Question about Panasonic Office Equipment & Supplies
COLOUR DRUM REPLACE MONOCHROME DRUM panasonic colour laser multifunction printer kx mc6020cx
How to reset the drum counter ???????????
SOURCE: Xerox Docuprint C1618 Colour Laser
it resets with a new drum, there is a chip on the drum ( CRUMB) that resets the main PCB count when you install a new print unit.
Posted on Oct 08, 2008
POCBM
  • 121 Answers
SOURCE: Brother HL 1250 Laser. Drum & page counter
Reset the drum counter as follows:
  1. Open the front cover.
  2. Locate the control panel button under the LED lights on the left side.
  3. Press the control panel button until all lights are lit, then release it.
    The Drum counter is now reset.
  4. close front cover
Posted on Mar 23, 2009
HobbesVT
  • 3 Answers
SOURCE: drum reset for Panasonic kx-mb781
There is a little special (white) gear on the outer left side of the drumkit - a little bit below where the toner sits. That gear joins with toner mixing assy - and you can rotate it in counterclockwise all the way back. This should reset the drum counter - worked for me - I hope it also does the trick for you ;-)
Posted on May 03, 2009
SOURCE: how to reset drum counter for brother hl4070cdw laser printer
When you replace the drum unit with a new one, you need to reset the drum counter by completing the following steps:
  1. Turn the printer power switch back on.
  2. Press the + or - button to choose "Machine Info".
  3. Press OK to proceed to the next menu level, and then press the + or - button to choose
    "Reset Parts Life".
  4. Press OK, and then press the + button to choose "Drum Unit".
  5. Press OK two times.
Posted on Aug 29, 2009
SOURCE: reset drum
I think this machine does not have a reset option instead you can reset manually.All you have to do is on the right side of drum unit there exist a white + type notch,rotate it clockwise till it allows.Put back drum unit into machine.Switch on and see replace drum and supplies message will disappear.In my case it worked.Hope this is the best solution.All the best
Posted on Oct 26, 2009
Drum life is over please change cartridges
its time to replace the image drum. Visit any online printer consumables supplier such as choicestationery.com, enter the model of the printer and it will list the consumables
here is the link
http://www.choicestationery.com/catalog/category/view/s/kx-mb-1500-series/id/18671/
hope this helpsKind regards
May 11, 2015 | Panasonic KX-MB1500 Laser Multifunction...
Why has my cartridge run out of colour after printing 4 photos
If you have high-end color laser printer, just reset drum chip for page counter.. like that reset page counters of each CMYK cartridges. Contact your nearest Cartridge vendor.
Oct 12, 2014 | Office Equipment & Supplies
Drum life over change cartorige
Not much you can do. Drums are designed to make so many copies or prints. You may be able to fool it. Remove the drum and put it back in. Don't touch the drum you will get an image of you fingers if you do. Remove toner cart 1st. Then drum wrap a piece of paper around it. They are light sensitive. Put it back in carefully. Then toner cartridge. Unless it is a package cartridge that has drum in then. This has been for naught. Hope this does help.
Sep 26, 2014 | Panasonic KX-MB1500 Laser Multifunction...
How can I resolve call 5service and my print out is faint?
You can check your cartridges on your PC, to confirm it is right. Try uninstalling the printer ! assuming you have the CD or DVD handy.
May 19, 2014 | Panasonic KX-MC6260 KX MC6260...
Vertical lines
Lines in prints with this machine would suggest a fault with a drum unit. As each toner cartridge contains its own drum unit it is likely to be a particular colour at fault. If the colour is not immediately obvious, I would recommend printing off a test page like the one here:
http://www.refreshcartridges.co.uk/igloo/colour-laser-printer-test-page/
Nov 19, 2012 | Canon Imageclass Mf-8350cdn Color Laser...
Panasonic KX-FL511 fax, have replaced the drum kit twice now, following the install instructions with drum (and same instructions in manual). Machine still will not reset counter or recognize the new...
after replacement of drum when you close the the cover just wait for few seconds to reset the drum
machine will take one cycle. do not open lid before comletion of reset cycle done.
Feb 12, 2010 | Panasonic KX-FL511 Plain Paper Laser Fax
Panasonic KX-FL512 fax drum life error
You need to follow the instructions that came with the drum as you need to reset the internal counter.
Dec 06, 2009 | Panasonic KX-FL511 Plain Paper Laser Fax
Drum reset for Panasonic kx-mb781
Apr 19, 2009 | Panasonic KX-MB781 All-In-One Laser...
Reset drum
Jan 07, 2009 | Panasonic KX-FLB801 All-In-One Laser...
DRUM REPLACEMENT CODE
How to Reset the “Replace Drum Cartridge Soon” Message on a Panasonic KX-FL511
[Menu]
[9000]
[*] (Will display P-SF)
[6722]
[Fax Start]
[Menu]
Nov 18, 2007 | Panasonic KX-FL511 Plain Paper Laser Fax
91 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
