Question about Brother HL 2140 Laser Printer
CORONA WIRE CLEANING
MY BROTHER 21400 IS A RELATIVELY NEW PRINTER (PURCHASED IN NOV. 2008). AS I WAS PRINTING A SIGN CAME UP ASKING ME TO CLEAN THE CORONA WIRE GIVING DIRECTIONS ON HOW TO DO IT. IT HAS BEEN DONE SEVERAL TIMES YET THE MESSAGE WON'T GO AWAY AND THE PRINTER WON'T PRINT.
SUCH MESSAGES SEEM VERY UNDERHANDED, PLEASE HELP ME MAKE IT GO AWAY. I PURCHASED THE PRINTER TO BE ABLE TO USE IT NOT TO LET IT SIT THERE WITH THESE ERROR MESSAGES.
  • Anonymous Jan 28, 2009
    i am having the same problem!!!
  • 4 Answers
SWARNAVA has the most common wrong answer to this problem...
I am waiting for a firmware update to fix this issue. The only solution is repeatedly removing the drum/toner, moving the green cleaner back and forth, putting it all back together loosely, putting it in the printer loosely, and closing the door gently. Hold down the blue button until all the lights glow, then release. If you're lucky you only have to repeat this process a dozen times until you trick the sensor into not giving false readings.
Posted on Jun 30, 2009
    New Friend:
  • 114 Answers
Remove the cartige. Separate the dram and toner unit. In drum unit there is corona wire just clean it.
Posted on Feb 03, 2009
Where do you find corona wires on Brother 7840W printer?
The wire is on the drum (where the toner cartridge fits in). The green or blue piece slide cleans the coroner wire.
Jul 23, 2014 | Brother MFC 7840W Printer
3 vertical dashed lines down every page
Hi there, I would assume that you are speaking about a laser printer, if this is the case you would have to take the printer in for a service and ask them to clean the primary and secondary corona wires.
A dirt corona wire can cause a vertical lines down the print job cause that part of the OPC drum is not being charged by the charge corona.
Could also be a dirty drum.
Hope this helps. :)
Please let me know.
Jun 29, 2012 | Office Equipment & Supplies
Vertical single black line on printed pages - does this mean I need a new cartridge or a new drum? Brother HL 1250
The first thing I would try is to fix the corona wire. Here is a link to Brother's website outlining the process (clean corona wire).
What you need to do is pull out the drum and look for a blue tab on the top of the cartridge. Slide that tab back and forth along the wire and see if that clears things up.
I have had some luck cleaning the drum when I get black streaks but I have also hear this can be dangerous and make the problem worse.
Feb 09, 2011 | Brother HL 1250 Laser Printer
My brother mfc-7840w printer keeps telling saying there is a drum error and will not print. i clean the corona wire and reset everything yet the same thing happens again and again. how do i fix this?
The drum is the photosensitive roller that the image is charged onto so I'm afraid cleaning the corona wire won't help. If the drum is removeable try reseating it, otherwise it looks like you may need to buy a new drum kit for it.
Apr 28, 2010 | Brother MFC 7840W Printer
Brother not printing
Hi John, the machine keeps asking you to clean the corona wire because on start up or especialy when the machine readies it's self to start printing, it passes a voltage through the corona wire which helps the drum erase the charge on the organic photo compound the drum is covered in.
If the machine sees any problem with the transfer of this voltage it thinks there is a problem.
The corona wire can be cleaned by sliding the blue tab on the top of the drum from right to left a few times.
You should check to see if this wire is broken ..it a very thin wire about the thickness of a human hair, if the wire is not broken then try cleaning the thin metal grid below the corona wire with a cotton bud , being carefull not to break the wire.
If this doesnt work then it sounds like the high voltage connection on the drum is faulty, and you will need to purchase a new drum ( or take it back to the supplier and say it is faulty and you want it replaced).
You ould also clean the surface of the drum itself carefully with a soft DRY clean cloth.
The only other cause is the high voltage supply pcb is faulty. Which if the machine is out of warranty is prohibitavely expensive to repair.
Hope this helps
Mar 03, 2010 | Brother HL 2140 Laser Printer
Get a clean the corona wire. Have removed the
Try using canned air to blow out that corona area, and then a Q-tip moist with alcohol to gently wipe the corona wire, if all that fails you will need a new drum.
Also press the go button 3 times so you get a printout and check that you are getting a clean the drum error or something else.
Dec 18, 2009 | Brother HL 2140 Laser Printer
Printer won't print error message corona wire needs cleaning
When you experience a persistent problem like this right at the beginning - listen to your own good advice. Take it back to the store and exchange it for a new one.
Jul 30, 2009 | Brother HL 2140 Laser Printer
Corona wire
I was getting the clean the corona wire problem message even after repeated cleanings.  Before this problem occured the toner light was flashing warning of low toner. When I got the clean the wire pop up the toner light was on all the time indicating the toner was depleated.  So, I thought I would try replacing the toner cartridge and see what happened. I opened the new toner box and noticed on the foil packege specific instructions to clean the corona wire when installing the new toner.  I installed the new toner and cleaned the wire one more time. I then reinstalled the drum and toner assembly into the printer and the clean the corona wire message did not come up again.  The printer now works fine.
Aug 08, 2008 | Brother HL 2140 Laser Printer
Pls Clean Drum
The drum is the larger plastic unit that slides out an the toner cartridge fits into it. The corona wire is the very fine wire at the front top of the drum. Just slide the little cleaning tab back and forth.
Aug 03, 2008 | Brother MFC-8440 All-In-One Laser Printer
Printer is printing BLACK PAGES
Solution from brother
Jul 11, 2008 | Brother HL-2040 Laser Printer
Brother HL 2140 Laser Printer Logo
1,151 people viewed this question
CheckitRight
CheckitRight
Soulvisitor
Soulvisitor
Ron Dufek
Ron Dufek
