My Conia aircon CA24003 model is not cooling down. I set the temperature to 24 degrees C but it doesnt go below 30 degrees C. Can anyone help plsss
  • 4 Answers
Get the filters out wash them carefuly dry them and put them back,check if the liquid inside must be replaced by a expert ,service from time to time is required
Posted on Jan 07, 2013
  • Nicola
    Nicola Dec 26, 2013
    I have the same issue. Had it checked they said it works and it did for them. When I went to use it, it's definitely not cooling! Have others who can vouch for it. Spent Xmas day sweltering! Any other suggestions??
BIKER T
  • 909 Answers
SOURCE: Can Movincool classic plus 26 AC set the air temperature at below 70 degree F?
aircons normally pull down to approx. 17 degree celcius.and heats to approx 30 degree celcius.  most of the time you need to simply clean the condenser properly and to make sure fans are in good order.
Posted on Oct 23, 2007
  • 50 Answers
SOURCE: Danby Portable Air Conditioner DPAC120068 - room temperature
Maybe, the compressor isn't starting? I'd take it back to where you purchased it.
Posted on May 18, 2008
SOURCE: room temperature has not changed since hooking up new portable a/c
I bought mine last summer. Used it once or twice. Hooked up it today and it is a piece of ****. Been at 34celsius for the last 4 hours and still not even close to being cool .. and its in my bedroom
DON'T BUY DANBY portable a/c -----------
Posted on Jun 07, 2008
jumptrout51
  • 3361 Answers
SOURCE: Carrier Comfort 13 Puron model 24ACA3 / FV4NB006
Verify 24 volts at the low voltage transformer inside the air handler. If it is OK, jump out the red/green and yellow thermostat wires. If everything comes on, replace the thermostat.
Posted on Jun 08, 2009
bozcro
  • 867 Answers
SOURCE: doesnt cool small bedroom with doors shut. I have
it should freeze that room with 9000btu do you hear the compressor turning on or is it blowing jus air? also helps if you switch the air intake to recirculate the room air rather than intaking the air from outside
Posted on Jul 30, 2009
Conia split system operating manual
Not sure if this is what you are looking for. A Make and Model would be a great help in finding the information that you are looking for. So we at West Palm Beach Air Conditioning would love give you a hand.
Manuel:
https://highcongtana.files.wordpress.com/2015/10/conia-air-conditioner-manual-ca24003.pdf
Oct 16, 2015 | Heating & Cooling
How can we make our Airtech Elite portable aircon's wind cooler? It's cool, but not cold!!
the temperature should be close to 20 degrees difference between the return and supply air of the aircon. Proper maintenance includes free airflow on the outdoor unit, hose the radiator down with water, clean it.
Oct 09, 2015 | Heating & Cooling
Cannot set correct temperature with remote
the 16 on remote is the set temperature not the room temperature.
Jan 25, 2014 | Heating & Cooling
Have samsung american fridge freezer with ice dispenser i bought it second hand the problem is the digital display says the freezer is 20 degrees but its freezing inside also every minute or so we hear a...
If it's American, the temperature probably reads as fahrenheit. If so, 20 degrees F is 12 degrees F below freezing which converts to only -6.67 degrees Celsius.
Domestic freezers should be set to -17 degrees Celsius (= 0 degrees F), so the beeper is warning you that the freezer compartment is far too warm. If it's working correctly and has the temperature control set correctly, then it should achieve the correct temperature if you leave it for 24 hours and do not open the door nor try to use the ice dispenser. If the freezer is full of unfrozen items and so has to cool those down as well, then it may take even longer to reach the correct operating temperature.
Te operating manual for your appliance will tell you how to set the temperature correctly and whether it's possible to select between fahrenheit and Celsius scales. Most models allow you to set an override on the beep alarm as well. I cannot guide you on this without knowing the exact Samsung model.
Please take a moment to rate my reply.
Sep 22, 2010 | Microwave Ovens
Need a conia airconditer remote control here in Australia. We have 2 split systems that use the same remote. Models CA 24003 & CA 3003. Conia have gone bust here and we can't get a replacement remote....
i had the same problem and i managed to find a universal remote control from JARCAR Electronics. Model of the remote: Digitech AR-1729. It doesn't list Conia as compatible but I managed to gain control of the aircon using the code: 291. For some reason when you press the power button on the remote, it's like your double pressing the on button so the aircon switches on and off quickly. You need to press the power button on the remote quickly and move it from reception before it powers down the unit again. At least I have control of the aircon again and I don't have to put up with these humid hot days in melbourne... Good Luck.
Jan 01, 2010 | Heating & Cooling
Oven not achieving correct temperature, 50 degrees too low
Thermostat is not working properly and needs replacement.
Apr 14, 2017 | Ovens
Non-cooling
- Calibrate your electronic thermostat if it is accurate. If not then replacement is needed.
- Check the location of your electronic thermostat, it may be installed in the room where its too cold.
Feb 29, 2008 | Carrier 36KCARMS Air Conditioner
Oct 16, 2007 | Movincool Classic Plus 26 Air Conditioner
Heating & Cooling Logo
88 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
