Question about RCA 32V550T 32" TV
Control Panel The control panel on the top of the tv is going out. When you try pushing the buttons nothing happens. When you turn the tv on with the remote, the menu pops up as if the button was stuck. I have Direct Tv and every time I try to use my remote to change the channel, the guide to the tv pops up. Now the tv menu is stuck in spanish, and the volume is on mute. I took the control panel apart, and there is a chip inside of it, can I replace it?
  • 432 Answers
Yes you can replace the chip, BUT, first try to clean the button contacts. I have to do that to my remotes, phones, and RCA TV (yes I have one too) etc.. around my house. Just needs a good cleaning. Don't forget to unplug the TV.
Posted on Jun 30, 2007
SOURCE:
When pluggged in, all lights behind the buttons on control touch pad panel light up, then go out. When the 'on' button is pushed, nothing happens. Can you tell me what the problem is? Thanx
First thing to try is turning off the power to the machine for a minute and then turn it back on, if that does not fix it then electronics have a brain problem. I have noticed that appliances with electronic panel controls are having many problems, my washing machine electronic control panel is bonkers but never had problems with the old mechanical controls. In order to fix mine I would have to order the whole panel as you cannot replace parts, I'm sure you unit is the same.
Mar 12, 2018 | Frigidaire Heating & Cooling
Frigidaire control panel has no power
Check those 3 micro switches in the door latch assembly. "my husband says that if you push the door it will work."
Nov 24, 2017 | Frigidaire GLMB209D Microwave Oven
My RCA Truflat T.V won't turn on and the FPA lock is turned on, I have the original remote. what should i do?
TV won't turn on • Press the TV button. Make sure the TV is plugged in.• Check the wall receptacle (or extension cord) to make sure it is "live" by plugging in something else.• Something might be wrong with your remote control. Press the POWER button on the front of the TV. If the TV turns on, check the remote control solutions on page 26.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).Buttons don't work
• If you're using the remote control, press the TV button first to make sure the remote is in TV mode.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).• Unplug the TV for two minutes and then plug it back in. Turn the TV on and try again.TV turns off unexpectedly • Sleep timer might have been activated. Go to page 24 for instructions.• KidPass might have been activated. Go to page 21 for instructions.• Wake-Up timer turned on the TV and no remote or front panel buttons were pressed for two hours.• Electronic protection circuit may have been activated because of a power surge. Wait 30 seconds and then
turn on again. If this happens frequently, the voltage in your house may be abnormally high or low.
• Unplug TV. Wait five minutes. Plug it in again.
Sep 16, 2011 | RCA 20F420T 20" TV
No response to any button on remote or tv except power button
Press the 'Favorite' button on the remote. You may have accidentally pressed it. It locks the channel. Pressing again unlocks.
Apr 22, 2009 | iLO 3200 32 in. LCD Television
Programming problem
a universal remote control is programmable without codes using this general process:
  • push and hold 3 sec the button set up
  • select the device to control (TV DVD etc)
The tv has to be ON at this step (use the power button in the tv front panel
  • use the remote control power button and try to get your tv pushing the button again and again and again
  • Caution! Go slow because when finally the tv turns on you have to push enter in the remote control to save this code that actually is the one the tv needs,
Apr 14, 2009 | Radio Shack 15-2142 Remote Control
Ac/heating problem
Same problem for me. Local garage seems to think replacing the control module in the dash will solve the problem. I also have clicking sounds behind where the relay junction box is (under dash). My problem is intermitant so I'm also thinking that replacing a relay or two might also help.
Mar 19, 2009 | 2000 Dodge Grand Caravan
My LG remote control is not working
Make sure you push the TV button on the top of the remote before you push the power on button.
Dec 17, 2008 | Televison & Video
LG LST-5100P set top box. Several times a day have
cap-grant, my friend has the same problem with set top box. When I phone maker I was told it is due to poor and weak signal. You must have 80% signal strength to maintain good picture. When signal strength dropped picture would freeze and had to be turned off at the power point to restart as nothing would work. So I guess what my experience says is you may need better aerial to boost signal and prevent dropout Leonard210
Oct 05, 2007 | Televison & Video
The word "Factory" is in red at the top of my TV screen. I've already tried turning it off, unplugging it, and also pushing every buttong possible on the remote. How do I get "Factory" off?
You might try pushing two buttons a once. Like volume up&down or channel up&down. Do this from the control panel on the TV not the remote. I've seen this happen on some sets,but I'm not sure about your brand.
Jan 14, 2007 | Durabrand DWT1905 TV
RCA 32V550T 32" TV Logo
102 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
