I cannot access my laptop with my projector. - Computers & Internet
  • achmad baihaqi May 11, 2010
    do you already activated the extended button
    in your function button
  • 112 Answers
Connected the vga cabel to the projector.
Posted on Jan 21, 2009
I have a Hitachi CP-L500 LCD projector. It is connected to my laptop from the svga projector port to the svga port on the the laptop. It is making no signal connection. I have made sure the input button...
I am not familiar with your Hitachi LCD projector . However , I do have a little knowledge regarding video signals and inputs / outputs as well as connections . If your connecting cable is one piece (has no adapters added to either end of it ) I would believe your problem is simply a settings misconfiguration in your projector / computer , or both . First , access your startup BIOS / CMOS settings during the initial booting sequence in your computer by pressing F1 or whichever keys you press when you turn the computer on to access it . Then , in the advanced list , check your primary video input selection to be sure it is default. Then, once the computer is completely booted and you can click on your start selection , go to your video settings and check how to switch between internal and external display options . I say this because it is important that you are able to reroute your video signal to your SVGA Out from the laptop (for sure) and it is in fact in that video output mode. Once you're sure you have a signal going out of laptop through that port , go to your projector video input selections menu and select each and every input option available until the signal comes through . This will only work if you're absolutely 100% sure that your video signal is in fact leaving the laptop via the SVGA port connection .
Sep 05, 2010 | Computers & Internet
VGA source is not working.
if you are using a laptop as a source, note that the VGA output is not active by default. You need to access your display settings on the laptop and set it up for dual output.
Aug 23, 2010 | BenQ (200NSH-LAMP) Projector Lamp for...
The projector is not recognizing the laptop, it says searching on the projector screen going through VGA, S video, etc.
Probably got the resolution on the laptop set too high for the projector. Go into your video control panel (accessed by right-clicking the desktop), set up the projector as a cloned monitor and make sure the screen resolution is low enough for the projector to handle.
Jan 27, 2010 | Optoma EP728 Beamer/Projektor Projector
I've connected the projector to my laptop using the VGA cable as stated in the manual. The projector reflects as it should, i can access the menu and input options which i then select RGB scart (though...
Not with any RGB input options, computers are not compatible with these. The projector needs to be set up to receive VGA. There must be a toggle button or menu entry somewhere on your projector that lets you do this or why would it have a VGA input?
Dec 07, 2009 | Sanyo PLC-XW55 LCD Projector
Connecting Macbook with a compaq MP1400 digital projector
You're going to need a conversion dongle that goes from the Mini-DVI to VGA.
Then:
  1. Connect one end of the projector signal cable to the Video Graphics Array (VGA) connector on the projector.
  2. Connect the other end of the projector signal cable to the Digital Video Interface (DVI) connector or VGA connector on the notebook computer and tighten the screws.
  3. Connect the projector power cord to the power cord connector on the projector.
  4. Connect the other end of the power cord to an electrical outlet that is easily accessible and close to the projector.
  5. Turn on the projector first, then turn on the computer.
Nov 09, 2008 | Computers & Internet
Laptop
1.Try FN+F3 or Fn_F4 or maybe Fn+F10 ..best is to see on the keyboard F1..F10 and see it should have like a TV logo.
2.Make sure you connect the cable to correct port on your projector.Becasue some projector do have another connector
for getting the output back to PC.
Takecare.
Apr 20, 2008 | Computers & Internet
Acer data projector
you have noy correctly loaded the the mother board driver
so again load the mother board driver for access, if not then reformat the laptop using original o.s disk.
Feb 07, 2008 | Computers & Internet
Cannot access menu functions or display signal on projector
if you cannot access the menu, you have a main board issue that requires replacement.
Oct 07, 2007 | CTX Ez Pro 585 Multimedia Projector
Sanyo pro xtrax projector
listen im a comp wiz on the remote press video 1 egt. if that doesn't work trash it
Sep 20, 2007 | Sanyo PLC XU35 Multimedia Projector
Computers & Internet Logo
David Payne
David Payne
