Question about Brother Hl-2130 Mono Laser Printer
Brother bhl2 maintenance - Brother Hl-2130 Mono Laser Printer
2 Suggested Answers
  • 191 Answers
SOURCE: PRINTING, COPY PROPER, SCANNIG PROBLEM
u have ti install drivers again after uninstall old drivers from computer.
Posted on Apr 06, 2009
Brother DPC- 115C
It sounds like you need to update the head property...that's usually what the maintenance 7X is. These are some complicated instructions. Try to go through them and post back with a detailed description of where you get stuck (sorry, I don't have the graphics except via email) :
[ 2 ] To Update the head property information stored in the EEPROM on the main PCB:
For the MFC210C U.S.A./Canadian models, skip steps (1) through (3) below.
(1) Make sure that the machine's power cord is unplugged from an electrical outlet.
If the machine is connected to a PC, unplug the USB cable.
(2) Switch on the PC.
(3) Plug the machine's power cord into an electrical outlet.
(4) Press the Menu/Set and Black Start (Mono Start) keys. Next press the key four times to
make the machine enter the maintenance mode.
TIP: Models equipped with numerical keypads can enter the maintenance mode in the same
way as conventional models; that is, by pressing the Menu/Set, *, 2, 8, 6 and 4 keys in this
sequence.
(5) Connect the machine to the PC using the USB cable.
(6) On the PC, run the ID/head property setup utility (BrUsbsn.exe) in the folder created. The
following window appears.
(7) On the Model menu, click BH3.
6-9 Confidential
(8) In Port, select the port number assigned to the BHL2-Maintenance Printer.
To confirm the port number, follow the instructions below.
Click Start | Settings | Printers.
The Printers window appears as shown below.
Right-click the BHL2-Maintenance Printer icon.
Click Properties.
6-10 Confidential
The BHL2-Maintenance Printer Properties window appears as shown below.
Click the Ports tab.
The port number assigned to the Brother BHL2-Maitenance Printer, USB010 in this example,
is one that has been selected in Port on the BrUsbSn screen (page 6-8).
(9) In the Head Info. box on the BrUsbSn screen (page 6-8), type 12 digits (e.g., 776601D00009)
out of the 13-digit property code (enclosed with asterisks, e.g., *J776601D00009*) which is
printed on the bar code label attached to the head/carriage unit. Click the OK button.
(10) To check that the entered head property is correct (using Function code 68 in Chapter 8,
Section 8.5.16.):
MFC620CN/425CN/420CN/410CN/215C/210C and FAX2440C
Press the 6 and 8 keys in this order. Then press the 2, 5, 8, 0 keys in this order.
DCP315CN/310CN/120C/115C/117C/110C
Enter 6, 8, 2, 5, 8, and 0 by using the and Set keys.*
(*To enter a numerical code on models having no numerical keypad, press the key several times to
display the numerical code to be entered and then press the Set key. Repeat this operation for each
numerical code.)
The LCD shows the current head property information (12-digit code) stored in the EEPROM
on the main PCB.
(11) Check that the character string entered in step (9) is displayed in "XXXXXXXXXXXX."
If it is OK, press the Stop/Exit key.
If something other than that is displayed in XXXXXXXXXXXX, check the connection
between the PC and machine and go back to step (6).
Nov 03, 2007 | Brother DCP-110C All-In-One InkJet Printer
Printer is flashing "Clean Unable 46- Refer to Troubleshooting & routine maintenance in user's guide" BROTHER DCP-135C
printer is flashing "CLEAN UNABLE REFER TO 46- TROUBLESHOOTING AND ROUTINE MAINTENANCE IN USER'S GUIDE..BROTHER 2480C
Feb 23, 2013 | Brother Multi-Function Center MFC-3360c...
My brother 420cn said unable to print see manual trooble shooting and routine maintenance, but I don't have a manual.
Have you checked at the Brothers web site? I find that they have the product manuals easily available. I have had two Brothers printers. I always lose the manual.
Nov 29, 2011 | Brother MFC 420CN All-In-One InkJet...
SCREEN READS ERROR 71 CALL BROTHER, WHAT IS THE PROBLEM, WHAT NUMBER DO I CALL
This error means that there is a scanner motor error. Try and remove the error by following these steps: Press MENU *,2,8,6,4. The machine beeps for approximately 1 second and will display "MAINTENANCE" on the screen, indicating that it is placed in the initial stage of the maintenance mode, a mode in which the machine is ready to accept entry from the keys. Now you are inside the simulation, Press 01 to reset the error status. After that press 99 to exit the simulation.
- Pressing the 9 key twice in the initial stage of the maintenance mode makes the machine
exit from the maintenance mode, restoring it to the standby state.
- Pressing the Stop button after entering only one digit restores the machine to the initial
stage of the maintenance mode.
If the error comes back, call Brother support, here are contact details:
7777 North Brother Blvd.
Bartlett, Tennessee 38133
Phone: 1-877-BROTHER (877-276-8437)
901-379-1215 (fax)
Monday-Friday, 9:00am to 8:00pm Eastern Time
Jan 12, 2011 | Brother MFC 8500 All-In-One Laser Printer
Error 71 / It is not working.
This error indicates that there is a scanner motor error. Try and remove the error by following these steps: Press MENU *,2,8,6,4. The machine beeps for approximately 1 second and will display "MAINTENANCE" on the screen, indicating that it is placed in the initial stage of the maintenance mode, a mode in which the machine is ready to accept entry from the keys. Now you are inside the simulation, Press 01 to reset the error status. After that press 99 to exit the simulation.
- Pressing the 9 key twice in the initial stage of the maintenance mode makes the machine exit from the maintenance mode, restoring it to the standby state.
- Pressing the Stop button after entering only one digit restores the machine to the initial stage of the maintenance mode.
If the error comes back call Brother support, here are the contact details:
901-379-1215 (fax)
Nov 22, 2010 | Brother DCP 1400 All-In-One Laser Printer
My brother printer is MFC-490CW and it just says "unable to print 36" what could this be?
Brother Error CodesRAM clear (most models)
Quickly press function * 2 8 6 4
Display should read maintenance
Press 0 1 for a full ram clear, or 9 1 to retain user data
Display should read reinit for a few moments then redisplay maintenance
Press 9 9 to exit the maintenance mode
Mar 08, 2010 | Brother MultiFunction Center MFC-440CN...
Would you please tell me how to clear the memory on my Brother Fax 837MCS? Thank you
This procedure works on most Brother machines:
  1. RAM clear (most models)
  2. Quickly press function * 2 8 6 4
  3. Display should read maintenance
  4. Press 0 1 for a full ram clear, or 9 1 to retain user data
  5. Display should read reinit for a few moments then redisplay maintenance
  6. Press 9 9 to exit the maintenance mode
Nov 19, 2009 | Brother Office Equipment & Supplies
Maintenance manual for Brother LT2 B838
yes i do.....
541-474-9631
National Sewing Supply
Oct 27, 2009 | Brother LS-2125 Mechanical Sewing Machine
Apr 06, 2009 | Brother MFC 7420 All-In-One Laser Printer
Brother Hl-2130 Mono Laser Printer Logo
187 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
