Question about Microwave Ovens
Glass plate spindle wanted
Mine melted so need a new 1 any ideas where from thanks donna
    President:
  • Microwave Ovens Master
  • 1,922 Answers
Take the model number down then contact www.appliancepartspros.com they will have it
Posted on Jan 07, 2013
4 Suggested Answers
THENTHEREWER
  • 131 Answers
SOURCE: need a glass tray for sylvania
http://www.myapstore.com/Omega/Dispatcher?REQUEST=ACCESSORY THIS IS THE ONLY PLACE I COULD FIND THE PART YOU ASKED FOR ,JUST COPY & PASTE THIS INTO YOUR BROWSER & YOUR THERE.YOUR MODEL # DOES'NT SEEM TO BE COMPLETE,THERE ARE LIKE 2 OR 3 DIFFERANT PREFIXES FOR YOUR MODEL.SURF THE SITE,ITS PRETTY SIMPLE.ITS A LITTLE PRICY,(62$)BUT I DID MY BEST,HOPE THIS HELPS!!!
Posted on Nov 08, 2008
SOURCE: my fridgidaire microwave needs a new roll around
my daughter found the part on the internet for me thank you for the response
Posted on Sep 19, 2009
  • 4 Answers
SOURCE: our oven's glass plate is broken i want new glass
After some research I discovered that Electrolux is the parent company of the common brand Frigidaire.
From the looks of it, the best place to order the part you need is from Sears Parts Direct. While there were several other parts companies which popped up, Sears seems the most legit, and the prices they advertise were actually cheaper than the other sites.
The part you need has the manufacturer product code: 5304461145
If you look at the schematic (http://c.searspartsdirect.com/lis_png/PLDM/R0908182-00001.png) you will see the tray labeled as part #45. This code matches the last two digits of the product code, so I'm fairly confident that this is the correct part.
The part is currently priced at $135.43 without tax or shipping.
You can purchase the part online at this link:http://www.searspartsdirect.com/partsdirect/part-number/Electrolux-Parts/Microwave-Parts/5304461145/0022/628/Model-E30MO65GSSB/1412/0123100?keySuffixId=&productTypeId=&searchModelNumber=E30MO65GSSB&blt=06&subCompDesc=OVEN/CABINET
Posted on Mar 01, 2011
What size glass tray do I need for my Westinghouse model WCM770B/W microwave? I broke mine and cannot find the answer in the manual.
Frequent thrift stores or yard sales, or take a tape measure to the inside of the microwave
. If your dish was square, the glass plate should likely be about 1 inch less wide and 1 inch less deep that the inside of the box.
If you have a round plastic rotator, the dish should be about 1 -2 inches bigger in diameter than the plastic rotator.
God bless your efforts.
Oct 23, 2017 | Westinghouse Microwave Ovens
Panasonic inverter microwave combi makes a clunking sound after a few seconds and the plate does not revolve properly, the supplier said it was burnt on food on the spindle but how could food get there, I...
Check the glass plate lines up with the 3 notches on the spindle, if it's not sitting correctly it will clunk, it's just a matter of getting the plate to sit right on the spindle, if still no joy check to see if the spindle is damage or the glass underneath.
Nov 23, 2013 | Microwave Ovens
The motor for the turntable is working fine, but the connection to the glass plate is so poor that it usually slips instead of turning the plate. This happens if anything larger than a glass of water is...
The glass plate has to be correctly seated on the drive spindle before you can have any hope of reliable rotation. Place the plate on the spindle and spin it gently until it seats.
Feb 14, 2018 | GE WES1384SMSS Stainless Steel 1000 Watts...
I have the CWM 100 - the microwave is only about 1-1/2 years old. It runs, but the glass turntable no longer turns. No matter what we've tried, removing the glass plate, cleaning the wheels of the...
Check to make sure the Spindle that the plastic piece fits on is turning when the oven is on.
If the spindle turns, your problem is either the plastic wheel adapter is worn or not making proper contact with the spindle. You can replace th e adapter by going to Cuisinart.com.
If the Spindle is not turning, you can go to Cuisinart.com and find the nearest repair facility.
Nov 20, 2010 | Cuisinart CMW-100 Microwave Oven
Turntable won't spin so microwave won't heat
Is it possible to take the glass plate out, if so, please remove the glass plate, switch on the microwave for 10 secs and watch through the door to see if you can see the centre spindle turning round? Try this and get back to me please
Mar 12, 2009 | Goldstar MV-1615 Microwave Oven
Need a glass tray for sylvania
Nov 05, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Russell Hobbs HOB CTS34 - Faulty glass plate
Door glass broken on russel hobbs 28lt micro wave. Any idea where I can have this replaced. thank you
Mar 15, 2008 | Microwave Ovens
Turntable turns, but in a constant jerking motion. The plate ring turns free so there is no binding.
It sounds like your turntable motor may be going bad. It is located UNDER the carousel and easy to get to by removing a few screws from the bottom of the oven. You can try running the oven without the carousel tray and watch the spindle to see if you can detect the same jerking motion. This would confirm the motor has a problem. If the spindle runs smoothly with no weight on it, but begins to jerk with the carousel placed back on it, the motor could still be bad, but you may also have a spindle that is slipping. In either case, replacing both would probably be a good idea just to be sure. Make sure you place a glass of water on one corner of the oven. It's not recommended to run a microwave oven empty. If you determine the motor is defective and want to replace it, make sure you unplug the oven and remove the bottom panel of the oven. There should be a couple of wires connected to the motor and the spindle just pops off from the inside of the oven cavity. It's a fairly simple repair job and will run about $30-$40. Let me know if this helps.
Jul 30, 2007 | GE JVM1440 Microwave Oven
GE Profile Spacemaker Microwave - JVM1660BBC
The turntable has a small motor underneath it that rotates the glass tray. You could have a motor that is going bad, or the plastic spindle (what the glass plate sits on) could be slipping. You can access the motor through the bottom panel. Be careful to make sure the microwave is unplugged for attempting any repairs inside. There is potentially as much as 14,000 volts in the high voltage network around the magnetron. Let me know if this helps.
Jun 27, 2007 | GE JES1039 Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
