Question about ViewSonic VA1916w LCD Monitor
Viewsonic va1916w monitor how you turn the power lock off
Hlw to take off the power button lock off ???
SOURCE: Problem with 17" ViewSonic Monitor
The same problem w/ my viewsonic E70 17" monitor.The viewmeter or viewmatch color on screen do not appear when power ON, although the green led power is ON.
But if you rest your monitor for about 10 hrs or more the viewmeter will appear when you power ON the monitor.
You can now start your CPU.
Remember : No viewmeter screen on monitor when power ON, means no supply coming out the picture tube or high voltage.
But if there is Viewmeter on screen , this normal and OK>
Posted on Feb 06, 2008
Mark_Webber
  • 472 Answers
SOURCE: no sound
Have you connected the audio cable from the PC soundcard to your monitor?
Posted on Apr 13, 2008
  • 9 Answers
SOURCE: I have viewsonic 1703wb monitor. Often Monitor power went off
Check the power cable. If it uses a power brick style assembly (like a laptop) it may need to be replaced. Some power bricks can break a wire at the base of the brick just enough that it causes a short in the system and shuts down the power flow.
Posted on Mar 19, 2009
  • 225 Answers
SOURCE: Black screen, power button flicks
The monitor should come when the power button is pressed once - period. If not, and it continues to happen when connected to another PC, then the hardware is having trouble powering up the panel / ccds and it should be replaced/serviced according to the terms of the warranty. I suggest to bring it to an authorized service center for proper diagnosis & fix the problem. regards
Posted on May 23, 2009
budmrtn
  • 11361 Answers
SOURCE: Where i can found viewsonic VA1916w display
Check VIEWSONIC website?
http://www.viewsonic.com/support/downloads/drivers/?prod_name=VA1916w
Posted on Feb 22, 2010
View sonic va1916 removing stand
Read this:
http://www.manualslib.com/manual/266476/Viewsonic-Vx2640w.html?page=10#manual
Apr 20, 2014 | ViewSonic VA1916w LCD Monitor
VA1916w monitor weird sound, turns off after a while
just buy a new one thewir is a fault with a microprocessor breaking down with heat ,but where and what one and at the end of the day the labour charge is more expensive than a new one
Jul 05, 2013 | ViewSonic Computers & Internet
I have a Viewsonic VA1916W-4 monitor and it has been working perfectly until today when the display went all green. I'm using it as a second monitor to supplement my laptop, which does not have the...
We had a similar problem with a bigscreen TV. We feared the worse, but after calling our local repair service, they told us this was a common problem involving a poor solder joint. They came out and fixed it in 15 minutes. Start by Googling your model number and "green" or "troubleshoot" to see if this is a common problem. If so, you may be able to fix it yourself or print out the issue and take it to a reputable repair shop or authorized dealer.
Sep 27, 2017 | ViewSonic VA1916w LCD Monitor
My monitor/CPU has a problem; I'm not sure yet but here's the symptoms: When I boot my desktop, my monitor goes on then after a while, it just goes black and says "No Signal" then suddenly the...
Sorry to read about your problem, I hope this helps you out.
make life easy and take the monitor to a friend, plug it in and see if it works....or if you have a old monitor around. plug that in...
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Dec 28, 2010 | ViewSonic VA1916w LCD Monitor
Monitor turn on button is stuck
The monitor screen is black can be caused by bad caps in the power supply, bad inverter circuits, or worst will be bad lamps, you need to open it up and look at the power supply for bad caps first, look for caps with bulging top or bottom seal and then report back so we can guide you further, see example of failed VIEWSONIC monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Feb 04, 2010 | ViewSonic VA1916w LCD Monitor
Screen is black with power light on. It worked when I turned it off on Friday and now on Sunday when I turned it on there was no video. I moved this monitor to another working computer and it did not work....
The problem is with the monitor. Try to check its cables if properly plugged in.
If the problem is still there, then you might want to have a service center check the monitor.
Jul 20, 2009 | ViewSonic VA1916w LCD Monitor
No sound
you need to reinstall your soundcard on the computer
Dec 06, 2008 | ViewSonic N2750w 27 in. HD-Ready LCD...
No sound
Apr 13, 2008 | ViewSonic VA1916w LCD Monitor
ViewSonic VA1916w LCD Monitor Logo
23 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
