Question about Apple iPhone Smartphone
My 2g iphone has a key board problem. Its lowermost keys (space bar,numeric etc) are not working. I have restored it as well as upgraded itto 2.0.1 but does not work. Plz help email> faizikhalid1@gmail.com
  • KMAGIC005 Feb 06, 2009
    I hate this I want my lower keyboard to work.
  • Anonymous Apr 12, 2009
    space button doesnt work
I had the exact same problem with my iPhone
found a great site which unlocks and fixes iPhones IrishiPhone.com
They fixed my keyboard issue for me and upgraded my phone to the latest software too
Hope this helps you :)
Posted on Feb 13, 2009
Brother ml 500 memory typriter how do i move margin to right
Use your space bar to move carrier to desired location, hold down Alt key button on bottom left (next to space bar) and press the number 5 numeric key on top row. That should set your right margin.
Jul 30, 2014 | Brother ML-500 Typewriter
Why won't the number 1,0 and space bar button work?
Have you tried a battery pull...... restart by removing the battery while your device is Powered On , try it and see if you're able to access your keyboard . you can try factory default to reset phone ...When you restore the factory default settings, all personal settings are reset. Follow these instructions to restore the factory default settings.
All phone data will be deleted. Data on your SIM isn't deleted.
1. Find "Security Wipe"
  • Press the Menu key twice.
  • Scroll to Options and press the Navigation key.
  • Scroll to Security and press the Navigation key.
  • Scroll to Security Wipe and press the Navigation key.
2. Restore factory default settings
  • Highlight Emails, Contacts, etc., User Installed Applications or Media Cardand press the Navigation key.
  • When the box next to the menu item is ticked (V), the selected data will be deleted.
  • Highlight the field at the bottom of the display and key in blackberry
  • Scroll to Wipe and press the Navigation key to restore the factory default settings.
  • Follow the instructions on the display to set up your phone and prepare it for use.
May 13, 2014 | RIM Blackberry Curve 9320 Smartphone -...
How to format E72 that won't charge in either nokia charger nor USB cable. But once it open it only vibrate then NOKIA sign appears and yet it won't open. please HELP ! thank you !
For Hard Reset:
This also restore your Nokia when it frezzes at the nokia screen logo only and didn't go any further.
hard reset is an options but will result to loosing all settings, contacts, data etc...
Turn your phone off and simultaneously press these four buttons circled in red.
* * (asterisk key)
* 3 (numeric 3 key)
* CALL / GREEN key
* On button
This is another method below found out by trial and error when the * + 3 + Call didnt work.
Switch your phone off.
Then, lay it down on a flat surface
With 3 finger of one hand, keep pressed shift, space bar and back space all at the same time
With one finger of the other hand, press the power on button
Do not release neither the 3 keys nor the power key till you see the nokia shakehands animation.
Jun 23, 2012 | Nokia E72 Smartphone
Bottom row of my keypad doesn't work
You have to get it changed
2G iPhone - FULL LCD with Touch Pad !. 3G iPhone - Only Touch Pad !
Best Regards
Jun 24, 2009 | Apple iPhone Smartphone
The bottom part of my iPhone touchpad is not responding at all, even though everything above the first centimeter is. can't use the space bar on the key pad.
try restoring the phone. if that doesn't work there is an issue with the multi-touch display and it needs repair :(
Feb 03, 2009 | Apple iPhone Smartphone
Can't Reset to preactivated factory stage(emergency call screen?)
go to itunes. when plugging in to computer hold down the home key it should restore factory settings. i called apple.
Dec 26, 2008 | Apple iPhone Smartphone
Iphone unlocked problems
i just purchased an unlocked i phone 1st gen and it was working fine with my tmobile carrier but all of a sudden i synced it with i tunes and now it wont let me make calls
Oct 11, 2008 | Apple iPhone Smartphone
Iphone keyboard
You will ahve to restore your iphone to 1.1.4 and then replace general.plist and touch.plist file with a new one. The two files can be found on google. Reboot and the issue should be fixed. It's a lenghty procedure, so let me know if the issue still persist, then I'll give you detailed instructions.
Sep 03, 2008 | Apple iPhone Smartphone
Sms operation
Greetings,
For instructions too long to post in here - click on this link
fxnlogo_s.png Technical Support, Instructions & Repair Service
Aug 28, 2008 | Apple iPhone Smartphone
How do i exit my iphone running on singleuser boot
hey guys... the only thing you can do now is to restore your iphone/ipodtouch...
how to restore:
connect your itouch/iphone with usb to your computer and open itunes... probably itunes will not find your itouch/iphone cause its not booted correctly... so
hold down the sleep button and home button for more then 15 sec. first it appears a black screen and after actually you have to hold down both buttons till this logo with the usb and itunes appears and then itunes said its a problem with your itouch/iphone and you have to restore...
thats all - itunes restores your itouch/iphone and finish :D
good luck guys ;)
Jul 04, 2008 | Apple iPhone Smartphone
Apple iPhone Smartphone Logo
266 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
