Question about Gaggia Baby Espresso Machine
Crack in coffee machine
I have a 3 year old baby gaggia which has a crack behind the water tank and therefore is leaking water from underneath with each use. i have tried to seal the crack with silicone but it only lasted a few days, what can i do considering it is part of the body of the machine and cannot be removed?
    Problem Solver:
  • 13 Answers
If is a plastic or similar material you can fix whit epoxi glue. is it in two different tube you only have to mix de glue en the hardener. to get very tough stuf. be sure to well preparing surface by sanding to get more grip on surface.you can make littel hole on each side of de crack to get a better grip for the epoxi.
Posted on Jul 05, 2007
SOURCE:
My 1983 Ford Tioga motorhome is leaking when I try and fill up the water tank. It has been sitting for 10 years and I can't tell if the leak is from the water tank or the old tubes. Where shoul
If water is getting under the carpet its probably the tank or a fitting on the tank.
I don't know of a way to find out unless you remove the tank to see under it.
Apr 08, 2013 | Cars & Trucks
Gaggia Syncrony logic rapid steam machine leaks water from bottom
Check the chamber under the white plastic valve behind the brew unit, it might be blocked with coffee.
Apr 13, 2010 | Coffee Makers & Espresso Machines
Have a baby gaggia coffee machine and unable to find anywhere that will service or repair. The machine has worked really well for 3 years but now is making aloud noise when working and the flow is very...
The loud noise is coming from the vibrating water pump.
One posibility is that is full of scale or and dirt so you can try descale the machine.
Second is probably the water tank can fit corectly on the base and the valve on it does not open correctly or not at all so the pump it can not s**k water but air or a mix of them so we have the loud noise.
Finally you can remove the shower disk on the group head , locate above where you place the filter holder and clean it probably is full of dry coffee and block the water way out.
Please note that can be all above problem together.
Good luck
Mar 27, 2010 | Gaggia Baby Espresso Machine
My baby gaggia dose (brand new out of the box) leaks
HI
Call who ever you bought it from and have them diagnose the problem. I think you have a disconnected hose or something worse.
Nov 18, 2009 | Gaggia Baby Espresso Machine
I let the water tank run empty by accident and now the machine keeps making a loud cracking/clicking sound which is intermittent whlist it is warming up. Have I done permanent damage?
It is possible that the elements got damaged, but try this fill tank let machine cool about 2 hours, then turn on and open the hot water valve and run about half the tank through, then descale machine.
Nov 09, 2009 | Gaggia Baby Espresso Machine
Leaking water
If the machine is less than 6 months old then there could be some coffee aound the gasket use a toothbrush to clean the gasket and try again. If the same result, then the gasket needs to be replaced.
Aug 12, 2009 | Gaggia Baby Espresso Machine
Espresso gaggia titanium. Water Tank leaking
The o-ring on the bottom of the water tank is either missing or not seated properly.
May 10, 2009 | Gaggia Titanium Espresso Machine
Gaggia Baby - water leaking from round the edge of main bulkhead
you need to replace the main rubber gasket within the bulkhead. due to heat and use, the gasket cracks and no longer is able to seal the brew head. a new gasket should be part of the warranty but you can purchase one and replace your self, pretty simple.
Mar 05, 2009 | Gaggia Baby Espresso Machine
Dishwasher tub leaks underneath
Hello. Anything is worth trying! But I would recommend epoxy. It works alot better with plastic and rubber items. Most of the leaks I have found in Kenmore machines are at the water pump. You may want to take a peek while it's running, just stay away from the wires!! Thanks!
Jan 17, 2009 | Kenmore 15899 Built-in Dishwasher
Gaggia Baby Espresso Machine Logo
157 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Pierre Laplante
Ekse
Marvin
Marvin
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
