiL USA Calling SbcGlObAl mAiL USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from SbcGlObAl mAiL USA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with SbcGlObAl mAiL USA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare SbcGlObAl mAiL USA's phone numbers against each other. Contacting SbcGlObAl mAiL USA in General While I********** is SbcGlObAl mAiL USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I********** is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach SbcGlObAl mAiL USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact SbcGlObAl mAiL USA.
Oct 21, 2019 | Best Computers & Internet
ZONEALARM Tech sUPPoRt pHoNe +18OO,,8O3''1O69 number Usa.G.Ds Usa ZONEALARM USA phone number is ranked #2 out of 2 because 7,728 ZONEALARM USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:8OO:,:8O31069 is to reach t he ZONEALARM USA Tech Support department for problems like Where to buy, Complaint, Tech support, Repairs, Returns. As far as we can tell, ZONEALARM USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. ZONEALARM USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O31O69 and ways to call or contact ZONEALARM USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling ZONEALARM USA Calling ZONEALARM USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from ZONEALARM USA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with ZONEALARM USA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare ZONEALARM USA's phone numbers against each other. Contacting ZONEALARM USA in General While I8OO8O31O69 is ZONEALARM USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I8OO8O31O69 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach ZONEALARM USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact ZONEALARM USA.
See all FIC VC19 Motherboard Questions
Computers & Internet Logo
99 people viewed this question
Top FIC Computers & Internet Experts
Ekse
Joe Negus
Joe Negus
Marvin
Marvin
Are you a FIC Computer and Internet Expert? Answer questions, earn points and help others
